Presta valves: demonic or Satanic?
View Poll Results: Presta valves: Satanic or demonic?
Satanic.
5
4.63%
Demonic.
10
9.26%
Neither. Bush's fault, like everything else.
15
13.89%
None of the above. You're just a klutz.
78
72.22%
Voters: 108. You may not vote on this poll
Old 12-02-07 | 08:24 PM
The Weak Link's Avatar
Bikes: GF Wahoo '05, Trek T1000 '04, Lemond Buenos Aires '07
The poll didn't attach itself properly with the last post. This query was inspired by me taking two hours and trashing three inner tubes trying to replace one stupid tire on my road bike so I could mount it on my trainer. And then I'm rewarded by the evil Coach Troy.
The Weak Link is offline
Reply
Old 12-02-07 | 08:37 PM
20 Anniversary
What kind of problems are you having? Only one I can imagine is that you're ripping the valves off when trying to inflate with a hand pump. In that case, you can often brace your downstream hand against the rim or wrap a couple of fingers around the spokes to hold the pump steady.
When I started cycling, 30 or so years ago, I didn't understand why there had to be two kinds of valves. Now that I'm used to them, though, they're easier to inflate than schraders, because you don't have to fight the spring.
Velo Dog is offline
Reply
Old 12-02-07 | 08:57 PM
I call them junk. I always change them out for schraders as soon as possible. People should learn to recognize landfill when they are looking at it. bk
bkaapcke is offline
Reply
Old 12-02-07 | 09:25 PM
Bikes: Cannondale t2000, Schwinn Moab mountain bike, Specialized allez cro-mo
Schrader vs Presta
I asked this same question on another forum with similar results. One of the answers I got was that you can't find Presta at a loca Wal Mart if you are out touring. And I can't argue with that but if you are running a 1 1/2 inch tire on a 26" wheel you are going to have problems finding these. I have drilled out my mtb tires to schrader and have left my T2000 presta. I guess the debate goes on.
Jim Bushard is offline
Reply
Old 12-02-07 | 09:45 PM
What a crappy poll! You should have included a choice for French, which ranks right there among satanic and demonic, Wisconsin winters, and white bikes, along with with the other choices.
The presta must have been invented by the same French guy who invented the Chauchat machine gun (a/k/a "shosho") of WW1 fame. The dough boys didn't care for it.
doctor j is offline
Reply
Old 12-02-07 | 10:21 PM
Artkansas's Avatar
Pedaled too far.
I've only had to use presta's recently. So far I'm not amused. Schraders are so straight forward.
Artkansas is offline
Reply
Old 12-02-07 | 10:24 PM
dendawg's Avatar
15 Anniversary
Took a little getting used to on my road bike but they're ok. When I get a flat I find them no harder to change then a Schrader tube.
dendawg is offline
Reply
Old 12-03-07 | 12:07 AM
ollo_ollo's Avatar
20 Anniversary
Bikes: Still have a few left!
I would definitely have voted "French" if it had been a choice!
ollo_ollo is offline
Reply
Old 12-03-07 | 12:38 AM
Tom Bombadil's Avatar
His Brain is Gone!
Bikes: RANS Stratus, Bridgestone CB-1, Trek 7600, Sun EZ-Rider AX, Fuji Absolute 1.0, Cayne Rambler 3
I definitely prefer Schrader. But if one is going to run thin rim wheels, then you've most likley going to have to go Presta.
I would want Schrader if I were running 32mm or larger.
All of my current bikes use Schrader. My Trek hybrid came with Presta - even though it uses 700x38 tires and wider rims. It was later drilled out for Schrader.
"Too often I would hear men boast of the miles covered that day, rarely of what they had seen." Louis L'Amour
There are two types of road bikers: bikers who are faster than me, and me. Bruce Cameron - Denver Post
Tom Bombadil is offline
Reply
Old 12-03-07 | 05:45 AM
maddmaxx's Avatar
Boomer
Titanium Club Membership
20 Anniversary
Bikes: Diamondback Clarity II frame homebuilt.
I don't understand......I have absolutely no problems with Presta valves......???
You unscrew the cap...unscrew the locknut...give it a tap to unseat the valve...fill it with air...screw down the locknut...screw on the cap.
Even DG has never complained about the mechanics of this device.
maddmaxx is offline
Reply
Old 12-03-07 | 05:59 AM
yohannrjm's Avatar
There's a biking season?
I've only got into riding road bikes over the last year, so I'm new to Presta's.
I have no problems changing tubes. The only hassle is getting the pump off the valve after filling. I always wind up losing air when I do that.
Maybe I still haven't got the hang of it.
yohannrjm is offline
Reply
Old 12-03-07 | 06:06 AM
stonecrd's Avatar
OnTheRoad or AtTheBeach
Bikes: Ridley Noah RS, Scott CR1 Pro
I think the type of pump you have makes a bigger difference than the valve. I initially had a Wrench Force pump and had nothing but problems getting it to seat correctly on the presta valve. Now I have a specialized pump the head is much nicer and goes on an off easily and I have very little problems pumping up the tire now.
