Taking color off Deep V - Changing Colors
I have a deep V rim (gold) that i want to make silver. I've heard of people wiping/sanding the color off of a deep V, but I have no idea how to do it, especially how to do it without messing up the rim. help? thanks
OR, how do i change the color? what kind of paint do you use? how do you apply it? etc. etc.
this is my alternative to spending money on rims..
Bikes: nagasawa, fuji track pro
Quoted: 26 Post(s)
i dunno how the color is applied, but if they are painted use, aircraft stripper...if they are anodized then....i dunno, buy new wheels
Is the old color broken? Is silver faster than gold?
The gold color's probably anodized. I dunno how you'd take it off without wrecking your rim.
end of biters
If it's anno'd I don't see why you couldn't just try spray painting it. I'd just take the tire/tube off and find some way to mask the hubs and spokes, probably some intricate mix of masking tape and newspaper. If it turns out crappy, well, the only alternative would have been to buy new ones anyways.
Bikes: Land Shark, Level Professional, Tsunami singlespeed, Giant Reign 1
the short answer... oven cleaner. this is if the color is anodized on. soak the rims in a sodium hydroxide solution, and then remove the finish with a fine sandpaper or wire wheel. after the color is stripped, you should use a buffing wheel & buffing compound, or at the least a rag and brasso to buff the finish to silver. i have to stress, that this is *extremely* time consuming.
if it's powdercoated, then get some automotive grade paint stripper gel and a handful of masks, as the **** stinks to high heaven, afterwards, you'll have to polish the rims as described above.
tupac for prez
Bikes: a bunch of track stuff.
you can powdercoat over the anodizing.
if you prefer to paint, use some light sandpaper (1000 grit) and scuff the surface before spray bombing them.
you can probably get your local auto body place to paint them for around 50 bucks. or go to a local vocational/tech high school, and see if they have an autobody class. .thats good practice for someone learning to paint cars... thats the sort of **** they had me do when i was a painter's apprentice in the early 90's.
the powdercoated deep-v wheels require chemical stripping... it's a ***** to do, as well.
get some of the earth-friendly stripper, go to a do-it-yourself car wash, and once it bubbles up, blast that **** with the high pressure wand.
it usually takes 2 or 3 times with that method, but the surface under the powdercoating is really nice and shiny.
tupac for prez
it eats it, quickly. and makes horrible fumes.
the fumes are hydrogen gas, very flammable. however, it's not 'really bad', and it won't eat it up, provided you aren't using a 90% solution. wipe the rims down with isopropyl (drug store) or methyl alcohol (fuel line dehydrator/brake cleaner) to oxidize them quickly.
uberNEWB
Bikes: Haro V2 [rip / stolen], PEUGEOT '93 SELECT
GREASED LIGHTNING. you can buy it by the qt, gal or 5gallon jug. Dilute it 50/50 with water and let your anodized item soak for a while until the color comes off... DO NOT USE DE-IONIZED WATER !!!! THIS WILL CAUSE MASSIVE PITS IN THE ALUMINUM !!!
After, rinse in cold water to stop the process of the greased lightning.
Lowes and other hardware stores often carry this product. The alternative to this is using LYE to strip the dye out of an anodized metal. But theis causes larger issues of pitting and can effect the metal (so I have heard. I am not a metallurgist, so I would not be able to tell you about how either product effects the grain of the metal. Either way, once you have stripped the color you can anodize it to what ever color you want.
For more info on anodzing join our group... https://groups.yahoo.com/group/anodizing101
Hope that helps.
uberNEWB
Two hours, plus the time to set up, clean up, go get all the crap, etc. Plus the ventilated space to work in. Plus the time to polish the rims.
Don't get me wrong, if you have the time, the right space, and want to save cash, good for you. Time is my most precious asset, so it's worth it to me to take them somewhere. The quality of the final product is also a bit more assured.
sell your rims, and shell out the money for the rims you want. better than messing up the rims you have and then buying a whole new pair for full price.
uberNEWB
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Step 1: Sell your old rims
Step 2: Take cash (from Step 1) and add cash to it.
Step 3: Buy new rims. VERY IMPORTANT: Make sure you get the color you like this time.
rex
Elitist
Liked 92 Times
Sorry. Here you go:
Step 3: Post to Ebay/Craigslist with the words "fixed", "fixie", "track", "vintage", "NJS" (even though they aren't), and "conversion" sprinkled into the ad. They'll be sold by the time you get home from work.
Top 5 ******
Bikes: Bareknuckle
How can you make the rims shiny silver like these:
https://velospace.org/node/3568
Can you get this out of the normal silver deep v's?
