Thinking about Getting a crankset
Hey, im new here i would like some help looking for a crankset that is compatible with the Dawes MTA. Yes i understand its cheap, but i still love it to death. So yeah the dawes comes with 3 piece cranks,a Euro Cartridge BB and i would like to switch over to the more common cranksets you see on fixed gears/single speeds. What would i have to look for in order to know that it will work?
Any help is appreciated
ohh well i guess i wasn't very clear i'm sorry. but the bike comes with bmx style cranks. i want to switch off to this type. https://www.businesscycles.com/graphics/tcr-sram.jpg
lol. That was an example. I would get them If i had the money. Now could i just buy any of these cranksets https://www.allcitycycles.com/product..._track_cranks/
https://store.citygrounds.com/store/p...ck-46t-130bcd/
https://store.citygrounds.com/store/p...t-Silver-Black
And Just remove my old crankarms and sprocket and put on the new ones?
Bikes: Mercier Kilo TT, Specialized Tarmac
Delusional Laserbrain
Bikes: 2008 Specialized Tricross, 1993 Giant Iguana rebuild w/ singlespeed drive train
S300 Courier's are kind of like budget Omniums if you want to keep it in the Sramily..
Goes to 11.
Bikes: 2015 Soma Double Cross
I need to see photos of the bottom bracket before I can make a recommendation. BMX bottom brackets come in all shapes and sizes. What's commonly known as "English" doesn't commonly go on BMX bikes.
Post a pic of your current crankset.
EDIT-By english i mean euro cartridge. made a Mistake.
Goes to 11.
That's not a BMX crank. It's just a really cheap 3-piece road crank. The bottom bracket is of a standard, "English" square-taper style. If you want to keep it cheap, remove the existing crank and bottom bracket and measure the spindle. Then find a crankset that requires the same spindle length. If you don't mind spending another 30 bucks, you can replace both the crank and bottom bracket. I'd recommend the latter since you'll be replacing that loose ball BB with a maintenance-free cartridge style, and you'll have a lot more options when choosing a crankset.
Great! But it says it comes with a euro cartridge BB. so is this the type of Bottom Bracket you are talking about? Or is it what you described a loose ball bearing one.
Goes to 11.
I can't say for certain that it is a loose ball BB, but in one of the photos there's clearly a BB lock ring on the non-drive side, which would indicate that it's of a much older style. I'd need a closer look at it to be sure.
So what type of bottom bracket would i get? I understand a cartridge English one, but specifically A model of bottom bracket. Would i just get one made for a english bb and with a square taper?
can i not get this https://www.performancebike.com/bikes..._20000__400184 and Attach a crankset of my choice depending on the spindle size i choose?
Your cog is slipping.
Way to confuse the kid, guys. The Dawes MTA takes a standard English-threaded BB.
Rust'y right though - unless you're buying a SRAM crankset with included GXP BB, you'll need to pick your cranks then buy BB with a the corresponding spindle length.
