is there any problem packing c02 cartridges for flying?
JuNKie! bike junkie!
might be a stupid question but I'm fly in to toronto with my bike and was wondering if there is any issue packing c02 refills with my bike?
cargo is pressurized correct?
they won't blow up and scratch my frame ....most importantly?
customs won't give me any hassel?
stupid question maybe but better safe .......
www.cranks505.com
www.cranks505.com
Cornucopia of Awesomeness
not allowed on board or in your checked luggage.
the only exception is if they're part of a self-inflating lifejacket.
The pressure in your carbon dioxide cartidges are in the couple of thousands of pounds per square inch range. Atmospheric pressure is about 15 pounds per square inch, meaning, even if you go from sea level to outer space, you will only see about a 15psi drop in pressure.
So to answer your question, do you think your CO2 cartridge will mind holding in X,000 psi vs. X,015 psi?
Given this knowledge, one can also figure out whether one needs to "bleed off" the tires on a bike prior to loading on an airplane, regardless of whether the cargo compartment is pressurized.
Regardless, with air travel being such a hassle these days, it would be prudent to check with your favourite airline to determine if these are really air-transportable, even if they are technically so.
hey man I can lift heavy thing but......
www.cranks505.com
www.cranks505.com
not allowed, unless you can take off the valves. when i travel with my paintball gun, my co2/n2 tanks had their valves removed before i was allowed on the plane with it.
Perineal Pressurized
Rather than deal with the potential hassle, wouldn't it be easier to pick up a couple at the local sporting goods store?
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
When I asked the people at Wally World bike dept, "where is the closest bike shop" they just shrugged their shoulders.
When I asked "where are the childrens guns" they pointed to the back of the store. Very disturbing.
raodmaster shaman
While in theory the pressure difference shouldn't effect the cartridge, there are other factors like rough handling in baggage, extreme temperature ranges, or manufacturing defects that could compromise the strength. Considering that one of those bursting would be like a little bomb, I can see why the TSA would rather play it safe and not allow them.
My experience, fwiw:
- From 1993-1996, I flew with C02 cartridges in my checked luggage (and maybe carry-on, can't recall) numerous times within the U.S. and Europe. No problems.
- In 1996, when moving back to States, I had a layover in Copenhagen. Before boarding, I hear an announcement over the PA system calling my name. I go up to the counter, and two Danish cops say they need to look in my luggage. "Do you have any gas in your suitcase?" I'm utterly confused, then it hits me - the CO2. I rooted around in my bag, handed over 4-5 cartridges, and was on my way. Have not flown with the suckers since then.
I fly with a bike perhaps 30 round trips a year. CO2 cartridges never make it through security. If they're in a checked bike bag, your bag gets opened and they (and whatever else might disturb a low-wage inspector) get removed. It doesn't matter what your excuse or rationale, or even being able to quote TSA regs if they say otherwise -- every time I've forgotten and had one in a bag or on a bike, it gets confiscated. Just buy a frame pump and use it when you travel if you can't find CO2 cartridges. I have a back-up CO2 unit that will take the non-threaded cartridges for BB guns and there's no part of America more than twenty miles from a WalMart with a nicely stocked gun section at the back. In a pinch, it works. But still I keep the frame pump in my bike case. If nothing else, you do need to pump up tires from time to time.
señor member
Bikes: Malvern Path Racer, Schwinn LeTour, Follis, Bridgestone 400 (RIP), concord 2sp
Seriously. I think it all depends on the airport. I've had stuff that wasn't up to snuff allowed at some airports and taken away at others. If you have enough time, you could always order some online and have them sent to your hotel or wherever you are staying (keep in mind they ship ground).
extra bitter
so I just unpacked my bike they took my c02 refills and my campy pedals clips and toshi straps!
www.cranks505.com
www.cranks505.com
roll'em high
Wolfman got nards!
Bikes: '06 Bianchi Volpe, '09 Mercier Kilo TT, '08 Jamis Exile 29er
That's ****ed up. Time to file a complaint. And wait a long time for nothing to happen.
Reason is a scoundrel, stupidity is direct and honest. –Ivan Fyodorovich Karamazov
Man's mind, once stretched by a new idea, never regains its original dimensions. –Oliver Wendell Holmes
I just ****ing around.
all my c02s made it and so did my pedals.
www.cranks505.com
www.cranks505.com
Brakeless
Bikes: Brew, Felt TK2, Masi Coltello, and Unknown French Frame.
You know when you bought your ticket how you talked to a lady. You shouldve asked her.
