pedals for a clyde?
pedals for a clyde?
I am getting my first road bike, and needing some advice on which pedals to get. I am 6'4'' and weigh about 240lbs.
Quoted: 765 Post(s)
Liked 1,735 Times
pedals are like saddles. It all personal preference, you should not have any issues with road or mtb pedals though.
"Fred"--is that bad?
Bikes: Felt f85 (11); Trek 7.3 FX (07); Schwinn Super Sport (86); Specialized Rockhopper (87)
I have Shimano M324's. I like them alot--SPD clips on one side and regular platforms on the other. I can ride in regular shoes should I decide that would be the thing to do. Pretty strong--I got them when I was about 265 and have had no trouble with them.
They run about $75 at REI and other places.
Quoted: 765 Post(s)
Liked 1,735 Times
I got a set of the M324 for my hybrid and they are nice. Found on ebay for $40.00
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
I would stay away from the Titanium spindled pedals.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Bikes: MTB,Road,Tri
I am an inch shorter than you and maybe 15 pounds lighter on a light day.
I have the Ultegra PD-6620 SPD-SL Pedals on my Road Bike and Tri Bike, and I have the PD-M324, which are SPD pedals on my "Hardroad" which is my Hardrock with 700C rims.
I prefer the m324s for general bombing around town, or commuting, but if I'm going to lycra it up on the road or, god forbid, race, then I'd really recommend the wider platform and stability of the SPD-SL pedals. You don't have to spend up on Ultegra, you can also get 105 level pedals.
If you want to walk any distance in the shoes, then SPD is the go.
Pants are for suckaz
Bikes: Hardtail MTB, Fixed gear, and Commuter bike
I only paid $25 (thanks Craigslist!) for my Shimano M324 pedals. I do love them! I ride in bike shoes 99.9% of the time but when friends want to go riding I can just ride my mountain bike and let them use my greenway bike without changing pedals or anything.
I run Shimano M545 pedals on my MTB and I have had them for almost a decade with no problems at all. They are heavy, but bomb-proof.
I've weighed as much as 270lbs on both sets of pedals without a problem.
Shimano M324's (they are platforms on one side SPD's on the other)
Shimano M545's (SPD on both sides)
Downtown Spanky Brown
Bikes: Motobecane Phantom Cross Pro Kona Lana'I
I like the M520 spd pedals. I don't have too many miles on them yet but I can assure you clipping in and out is pretty easy.
One caution: some pedals lock your feet in and don't allow any movement. I found out, rather quickly, that my knees simply could not tolerate this! As a result, I prefer a pedal with some "float".
My personal preference is for Crank Brothers pedals and a mountain bike shoe. The Crank Brothers pedals use a 2-bolt cleat that will fit any SPD-compatible shoe. I find that they're very easy to clip and unclip. The Acid and Mallet pedals have large paltforms and look like they could be used with or without clips. The pedals I use allow 6-degrees of float, which is just what my knees need!
Shimano makes two types of pedals: SPD and SPD-SL.
The SPD-SL is designed for road use; they look like a copy of the Look road pedals I used to use. The Look pedals were very comfortable, but the extra-large 3-bolt cleats make them difficult to walk in when you're off the bike. I always felt like I was skating on ice! Of course, I was using a slick-bottom road shoe that wasn't really designed for walking. Not sure if they make treaded shoes with an area big enough to accommodate a 3-bolt cleat or not. SPD-SL pedals can only be clipped into from one side. I found my Look pedals were very easy to get into, but I would occasionally have to flip the pedals around to get the clip side pointing up.
The SPD pedals were originally designed for mountain biking, IIRC. They use a smaller 2-bolt cleat and the pedals are generally smaller than SPD-SL. I haven't looked at SPD pedals recently, but they used to be of the variety that locked your foot in and didn't have any float. The advantage of using an SPD (or other 2-bolt cleat) is that the cleats are smaller, so the shoes can me designed with enough tread that walking is possible. I greatly prefer this style of shoe! Many SPD pedals have clips on both sides, so you don't have to worry (as much) about rotating the pedal into the correct orientation.
Bikes: 2006 Cannondale CAAD8
https://www.probikekit.com/display.php?code=M8003
If you want to save more money for $55 shipped there is this (currently out of stock though). Same thing just slightly heavier
https://www.probikekit.com/display.php?code=M1111
I Design Stuff
AiM SmAlL mIsS sMaLl
Bikes: 08 Spec. Rockhopper, 11 Spec. Crux, 04 Cervelo Soloist
shimano pd-540's on my allez and love them. plus were only like 40 bucks at my LBS new and everything elese they had was in the 100 range
2nd Century TBD
Bikes: Felt F75, Trek 7.2 FX
My Biking Blog: https://bikebeagle.blogspot.com
looking at 2 different pedals. first bike, so need some input. i guess my main issue is make sure i have good foot coverage on the pedal. i wear a size 15 shoe.
look keo carbon: on sale for 132 from 200 https://www.probikekit.com/display.php?code=A1468
dura ace: for 142 from 215 https://www.probikekit.com/display.php?code=D1103
would carbon pedals be stronger than the materials that comprise the other type of pedals?
also, how important is the weight of pedals, since they are moving parts?
does anyone else have big feet? i am interested in hearing about what they use?
it is tuff to go thru life with big feet...haha
Chubby super biker
I have huge feet, size 13.5 wides. I have a set of $20 Wellgo BMX pedals on my MTB that came from my Trek FX and, well, I love them. I tried some basic platforms with toe clips on my new LHT, and those aren't going to last long. Like.. tomorrow.
Anyway I've toyed with going clipless, and I'm not suave enough for that. Heck, today I managed a 0 mph fallover complete with road rash with toe clips! I just don't like the idea of having to "clip in" and "clip out", seems like being attached to the bike isn't a great idea. For some, heck yes, but not me .
I just wear a pair of North Face "trail runner" shoes that are great, and I may actually upgrade to a pair of Merrells this year. I'll see what I can get the finance committee to approve...
Destroyer of Wheels
The Almighty Clyde FAQ || Northeast Index
eTrex Vista References || Road Reference
It's the year of the enema!
Bikes: mid 80s Ross Centaur converted to Alfine 11 09 motobecane imortal force, 83 Ross Paragon,81 Schwinn LeTour Tourist, 91 Paramount, 93 GT converted to city bike
Which Pedals
Steer clear of the house brand (wellbilts)and probably the CF jobs.
Other than that,as many have said; it's a matter or preference.
I'm running a set of Shimano 515 roads that I've reconditioned. Now into my 8th year with em.
