Columbus Zona v. Columbus Life/Spirit
yesterday you said tom.
Bikes: Bianchi Pista 07, Dodici Veloce
Debating on which tubing to use for my next build. The frame is going to be lugged and is going to be used daily on the streets.
I keep reading that Life/Spirit is lighter and slightly stronger than Zona but is susceptible to dents because it uses tubing that has very thin walls. And we all know no one likes dents. I care more about durability than weight.
Also on another note, what is the difference between Life, Spirit, and Spirit Keirin? Is it just the weight?
Yes Spirit & Life are a bit stronger than Zona, thus they can be drawn thinner. Durability is dependent on who is doing the welding/brazing and what the rider does, but yes a thicker & stiffer tube is usually better in that regard.
If the frame is lugged, then you are probably stuck with the "spririt for lugs"; it's the only set with long enough butts.
As for the differences between the tube sets, weight is one, but so is tube diameter, wall thickness & butt lenghts. Never heard of Spirit Keirin.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
I'd go with the thicker downtube option within Zona, .8/.5, since that will add a little extra stiffness. Spirit for Lugs has nice long butts so that would be a good choice for the top tube. Mix and match.
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
Is Zona cro-mo or nivacrom?
Randomhead
Liked 3,698 Times
Zona is nivicrom. I haven't managed to dent my Spirit for Lugs bike at all. I'm guessing that the shaped Spirit might be easier to dent
epicbike101
Framebuilders
28
01-14-13 09:39 AM
