Campy 8sp Exa Drive Lock Ring
Bikes: Pinarello
I'm building a new wheelset and have an 8 speed Exa Drive Cassette that I intend on using. I have the freewheel and the cassette but can not figure out what size lock ring I need. Can anyone help?
A 8 speed hub takes the old 26mm thread diameter, not the new 27mm. In each thread size there are two models, one for 11T cogs and another for 12/13.
I'm assuming that you are using an old 8 speed hub?
https://branfordbike.com/articles/cas...-cogs-pg60.htm
https://branfordbike.com/product-list...freewheels-62/
Bikes: Pinarello
DaveSSS: Thanks for your reply. I have an early to mid 90s 8speed record hub. So, from you message, I assume that I need a 26mm thread, 11T lock ring (I am using 11-21 cogs).
Thanks for your help.
