Wire bead vs kevlar bead - really worth the price ?
I want to pick up a set of tires for cyclo cross this weekend. I can either order a set of wire bead conti cross tires for 19 each or get them right now at the lbs - but kevlar for 39 each. Other than a litte weight difference, is double the price worth it for kevlar bead?
well if they ship you the wire bead tires, most likely they will end up folding the tire when they ship it to you, kinking the bead. i always wondered how they ship wire bead tires to LBSes.
One less car
Bikes: '08 Soma Groove (commuter/long distance tourer), '97 Lemond Zurich (road commuter/tourer),'01 Seven Axiom Ti, '03 Look KG381i, '01 Santa Cruz Superlite X
I ordered some wire beaded Avocet Cross II Ks and they were wrapped in a figure-8 pattern with a rubber band...
Probably not worth the extra money just for the Kevlar bead, however a kevlar belt might be worth it for the puncture resistance...
Jay
Jay
Bikes: Old Hard Rock, New Cannondale R400
Since the bead is inside the rim, I don't think Kevlar makes a difference as to how durable it is, does it?
The Kevlar bead should only buy you less weight and greater portability (they are called folding tires for a reason).
- Jeff
- Jeff
Mr. Nikos...
In a word, yes! Wired tires are in most instances a pain in the butt to install....especially when you're out on the road fixing a flat and just discovered you've just pinched a new tube while trying to fight that last bit of bead over the rim.
Kevlar beads are ten times easier to install....often times using only my fingers to install, depending on tire/rim combo. If you can afford them, go for the kevlars...
George
George
A look in the ubiquitous Performance catalog will show that some companies manufacture the 'same' tire with option for wire or kevlar beads. Price differences are $3-6 between, with kevlar more. Continental, Specialized are
some companies that do this. The LBS price may not be out of line with the LBS but is not typical of the spread the manufacturers put on their tires with just a bead difference. Wire beads are significantly harder to mount and remove and are foldable, but with difficulty. Once you try kevlar beads you never go back, unless $6 difference is crucial. For pix about folding a wire bead tire go to https://home.bellsouth.net/p/pwp-sch1943/
Steve
Steve
The one advantage I can think of for 'cross is that often a kevlar-beaded tire can be mounted/unmounted with your bare hands. If you flat during a race this might be a benefit, I dunno.
Other than that, folding tires are useful as spares on tours.
The kevlar-bedad tires I've used have had relatively soft sidewalls; when they were also kevlar-belted the belt was only under the tread, not the sidewalls. I wouldn't have given much for their resistance to sidewall damage. These were touring tires, though; presumably a 'cross tire would be more robust.
RichC
RichC
Training: 2002 Fuji Roubaix Pro (105 triple)
Commuting/Daytripping: 2001 Airborne Carpe Diem (Ultegra/XTR, touring wheels)
Commuting/Touring: 2000 Novara Randonee (Sora/Tiagra/LX, fenders, lights)
The difference is not $3-6 on these tires, here's the only place that sells them on the web - cambria. Scroll down to conti cross country - its $19 for wire and 39 for kevlar
https://cambriabike.com/tires/knobby.htm
RichC
[QUOTE=nikos]The difference is not $3-6 on these tires, here's the only place that sells them on the web - cambria. Scroll down to conti cross country - its $19 for wire and 39 for kevlar
https://cambriabike.com/tires/knobby.htm[/QUOTE/]
I stand somewhat corrected: haven't ordered tires for past three yrs and that
was what I recalled for road tires. Looked in several catalogs and web sites and there are not as many dual wire/kevlar beads as there were, or they are
not listed, typical price differentials are $12, with Conti 2000 Ultra having a
$9 difference in price. Wire bead tires seem to be ~100gr heavier than kevlar
bead equivalents. You seem to be stuck with the limited # of suppliers for your desired tire. I have been looking at Schwalbe Stelvios for my bent, the only
406 size with kevlar bead/belt, and the price difference wire to kevlar bead is
about $15-18 (28 -> 42-5). It takes about 20min to wrestle wire beads on the bent rims. Steve
JRA...
Bikes: trek 520 & 736, DeRosa Professional, Fuji Professional, Raleigh International 3-speed, Saronni (any info people?), Humber 3-speed, Raleigh Sports, Carlton Grand Prix coming soon!
I've found the only theoretical adavandtage to kevlar beads is the weight, and maybe traveling with them. They tend to seat worse on initial mounting. In terms of shipping, kevlar and wire beaded tires are often shipped the same/similar (ie, wire beads are folded as well), which makes me wonder if they truly fold better. In terms of punture resistance, I question the effectiveness of kevlar belts versus a tire liner, which is much more economical in the long run.
Summary, unless you're racing or they're the only option for a tire you like, don't bother with them.
Kevlar tyres are worth the extra money. Apart from being easier to mount and foldable, the kevlar gives the tyre an amazing amount of puncture resistance. I pulled a kevlar tyre off my bike and picked out 20+ pieces of small glass from the outer rubber layer and not one piece had penetrated the kevlar beading. Expensive but worth it.
CHEERS.
Mark
CHEERS.
Mark
BTW, looking at Cambria's site, I notice that there are other tires with kevlar vs wire beads that only have a $6-$7 difference (eg., Continental Grand Prix ATB), but the IRCs further down the Knobby page show a $12 dollar difference. Maybe there is something else about the tires. Or maybe it is a marketing/pricing issue with Continental. Could be worth looking at another brand. After all, Continentals are good (I ride a pair of Town and Country tires to work), but they are not known as the most economical alternative.
- Jeff
One less car
Does a Kevlar bead necessarily mean a Kevlar belt?
The bead has no affect on the belt, whether it has an extra Kevlar lining or not is not dependent on the bead material.
Jay
Super Biker
Bikes: 2014 Curtlo, 2006 Serotta Coeur d’Acier, 2005 Independent Fabrication Steel Delux, 2003 Surly 1x1, 2003 Surly Cross Check, 1986 Schwin Worldsport SS commuter, 1980's Mongoose Supergoose
Get the foldable tire if you can afford it. $20 more does sound like a big price difference. Typically foldables are between 5 and 10 dolars more the wire beads.
Pros of foldable:
Cons of foldable:
All and all foldables are worth the money, especially if you're looking for performance.
Pros of foldable:
Cons of foldable:
Bikes: '70s Puch sport tourer, '90 Peugeot Success.
If i'm not mistaken, Contis, Michis, & some others are still made in Europe, which accounts for the higher prices over items made in countries without labor laws or environmental standards, such as China.
RichC
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Bikes: Raleigh, Benotto, Schwinn, Trek
Bikes: 2012 Trek Madone 6.2
Originally Posted by Don Cook
NO. If the tyre bead material is the only difference, not worth it. And on a cyclo cross event? Who cares about 10-20 grams (at the most) of extra weight.
So double the price for foldable portable tires....wow
