Swapping to track ends, gimme info, PLEASE!!
I'm looking to swap my dropouts for track ends. I have a old miyata, I like the frame, the tripple butted cro moly is great for dallas' crappy streets. Anyway, I contacted a local frame builder who quoted me $250 which includes alignment and paint matching, is that a high price? Wouldn't any welder do just as good a job, minus the paint, for a much cheaper price? Or is this really, really, really a job best left to a frame builder? What do I risk going through an average welder?
Elitest Murray Owner
Bikes: 1972 Columbia Tourist Expert III, Columbia Roadster
Well considering that the frame was brazed together, welding the track ends would be kind of dumb. So no, a welder shouldn't do it, beside they won't have what they need to get the ends properly aligned.
Why don't you just look for an actual track frame if you have to have track ends?
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
For $250 you can put together a decent conversion or you can buy a petty decent SS build from BD with a couple of bucks more........ what's wrong with horizontal dropouts?
I wouldn't suggest swapping the ends on a old bike unless it has lots of sentimental value to you.... as time passes older bikes are more prone to wielding/ frame failures during rides (I learned my lesson from my peugeot commuter which I recently had repaired (seat stay came off; was my grandpa's who is gone now) and retired) not to mention hidden rust under paint... you might as well have that frame builder of yours reinforce the wields or brazing if you're going to go through with your plans...
Bikes: Panasonic NJS Keirin x2, Level Professional, Bianchi CUSS, GT Pulse
Are you taking the frame to David at SW Frameworks?
I'd say buy a dedicated track/fixed gear frame and save yourself the trouble.
master of bottom licks
Quoted: 111 Post(s)
That depends... how much money do you have and is having track ends really that important to you? Also, a welder is a guy who can join metal... it doesn't mean he knows how to modify a bicycle frame so don't expect a service from someone not really qualified to provide it. I mean, you wouldn't go to your proctologist and ask him to fill a cavity, would you?
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
Miyatas are really nice frames, especially if you have one with triple butted tubes and horizontal drop outs.
Why would you want to use inferior track ends?
With track ends, the wheel is harder to remove, especially if you have fenders installed and don't offer any special ability to hold the wheel in place over horizontals.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Ride for Life
if it's a really nice frame and you really like it, don't listen to what everyone is saying about spending the $250 on a track frame. $250 isn't going to get you a triple-butted steel anything.
i would recommend calling other frame builders, even if they aren't in your area, and get price quotes from them. that'll give you a better idea.
Liked 5 Times
I really hope the OP is not messing with a 1000 or Team, as those were really nice frames the way they are.
If it's a 6xx, 7xx or 9xx, might as well knock yourself out with the modification, since they cost about $150.
If you look around, you should be able to find track miyatas as well.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
FWIW, the OP originally posted that it's a Miyata 312, and came with 27" wheels. When changing to 700c wheels, the OP asked if the hubs would be wider. So, maybe the best advice might be to not attempt to do anything.
Liked 5 Times
shows me for not reading through.
312 came with triple butted? I always thought 312 was double butted...
oh well, total waste of money, but knock yourself out with the modifications.
and post pics when it's done.
I step on puppies
I've flux-cored some track ends on an old junker road bike for fun. It holds up fine, but I wouldn't do it again.
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Why do you want track ends? Horizontal are better in pretty much every way, except for hipster aesthetics.
Here comes the noob with the really stupid question: why are horizontal dropouts better? Is it because of what AEO said? I do have track ends (err, a track frame so that means track ends, right?) and don't have fenders and with a 15mm box-end I'm able to adjust my chain just fine. Or... am I making some major mistake that's going to throw my wheel way out of true...?
Veteran Racer
Liked 764 Times
Veteran Racer
Liked 764 Times
This is correct if you are constantly changing gearing and using a rear brake. I do change gearing on my FG, but do not use a rear brake. My SS has a rear brake, but I don't change gearing. I think this might become an issue if you had a flip/flop fixed/free with different cog sizes, and had to constantly re-adjust the rear brake. Of course, this is the reason why horizontal dropouts are not truly horizontal, but slanted such that the distance from the rear wheel rim to the brake bridge doesn't change as the wheel is moved in the dropout.
Hmmmm, I think I'll keep it the way it is. Just for the record it's not a street cred thing, this bike has medium sized horizontals not the long ones which work so well for adjusting. Plus it's a great frame, very comfy! And while I could get a track frame, for the money, it would not be as nice as this frame is. Thanks for all the replies guys.
spinachface
Track Cycling: Velodrome Racing and Training Area
21
10-06-14 07:06 PM
