performance aluminum frame headset question
i've been futilely trying to contact performance to get this infromation to no avail. does anyone know what type of headset this frame takes? would any 1 1/8" threadless work? a la something like this?
https://www.performancebike.com/bikes...00_20000_64502
thanks in advance
thanks in advance
Quoted: 5787 Post(s)
Liked 2,580 Times
Looking at the picture and reading between the lines, where it doesn't mention integrated or hidden headset, I'd say it's a conventional 1-1/8" pressed in headset. Threaded or threadless depends on the fork, and stem used. Either way, these are highly standardized and all the same dimensions, so feel free to buy the headset of your choice.
You'll need a few tools to press on the fork crown, and frame cups.
Enjoy the new wheels when you're done.
FB
Chain-L site
FB
Chain-L site
Liked 2,580 Times
No, no, no, no....
Quite the opposite, you need any conventional press fit 1-1/8" headset.
An integrated headset is specifically what you cannot use, which is just as well because these are not as standardized and you'd have go back to the company and find out which you need.
FB
Chain-L site
FB
Chain-L site
okay, gotcha... find a non integrated/hidden headset for 1 1/8" headtube. now another question, i have a fork with a carbon steerer...
what exactly do i need to get this working aside from the headset (i assume a compression plug)
Liked 2,580 Times
Yes, you'll need a compression plug, unless the fork comes with one. You'll heed a headset press, and fork crown setter to seat the crown race and headset cups. These are pricey and not used much, so you might be better off letting the LBS do that part of the job, or finding a buddy who already has the tools.
You'll probably need need to cut the steerer down, so a fine blade hacksaw 32-48tpi, or an abrasive blade like those used for ceramic. You can use 2 hose clamps to make a guide for a straight cut, and some emory on a block to smooth the top when you're done. You should also seal the cut end with some touch up paint, or nail polish.
That covers the essentials, though you might also want extra spacers besides the few that usually come with the headset.
FB
Chain-L site
FB
Chain-L site
as far as the steerer, it's already been cut to 200 mm so i doubt i'll need many spacers (zero stack baby!). sounds like i'm 90% solid on what i need. thanks again.
gus6464
Bicycle Mechanics
10
08-09-20 11:31 AM
