Wheel Advice
Bikes: Bianchi Via Narone, Fuji Touring, Fuji Sportif, Giant Escape
Wheel Advice
I have a Bianchi Via Narone 7 Sora Compact. I absolutely love this bike. The problem is, since I bought it over the summer, I have put about 1,300 miles on it and have been through about 10 broken or bent rear spokes. I am still riding on the stock wheels that came with the bike, Jalco DRX2000's with 28 spokes. I weigh in at about 235lbs. Should I look at moving up to a 32 spoke rear wheel? Anybody have an opinion on the Shimano 105/DT Swiss R450 Rear Clincher Wheel. It is reasonably priced and money is a factor right now.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
what year is the bike and did you buy it new? if it is a new bike your dealer should be looking at getting you new wheels.
Sugar "Kane" Kowalczyk
Bikes: Trek, Cannondale Tandem, Surly LHT
Perhaps a little more info might help. Where are they breaking? Did you get them retensioned after a couple hundred miles? Are they butted?
Often, a new machine built wheel comes in quite a bit under or unevenly tensioned. This can make for oscillation cycles at the hub/spoke intersection that can fatigue the spoke. Butted spokes tend to hold this tension more like a rubber band as compared to a straight, stiff shaft. Good 28 spoke wheels should hold up to your weight, provided you are not off-roading or hot dogging with your bike. I'd say you either have poor quality spokes, or they were improperly tensioned. That means under/over/or uneven tensioning. My 2 pennys.
18 more broken spokes and you will have a completely hand built wheel.
Just my opinion but unless you are riding on really good roads and are a smooth rider, 28 spokes is too few for a rear wheel for someone at your weight. I recommend a 32 spoke 3-cross rear wheel. In the mean time I would suggest detensioning your current wheel and making sure the heads of the spokes are set then retentions and true the wheel. You may find that you get more mileage and less broken spokes when doing this. There are resources that explain the process of setting the spoke heads at the hub; some call for using a punch and mallet and other processes call for bending the spokes slightly at the elbow to give them more of the proper angle to the rim. Search and read up on these issues.
-j
-j
Yes, more spokes; I never went below 36h on rear wheel when I weighed 235. Shimano 105 is a good hub but I can't speak to the DTswiss rim.
Quoted: 5791 Post(s)
Liked 2,581 Times
Bikes are basically engineered around rider weights of less than 200#s. I'm not saying that you're too heavy, since there's lots of safety margin, but that you should exercise some judgment whenever considering components intended for competition, or where saving weight was a design consideration.
For some perspective, not that long ago 36 spoke wheels were the norm, with the British prefering 40rear/32 front. Over the years (with no significant improvement in the technology or materials, 32 spokes become the norm. In all fairness that's generally adequate, and I find that my 32 spoke wheels hold up about as well as my 36 spoke wheels used to. (I weigh 190#s)
Given your weight, I'd definitely go with a set of properly built 32 spoke wheels (14g DB stainless spokes, decent hub, medium weight double wall rim). I'm not saying that well built 28 spoke wheels won't hold up, but that given that you weigh more than 20% more than the high range of design weight, buying yourself some extra margin of strength can't hurt.
FB
Chain-L site
FB
Chain-L site
Liked 7 Times
I think you would have less trouble with a 36 spoke rear wheel. It would hold up better and stay true longer.
Liked 2,581 Times
Discounting the availability issue I'm with you 100%, at his weight more spoke strength is better.
Another option for the OP if buying hand built wheels is 14/13g single butted spokes for the right flange and 14/15/14 or 14/16/14 butted spokes for the left. This will allow more balanced tension in the dished wheel while putting more material to the task.
FB
Chain-L site
FB
Chain-L site
Now that you have found the shortcomings of the factory wheels ,
A hand built wheel will be an improvement..
when the spoke tension has to be raised on the right side of the wheel to cram in all those sprockets
the strength is compromised.. consider something like DT alpine, spokes on the right, 3 gages.
hook a 13, center a 15 and a 14 where the nipple threads are.
a 14 15 14 is probably fine for the left side..
36r/32f pair is worth a consideration skinny race like tires like 23mm would use a thinner rim
a wider tire say a 32 will work best on a wider rim, but I don't know the preferences clearances
of the frame of the bike and rider.
and if the OP does not work on their own bike, the wheel truing/tensioning
is part of maintenance, schedule it to be checked occasionally..
