Just a couple questions...
Just began my first fixie build up last week. It's an 80s Miyata frame (1024 I think). Ordered some Mavic CXP22's laced to Formula hubs earlier this week after reading about them on here. Anyways, the bottom bracket needs to be replaced and I was wondering if this bottom bracket: https://www.benscycle.net/index.php?m...roducts_id=656
would fit and also if it would fit these cranks: https://www.benscycle.net/index.php?m...roducts_id=528
or these: https://www.benscycle.net/index.php?m...oducts_id=3927
also if you guys had any suggestions on cranks/bottom brackets. Thanks a mill.
One skid from blown knees
Search for info on the frame you have to see what type of threading is used on the BB shell. Or, you can remove the current BB & get the info off of it.
I did a little bit of research and I guess all of those Asian manufactured bikes are the English ISO threading so that should work. Thanks!
