Attempting to date classic Raleigh
Brian
Bikes: Schwinn World Sport, Raleigh ????, Triumph ????
Hi.
I am just getting into classic bike repair and found an older Raleigh at a rummage sale. It needed to be stripped and so that is what I did.
I've had it repainted, but I think I may have painted over the serial number before I could write it down. I also forgot to write down what style of Raleigh it is. If you've hit your head in disgust please remember I'm new to this and I am learning as I go.
My question is:
Can I still identify this bike? I have a stamp from the cranks "201 ND 66" Does this help me at all?
If anyone can help me identify this bike I would be thrilled. I am anxious to get new hardware on it, but want to be sure I'm buying the appropriate parts.
Thanks in advance for your help.
-brian
My question is:
-brian
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,062 Times
Unless the paint is "powdercoat thick" you should stll be able to read a serial number through it. But if not, just take some pics of the lugs, the bottom bracket, the dropouts, the rear cluster (where the seatpost goes in), and the fork crown and post them here. There are Raleigh experts who will know.
Brian
Fantastic! I will take some pics tonight.
-brian
-brian
Ferrous wheel
Bikes: 2004 Gunnar Rock Hound MTB; 1988 Gitane Team Pro road bike; 1986-ish Raleigh USA Grand Prix; mid-'80s Univega Gran Tourismo with Xtracycle Free Radical
What components came with/are on the bike?
Also, I have a powdercoated frame, and I can still read the serial number. I'd be surprised if you can't still read yours.
Brian
I think, like love, I was looking in all the wrong places for the serial. It was on the drop out.
097578 is what is stamped there. No letters though.
I took photos on my lunch break, and I will post them when I get home this evening.
Also, I believe all the parts are Raleigh. The cranks have a Raleigh stamp on them and the axle had "16GC" stamped in it.
Thanks for all your help.
-brian
-brian
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Well, all the instances where the serial number has been placed on the dropouts of Raleigh bikes, it has turned out to be sometime around 1968 for a build date. I've heard of Grand Prix's and Super Course's with the serial number there. A picture will make short work of determining the model.
Quoted: 3810 Post(s)
Liked 6,705 Times
-brian
-brian
I have a '71 Super Course with serial # on the left rear dropout and believe the early 70s builds can usually be identified that way. Of course, when it comes to Raleigh serial #s, confusion is usually the answer.
Neal
Brian
Ok, here come the photos.
Hopefully these can help. I didn't get one of the frame and fork together. If anyone thinks that would be more helpful I could take a shot of it tonight and post it. I also have a couple of other angles of these points, if you want to see another view.
I appreciate everyones help with this.
-brian
-brian
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Brian
The guy who painted my Dad's Camaro painted it for me.
I don't think he's done bikez before. His heart wasn't in it, but he did a great job. There are a few runs and when I took the tape off the front, it cracked a little.
The color is actually the same color he painted the Camaro. It is a 69 Cadillac color. I can't remember the actual name, but I really love it and can't wait to get the bike together.
I was thinking of telling him he should consider doing bikes, but he doesn't live in a large metropolis and I don't think there is much demand in Sandusky, Ohio for bike painting.
-brian
-brian
Brian
It was a low-end model, but I got it for $1 at the rummage sale. Good first project.
Now that I have an idea of the date and model how should I go about finding the correct parts for it? Do I need to know more specifically what the date on this bike is? The original color was white.
One of my main concerns is the bottom bracket. The axle I pulled out was in good shape, but I've heard it is better to get an axle that will support cotterless cranks. Who has a good axle for this bike?
Also, what about bearings? Should I get them loose or in a cage (proper term?)?
Damn...so many questions. If anyone can help me out I'd appreciate it. Like I said, I am fairly new to this so I may have quite a few questions.
-brian
-brian
Guest
Posts: n/a
Quoted: Post(s)
raleigh dating
For the correct equipment go to Sheldon Browns site
www.sheldonbrown.com/retroraleighs/
and check for the retro raleigh site. There or in one of the links from there you will find a copy of the Raleigh catalog for the matching year. Usually a list of componentry(specs) is included. I would go for a original cottered crank as it was original. A period-correct cotterless crank would be an adequate upgrade and might be easier to find. Try ebay. As for the bb loose bearing-balls are technically better whereas caged ones are easier to put in. I do not know which was original but is supect ballcages were, due to industrial fabrication. The same applies to the steering bearings.
Pictures look like it could turn out to a nice project.
Bikes: All 70s and 80s, only steel.
Nice colors. What you're looking for is a new spindle, not axle (difference being that an axle doesn't spin, everything around it does, and on a spindle, the spindle spins). Beware of swapping out the bottom bracket; there are some compatibility issues with older Raleighs. It can be done, but it may be harder than you think. I second the idea of finding a period-correct cotterless crank. Try ebay with "vintage Raleigh cranks," or something like that.
Chrome polish (e.g. simichrome, blue magic, etc.) will work a miracle on that headbadge.
Good luck with the project.
Brian
Thanks for the added help.
I didn't know to use chrome polish on the badge! That is great.
I have heard the spindle refered to as the "axle" or "spindle." Recently, I was talking with someone in our bike group about my spindle and he had no idea what I was talking about so I guess I assumed everyone called it an axle.
I made another thread here. Sheldon Brown suggested not spending too much money on the bike. I was considering throwing the spindle I pulled out, back in. It appears to be in good shape. Are their advantages to cottorless cranks besides easy crank removal?
Thanks for the assistance.
Ferrous wheel
Cotterless cranks are often lighter than their cottered counterparts. Also, a wide variety of chainrings are available for most cotterless cranks.
Cottered cranks sometimes look better on a vintage bike, if you ask me.
Glutton for Punishment
Quoted: 5 Post(s)
Liked 8 Times
His Record would've come with the three-spoke Nervar crank, which looks sort of bland (imo). A Stronglight, or even a Solida from the same period would look much better.
Brian
I have been trying to specifically date this Raleigh.
I was looking through Sheldon Brown's catalogues and I couldn't find mine in there. The color scheme originally was white with black. Does anyone specifically know what year Raleigh offered that color?
Thanks.
Thanks.
Liked 4,395 Times
Thanks.
Thanks.
Don't hope to get more accurate then that, for the Raleigh serial charts online are mostly incomplete (if not 100% erroneous in sections), and cannot be relied on. Consequently, dating the lightweight Raleighs is mostly dependent on component variances, component date stamps, and paint scheme variants.
-Kurt
Liked 4,395 Times
P.S.: Sheldon's .PDF catalogues are incomplete.
See:
https://bulgier.net/pics/bike/catalogs/Raleigh74/
-Kurt
See:
-Kurt
Vello Kombi, baby
Bikes: 1973 Eisentraut; 1970s Richard Sachs; 1978 Alfio Bonnano; 1967 Peugeot PX10
Quoted: 80 Post(s)
Liked 14 Times
urghh... looks like a kickstand mashed the rear stays... check the alignment of the rear triangle.
"It's always darkest right before it goes completely black"
Waste your money! Buy my comic book!
Brian
I checked on the cranks and chain rings.
The cranks have the Raleigh stamp on them and the chains have 40 and 52 stamped into them. I noticed that the 75 Raleigh had a Raleigh crank option (40/90). Also, the cranks have "201 ND 66" stamped in them.
Is it fruitless to continue trying to date this bike if I am going to put the original spindle and cranks back on? I don't want to put too much money in this bike. I'd rather get myself comfortable with putting a bike back together.
Thanks for your continued help.
PS - How do I check the rear triangle alignment?