The problem with the gene pool is that there is no lifeguard and the shallow end is much too large
2013 Noah RS
stonecrd is offline
Reply
Old 12-03-07 | 06:42 AM
freeranger's Avatar
20 Anniversary
Bikes: 06 Lemond Reno, 98 GT Timberline
Not crazy about presta, but have never had a problem with them. Maybe it's your pump. This is the one I use and have never had a problem (and I like the dual head so no levers to switch when changing from presta to schraeder):
https://www.performancebike.com/shop/...tegory_ID=4360
freeranger is offline
Reply
Old 12-03-07 | 06:45 AM
roccobike's Avatar
Bike Junkie
From: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
For low pressure tires, like MTB, I prefer Schrader. For high pressure road tires, Presta all the way. The Presta's are a little less convenient to inflate, but the valve is designed to allow less pressure loss when disengaging the pump. Once the adaptor is on the Presta, I don't see much difference from a Schrader. As was said before, the pump makes more difference than the valve.
As for not being able to find a Presta valve tube at Walmart while on a long ride, I don't understand why there isn't a spare tube in their fanny pak. Of course the last time I needed the spare tube, it was for a group ride partner who doesn't believe in riding with a spare. Come to think of it, he still owes me a new tube.
Roccobike BF Official Thread Terminator
roccobike is offline
Reply
Old 12-03-07 | 06:53 AM
John E's Avatar
feros ferio
25 Anniversary
I have Schraeders on the cars, the UO-8, and the wheelbarrow, prestas on all of the other bikes, including the mountain bikes.
advantage presta: 1) higher hand pump pressure; 2) smaller hole in rim; 3) looks right on a road racing bike with skinny tires;
advantage Schraeder: 1) may hold air pressure slightly longer; 2) no external stem fitting to bend; 3) nicely proportioned for a car or truck.
John E is offline
Reply
Beverly's Avatar
Senior Member ??
Bikes: 2007 Trek Madone 5.0 WSD - 2007 Trek 4300 WSD - 2008 Trek 520 - 2014 Catrike Trail
The pump made a big difference for me. I ripped several tubes at the stem with my original floor pump. After buying a new one I haven't had that problem.
Enjoy the little things in life, for one day you may look back and realize they were the big things.
-- Antonio Smith
Beverly is offline
Reply
Old 12-03-07 | 07:29 AM
DnvrFox's Avatar
Pump?
You are supposed to use a PUMP?
No wonder my lips are hurting so much. It does build up your lungs, though!
DnvrFox is offline
Reply
Old 12-03-07 | 08:44 AM
20 Anniversary
Bikes: Giant OCR2, Motobecane Fantom Trail, Specialized Hard Rock, Giant Nutra
I prefer Schrader. I'm a klutz and frequently when I flat the adrenaline is pumping, and I would end up ripping the darn presta off. I don't have that problem with Schrader, plus I can get them at Walmart,harware stores, or drug stores and if necessary, I could temporarily put in a presta. Try to temporarily put a Schrader in a presta hole.
ad6mj is offline
Reply
Old 12-03-07 | 08:51 AM
Beverly's Avatar
Senior Member ??
That's a nice looking yellow pump but I prefer mine
File Type: jpg
-- Antonio Smith
Beverly is offline
Reply
Old 12-03-07 | 09:06 AM
John E's Avatar
feros ferio
25 Anniversary
Originally Posted by DnvrFox
Pump?
I have heard of folks starting a brand-new folded innertube using mouth-to-mouth resuscitation, because it can be hard to pump "from scratch."
John E is offline
Reply
Old 12-03-07 | 10:01 AM
Trsnrtr's Avatar
Super Modest
20 Anniversary
Community Builder
Community Influencer
Bikes: Trek Domane+x2, Trek Emonda
I must admit, I'm confused, too. I've been using Prestas for 26 years and don't see the problem here.
“Train hard until your legs are tanned, then keep going until the shape arrives.” -Jolanda Neff
Trsnrtr is offline
Reply
Old 12-03-07 | 10:03 AM
steel lover
Bikes: Bianchi Alloro, Miyata 710, Fuji Espree Fixie convert
I have an adapter that came with my pump which converts presta to shrader.
Presta for hand pump (cause it's convertible), and shrader adapter used so I can be ultra lazy and use my cigarette lighter powered compressor to easily get to 115
chevy42083 is offline
Reply
Old 12-03-07 | 10:04 AM
howsteepisit's Avatar
20 Anniversary
Bikes: Lynskey Meraki 12 speed Di2 Ultegra and canyon Grizl AL 7
I like 'em. Pump head stays on nice, the screw down cap keeps dirt and dust out. Been using them for over 30 years
howsteepisit is offline
Reply
Old 12-03-07 | 10:18 AM
I'm so used to presta that I find the periodic inflation of the tires on my automobile (schrader) to be a rather strange way to put air into a tire.
BSLeVan is offline
Reply
Old 12-03-07 | 10:25 AM
alicestrong's Avatar
Pedal pusher...
Bikes: I've got a bunch...
I prefer Prestas.
Are you sure that you are using the correct pump? It must have a head on it for Presta style valves...
May you live long, live strong, and live happy!
alicestrong is offline
Reply
