28.6 Derailleur Adapter Clamp - Campagnolo brand - does/did it exist?
Unique Vintage Steel
Need some help from the mechanics and wrenches out there that have been at this longer than I have been. I want to know if what I'm looking (and praying I find) actually exists. I've seen the Campangolo adapter clamps for front derailleurs in 32 and 35mm. But did they ever make them in 28.6mm? Oh, and I'm looking for a silver one!
1) yes I know there are other brands of adapter clamps such as "problem solvers" and I'm not interested in them at the moment
2) I may be willing to send a few $$ finder's fee via PayPal if someone can source one of these Campagnolo clamps (in silver!)
3) I'm also aware that it is possible to take apart campangolo derailleurs and frankenstein myself a 2007 QS campy derailleur with a 28.6 clamp. I haven't ruled this route out yet, but it's not yet at the top of my options.
Here's a pic of what I'm after:
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
Or, get yourself a roll of Campagnolo-branded electrical tape and make a shim so that you can use the 32 mm clamp That works surprisingly well!!! Or you can use an old strip of inner tube.
moxfyre....
Putting a lot of $$ into restoring a bike with a new campy group and I'd rather not "settle" for anything that I don't want if I can help it. And if you can't help, then best to keep your yapper shut.
moxfyre....
Good luck finding the clamp, and do take the shim suggestion seriously if you can't find a 28.6.
Fair enough, and no hard feelings. The shim is probably the last on my list of options, but like everything it is an option. Guess I haven't dropped hints about my restoration project around the Mechanics forum much like I have in some of the others. I'm putting a 2006/2007 Chorus group on my early 80's Gazelle Champion after having it completely repainted and reproduction decals put on. She's going to be my Master's graduation present to myself.
Did you consider using an 8/9 speed der in 28.6? They are plentiful NIB on ebay for very cheap. There might be a little slop in the front shifting but not too much. All Campy's current front ders are basically 8 speed width with a plastic shim anyhow. Good luck on the bike project.
Tim
Tim
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
I had a similar problem on my Bianchi Veloce which has a 28.6 mm seat tube, and came with a Mirage FD (in black). Being an OCP, I wanted a silver FD so that it would match, and rather than use an adapter, which I thought would be ugly, my solution was to look on eBay for a NIB older FD with a 28.6 mm clamp, and swap the clamp with that on a new Veloce FD.
You can do this with much of the Campy FD gear as the parts are interchangeable; it's just a bit fiddly, and helps if you have 3 hands…
Hope this helps -
- Wil
Hope this helps -
- Wil
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
Quoted: 138 Post(s)
Liked 12 Times
I might suggest the (gasp) Shimano solution which is a pair of shims that is double sided taped to the inside of the 32mm derailleur. You should be able to pick these up at your LBS for only a couple bucks. They are silver so you would have to look VERY close to be able to tell.
The views expressed by this poster do not reflect the views of BikeForums.net.
"Purgatory Central"
Hey 'cuda2k', if you can find a campy clamp/adapter like the pic you posted, then that would be way cool, even if it's not the size you need. You can always modify the clamp at the mating surfaces where the bolt goes by filing it or machining it to fit a 26.8 tube. Outside of that, get a super record FD clamp and try to modify that too. Those old super record derailleur clamps were quite ornate, and maybe you could modify it to work. That would look good, and be period correct. Hell, as far as that goes just use a complete super record FD with your modern Chorus crankset. You may have to modify it some to work with the narrower 10-speed chain, but it could be done.
Just a thought
Just a thought
Chairman of the Bored
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
You can buy a record metal cage FD in 28.6 Actually I have one in my house right now, NIB. It was too small for my bike....for some reason I thought it was the right size.
One thing I didn't mention was that I'm using 2007 Campy derailleurs and shifters. Thus, I need a "QS" style derailleur. I've been keeping an eye out for a 28.6 derailleur on ebay to frankenstein as well. Catatonic - if you want a metal cage Record derailleur with a 32 clamp or braze on, maybe we can work out a mix/match arrangement?
If in doubt Fix it
Bikes: All Hand built: Raleigh Record fixed conversion, On-One Pompino, Felt TK2, Look KG451, Rychtarski Lo-pro, Orlowski Lo-Pro, New Hudson, Haro X2
I'm having a very similar problem with a build i'm doing in the UK. My lbs has contacted a few different dealers and they've all said there is no 28.6mm clamps anymore, so i'm being forced into a 32mm + spacer.
Quoted: 2026 Post(s)
Liked 1,096 Times
Originally Posted by moxfyre
Why the heck would Campy stop making the most standard clamp size in existence??
Quoted: 443 Post(s)
Liked 27 Times
Nashbar is still selling adapters in 28.6 and they're on sale for $2.45. I bought two and they're much nicer than I expected. They're not Campy nice, though.
killsoft - good luck. Ebay is about your only chance of finding an older Campy Record or Chorus in all silver. I've had the luck of finding someone with an older 28.6 clamp Record derailleur which I'm going to swap clamps with a Braze-on style Centuar derailleur. I think we should all start bombarding campagnolo's email asking why they discontinued 28.6 clamps when it has to be the most common tubing size out there (although not in new bikes). There are a billion great older steel bikes that would look and ride fantastically with a campy 10sp upgrade. My Gazelle will be one of them.
