Setting the studs
Setting the studs
Just got a new set of Nokian studded tires, was going to try and ride my 30 miles on pavement to set the studs, never got around to it. Now the snow is falling: can I get away with riding on plowed streets to set the studs? Does it have to be bare pavement?
Also, the tires are 42 mm 700c, can I get away with using 28mm - 42mm tubes? LBS doesn't have anything bigger.
Thank you very much for any thoughts or tips you may have.
Formerly Known as Newbie
I didn't follow the protocol with my Nokians (W106s), no problems. I'd wager a guess plowed pavement will be ok.
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
And yes, I think your tubes will work. You're within their supposed range.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
I've used 28-32 tubes on my 35mm W106s for years now with no problems. I don't know if I'd go to 42, however. Try it and see. The worst thing that could happen is you'll get a flat.
As for "setting the studs", back in the day when I used to stud car tires, we'd tell the customers the same thing. Basically, it was to keep the customer from spinning the wheels or doing cowboy stuff until after the rubber lube wore away. (The studs and holes have to be lubricated to insert the studs.) No cowboy stuff for the first few miles and you'll be fine, no matter what surface you ride on.
Bikes: Genesis Equlibrium, Salsa Vaya, Claud Butler Urban 100
After your first couple of rides, examine your tyres to check if any studs are escaping. If they are, you should push them back in with a pair of pliers.
Bikes: 2015 Niner RLT9 / 2006 Felt F5C / 2012 Stumpjumper
The tubes can stretch, you should be fine. It was a common trend a few years ago to run 16" tubes in 20" BMX wheels because they were lighter.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
that they will become brittle faster. Take two identical
rubber bands. Place one of them on a book or something
else to stretch it out to close to the limits of its elastic
capacity. Leave the two of them on a corner of your
bookshelf or somewhere out of the way for a couple
of months.
The one around the book is your inner tube in the over
sized tire. You're good for quite a while, but were I you,
I'd be searching the internet for some tubes of the
correct dimensions.
Respectfully,
Mike Larmer
6 miles per taco, w00t!
I tend to use undersized tubes myself. Seems to work fine. They are lighter too
I find that i will puncture the tube before the tube will get old (and brittle) enough to fail anyway.
Yes, I figured it would be better to be safe than sorry, and got some Quality 35mm - 45 mm tubes. Not really keen on changing a tire with temps in the teens and twenties. Thanks for the tip.
