Internal Gears on Dropped-bar Bikes?
Old 02-27-08, 09:49 AM
Pants are for suckaz
HandsomeRyan's Avatar
Bikes: Hardtail MTB, Fixed gear, and Commuter bike
Is there such a thing as a dropped bar bicycle with a 7, 8, or 9 speed internal geared rear hub? I know the shifters that many internal gear hubs use are not really compatable with dropped bars but I feel certain I'm not the only one who thinks that an internal hub could add the lower maintainance of a single speed with the hill-climbing advantages of multiple gears.
♣ If such a bike exists in nature can someone point me in the correct direction to find one.
♣ If such a bike does not currently exist, are there reasons (other than incompatability of the shifters on the handlebars) that I'm missing?
Thanks!
HandsomeRyan is offline
Old 02-27-08, 09:56 AM
Needing more power Scotty
riddei's Avatar
Bikes: 2006 Trek T-80 (commuter) 1982 Bianchi SS (classic 12 speed)
https://sheldonbrown.com/harris/bianc...os8/index.html
You have to travel to Massachusetts, but I see from your signature that you know about Sheldon...
riddei is offline
Old 02-27-08, 10:44 AM
Originally Posted by riddei
...You have to travel to Massachusetts...
Perfect! Thanks!
I should have known that Sheldon was the man on this one. Mmmmmmm... Steel frame-a-licious.
I'll have to call Harris and see what those sell for. (Then I have to convince my wife that we need to drive to MA to buy a bike)
Old 02-27-08, 11:08 AM
POWERCRANK addict
markhr's Avatar
multiple rohloff equipped drop bar bikes
https://www.rohloff.de/en/info/bikesearch/index.html
These guys make two piece drop bars so you don't have to do either drop or stem mounts. - https://www.noell-fahrradbau.de/renn.htm
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
markhr is offline
Old 02-27-08, 11:32 AM
Membership Not Required
wahoonc's Avatar
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times in 14 Posts
Here is one from A.N.T. with a Rolhoff hub, but I see no reason it couldn't be built with something type of hub. Also some one on the forum built up and orange bike (Schwinn IIRC) with a Nexus 8, generator hub, and drop bars as their daily do it bike.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"
_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"
_krazygluon
wahoonc is offline
Old 02-27-08, 11:43 AM
SweetLou's Avatar
What is a two piece drop bar?
SweetLou is offline
Old 02-27-08, 01:20 PM
POWERCRANK addict
markhr's Avatar
Exactly that - it splits near the stem so you can slide the twist shifter on (or any other things on that wouldn't normally slide on over the drops). In my opinion a much better solution than either putting the twist shifter on the drops or a stub on stem.
markhr is offline
Old 02-27-08, 01:28 PM
Bolo Grubb's Avatar
Bikes: 1984 Trek 720 with a Nexus hub, 2016 Cannondale Synapse
Quoted: 35 Post(s)
Liked 17 Times in 10 Posts
Old Trek with Nexus 8
I rebuilt an old trek 720 tour bike with one. I now use it every day for commuting, love it
Bolo Grubb is offline
Old 02-27-08, 01:50 PM
riddei's Avatar
Originally Posted by HandsomeRyan
Perfect! Thanks!
Let us know what you find out. I'm sure there is curiosity... (me for one).
riddei is offline
Old 02-27-08, 02:19 PM
Perineal Pressurized
dobber's Avatar
Perfect! Thanks!
I'd find myself a good old road frame with horizontal drops and have a wheel built up.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
dobber is offline
Old 02-27-08, 02:37 PM
Thanks for all the replies. I emailed Harris about the Jos8 but I have not heard back yet. I doubt I can convince the wife that we need to drive to MA to buy a bike but I'm considering a similar conversion on another SS bike. Raleigh Rush Hour imediatly popped into my mind, but I'm sure there are others that would make suitable canidates.
