bottom bracket question
Bikes: Cannondale M300
Hi, i just bought a used Race Face Next LP Crankset on Ebay a couple of days ago, and the seller told me to get a 113mm bottom bracket to go with the crankset. I then bought a 113mm bb from JensonUSA. When i finally got my bottom bracket in mail today i found out they had ship me the wrong bb. (from a Shimano un53 to un73) It is a a better model , but it is only a 110mm bb. Would that be a big problem for my crankset? or should i just put it in anyway because it is only a 3mm difference. thank you very much in advance for anyone's help.
weirdo
Bikes: Viner Pro Carbon,Fat Chance Yo-Eddie, Specialized S-Works (epic), Voodoo Rada, Trek 830 setup SS for commuting.
The 110/113 measurement is the spindle length. The spindle length depends not only on the crank, but on the fram you have. The 110 length will sit your crank 1.5mm closer to your frame than the 113. If the crank can handle this without rubbing the frame, then the next thing you need to worry about is if the change will throw your chainline off. Having your cranks 1.5 mm closer to the frame may cause some problems with the way the bike shifts. I know 1.5mm doesn't sound like a lot, but if you know you need a 113, I would use a 113 not a 110. My only question is how your e-bayer knew that you needed the 113.
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
Have you gotten the crankset yet? From the pictures i've seen, it looks like it needs an ISIS bottom bracket. If that is the case, you won't be able to use the shimano. I think 113 is the standard size for ISIS.
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
Quoted: 128 Post(s)
Liked 12 Times
Yup, I'd guess that the crankset takes an ISIS bottom bracket, for which the only available spindle lengths are 108, 113 and 118mm. Sounds like you got a square-taper BB.
If indeed your crank takes a square-taper, Shimano's 113mm bottom bracket spindles are nearly symmetrical (both sides stick out equally far from a 68mm bottom bracket shell) whereas the 110mm is asymmetrical, with the non-drive-side spindle 3mm longer than the drive-side.
"c" is not a unit that measures tire width
Bikes: 2006 Orbea Volata, 84 Trek 760, 83 Trek 720,
They call me "Mr. Mixte"
