New type of derailleur - new invention
Good morning,
I would like to present you the new derailleur controlled with an endless
cable. You can see it at https://www.derailleur.republika.pl. If you have
any questions or opinions please write them. I also wait for companies and
people who would like to invest their money in developing and manufacturing
my derailleur.
Regards,
Wladyslaw Hura
www : https://www.derailleur.republika.pl
e-mail: derailleur@op.pl
my derailleur.
Regards,
Wladyslaw Hura
Über member!
Bikes: 2004 Albert Eisentraut
Not sure what problem they are trying to solve... Interesting tho.. However, in order to make sure you have no "free play" developing as the parts wear out you will have to spring load the derailleur to one side so it will squeeze out the "free play". So, if you need a spring to make sure the derailleur is always pulling against one side of the cable, why would you need the "return" cable?
I think it is a neat idea, but it doesn't really solve a problem.
DEADBEEF
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
I don't see how it's going to shift as smoothly as a derailleur with a parallelogram linkage that's set up so that the cage tracks closely to the cogs. One of the reason people use such a linkage is to maintain closeness of the cage to the cog throughout the full range of motion. This helps to make shifts smooth and crisp. By simply just sliding the cage sideways, you will have very laggy shifts in the medium and smaller cogs.
1999 K2 OzM
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
1999 K2 OzM
2001 Aegis Aro Svelte"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Yep, looks like an answer in search of a problem. Twice as much cable, housing, cable stops etc.
Bentbaggerlen
"When the spirits are low, when the day appears dark, when work becomes monotonous, when hope hardly seems worth having, just mount a bicycle and go out for a spin down the road, without thought on anything but the ride you are taking." - Arthur Conan Doyle
Bentbaggerlen
Interesting idea. Regardless if we think its a better design or not, its nice to see fresh ideas in the industry.
My suggestion: Contact Pacific, they seem to be on a buying spree...
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
From: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Too much there to go wrong. Two shifter cables?
Crank Crushing Redneck
Bikes: Bikes are environmentally damaging
Looks like a dangling target for lots of rocks to smack and destroy.
Sorry, but I see no significant reason to adopt this sytem over the current standard.
But it looks really cool anyway.