Bolo- Sweet ride. Is the grip shifter mounted on the drop intuitive to use?
Old 02-27-08, 03:20 PM
SweetLou's Avatar
So, this two piece bar has the outside diameter of a flat bar? I guess it does since the shifter is on it.
SweetLou is offline
Old 02-27-08, 04:17 PM
Uber Goober
StephenH's Avatar
Quoted: 190 Post(s)
Liked 41 Times in 32 Posts
I ride a single-speed cruiser with coaster brake. I've noticed that normal multi-speed bikes are wider where the axle is than my cruiser. Makes sense, you've got to fit that pile of gears in. But I don't know if this causes any problems when you go sticking hub A in frame B. Something to check on at least.
StephenH is offline
Old 02-27-08, 07:08 PM
wahoonc's Avatar
Quoted: 70 Post(s)
Here is the one I remembered it was just posted on another thread. Maybe PM the member and ask for the specifics.
Aaron
_Nicodemus
_krazygluon
wahoonc is offline
Old 02-27-08, 07:40 PM
SweetLou's Avatar
That is not a production bike. He used the Hubbub adapter to get the shifter on the drop bars.
SweetLou is offline
Old 02-27-08, 08:21 PM
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times in 20 Posts
If the $200 walmart bikes can have gripshifters next to the stem on road drops, you can too.
operator is offline
Old 02-27-08, 09:15 PM
SweetLou's Avatar
Will those shifters work with an internal geared hub?
SweetLou is offline
Old 02-27-08, 09:24 PM
Bikes: canondale silk trail--92 schwinn criss cross--sun atlas x type--fugi odessa--2018 trek domane ALR5 disc
Quoted: 47 Post(s)
Been waiting and hoping shimano and/or sram would get there head out of their rectum and build us an OEM version of a normal roadbar shifter for gearhub use. But I doubt it will happen anytime soon.
On the other hand these guys are supposed to have a product ready or soon to be ready. https://jtekengineering.com/index.html Last I heard the prototype was made and undergoing testing. Give Jay a shout and report back.
If its like their other products it will work well and be inexpensive.
carlton is offline
Old 02-27-08, 09:32 PM
Quoted: 47 Post(s)
Aaron
Yes, but unfortunately the twist shifter is mounted on the stem.
carlton is offline
Old 02-27-08, 09:52 PM
Quoted: 47 Post(s)
Do you know if these are the same bars that used to be listed on SJS cycles site? I can't find them now used to have them bookmarked. The only problem I saw with them was that they were still mountain bike bar size all the way to the end of the drops. Kind of skinny and not as comfy as a normal road bar. I also envision a brake cable routing problem if the cables are routed under bar tape unless the bars are now grooved.
carlton is offline
Old 02-27-08, 10:42 PM
Bolo Grubb's Avatar
Quoted: 35 Post(s)
Very intuitive to use. I don't even think about it now, it is just as natural as riding my other road bike with brifters. I am really liking my Trek with hub and find myself wanting to ride it more. I even make up excuses to run errands on it.
Old 02-27-08, 11:22 PM
POWERCRANK addict
markhr's Avatar
Sorry I don't know those bars you refer to on the SJS site. Do you have a picture saved?
Please explain why you feel the cable routing would be a problem? The brake cable on the same side as the twist shifter could be routed in almost any direction surely?
markhr is offline
Old 02-28-08, 10:55 AM
cab horn
Quoted: 42 Post(s)
Not those exact shifters that come on those bikes. But gripshifters that work with internal hubs. Yes.
operator is offline
Old 02-28-08, 11:03 AM
SweetLou's Avatar
But the only gripshifters I know that work with internal hubs don't fit drop bars.
SweetLou is offline
Old 02-28-08, 11:20 AM
POWERCRANK addict
markhr's Avatar
as I pointed out before, twist shifters will fit the noell fahrradbau drop handlebars
markhr is offline