You're right, and I would have suggested 36h wheels, but they're rarer in prebuilt wheels, and the availability of rims is rapidly declining, so if he went to 36h the OP could be facing fewer choices down the road when time came to rebuild.
Liked 7 Times
Another option for the OP if buying hand built wheels is 14/13g single butted spokes for the right flange and 14/15 or 14/16 dutted spokes for the left. This will allow more balanced tension in the dished wheel while putting more material to the task.
I would say its near impossible to find prebuilt 36h wheels; at least I haven't had any luck. Availability of 36h rims seems hit and miss. A year ago I had to wait a couple of months for 36h Mavics on back order. More recently, most sites I checked seemed to have them in stock. But, even so, they are getting harder to find.
If sourcing 36H rims was a concern, buy up a few now and be set for many, many years. How often is anyone going through rims after all?
Liked 7 Times
Some cheap 36H, cassette hub, rear wheel options: https://www.niagaracycle.com/advanced...+700c+cassette
Liked 7 Times
Which sort of proves my point. If you bought four 36H rims now (any investment of less than $100 for a budget rim like the Alex X101: https://www.niagaracycle.com/product_...oducts_id=1066), you'd be good for almost 30 years at that rate. If you used disc brakes or did most of your braking up front, you might get even better rim life.
I linked to the Alex X101 rim (available separately for under $20) in my post. An 8/9 speed cassette hub will accept a 10 speed cassette too.
Liked 2,581 Times
.... If within budget I would recommend DT Swiss Alpine triple butted 2.0 - 1.8 - 2.34 (14 - 15 - 13 gauge) spokes, assuming the hub spoke holes are big enough, or DT Competition double butted 2.0 - 1.8 - 2.0 spokes. I will not use a spoke that is smaller than 2.0 mm (14 gauge) at the hub flange.
FB
Chain-L site
FB
Chain-L site
Liked 7 Times
You and I are basically on the same page, but I'm a firm believer in using different gauges on right and left flanges of high dish wheels. In this regard it's the center section which is most of the length of the spoke that counts. That allows more equal strain (%elongation) of all the spokes despite the tension being lower on the left. The Op should decide on the right flange spokes first, then look for a lighter butted spoke for the left, though like you I won't go below 2.0 at the hub.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
Trust No One
My dear Mr. Hoffman:
Your problem seems to be a fairly common one these
days, based on my own limited experience with the
people who wander in to the Sacramento Bike Kitchen
for assistance.
I recently contributed about all I want to on the topic
on the Clydesdales forum here:
https://www.bikeforums.net/showthread...or-heavy-rider
when I made an unguarded remark about how maybe
28 spoke wheels were not such a good idea in
general and particularly in cases where the bike is
a little more loaded.
It really starts to get interesting around post #35.
While I do not believe that lower spoke wheels in and
of themselves will cause the downfall of Western civilization
and an end to life as we now know it, I'm not 100%
certain they are not a part of some vast conspiracy.
Anyway, read the thread if you get the time. Meanwhile
+1 to all the posts that have told you regarding 32 or even
better 36 spoke wheels (in the words of my grandmother),
that "it couldn't hoit".
Happy New Year,
Mike Larmer
for assistance.
Happy New Year,
Mike Larmer
Quoted: 1529 Post(s)
Liked 718 Times
IMO an OCR is worth a whole bunch of spokes.
Pretty sure a properly-built 28h OCR wheel would have a decent safety margin for a 235lb guy.
IME the most likely thing to kill a front rim is wear from braking, which isn't the case for a rear (although it might be for a nicely-specced OCR).
So I'd say the best way to brake is to use the rear as much as possible, saving the front for when more urgent deceleration is required.
I like the hub. I built up a 36 double butted spoked wheel with a Mavic Open Sport rim for a friend who was your weight and breaking nipples on a shimano 550 rear wheel. He has over 6000 miles on the wheel with no problems.
we be rollin'
If I bought a Shimano Tiagra rear hub and want to use an 8 speed cassette, would it be a cool idea to use DT Swiss Champion spokes on the right side and DT Swiss Competition spokes on the left side?
