Cartridge Bearings For Easton EA 90 - R4 Hub
Former Hoarder
I'm wondering what size cartridge bearings these wheels take as I want to replace both the front and rears.
I realize I could pop them out and measure them but then the wheels would be unusable until the new bearings arrived....which I would rather not do.
Anything unusual I should know about replacing the bearings or is it pretty straightforward?
Thanks for the help...
I'd knock them out and measure if I were you ..
standard bearing number may be on the seal, molded in.,
then you don't have to go further..
then, stick them back in and ride, till the replacements, show up.
Portland has industrial Bearing suppliers, and so it can be a 1 day project.
quicker than ordering online, and at a bike shop which may not stock them.
Former Hoarder
Former Hoarder
12-24 is a 6901 or 61901 and the 15-28 is a 6902 or a 61902. https://www.enduroforkseals.com/id138.html
6901 and 6902 are standard bearing numbers , I think Enduro Bearings come thru QBP
so easy to get via LBS
90% fill on the balls [I got some for my Bullseye Hubs, a while back]
and even a Phil Spec, essentially a submersible pump bearing,so has to be a good
carfreefamily
Classic & Vintage
9
01-27-19 03:51 PM
