Shimano Track Hub on 128mm spacing
Bikes: Capo
I'm looking to convert an 80s frame with a 128mm rear spacing to a single speed and I want to use Shimano Track hubs. I can fill the gaps with spacers, but I want to know if the axle is long enough to tighten the nut onto it. Anyone have any idea if I'd have any problems with this setup? Thanks in advance.
Schwinn Magnet
The Shimano hubs that I have (7710) have short axles, they cannot be spaced beyond 120mm. Same for the newer Campy Record. I would guess same for all track racing specific hubs that use nuts. Hubs for street use usually have longer axles so they can be spaced out.
- dorinte
- dorinte
Schwinn Magnet
Here is a pic of a DA 7710 hub at 120mm spacing:
Note that there are no threads exposed beyond the axle nut.
- dorinte
- dorinte
Quoted: 5784 Post(s)
Liked 2,578 Times
Competition rules, as a safety measure, dictate that the axles cannot extend beyond the face of the track nuts, so good quality track axles are measured to be just long enough and no more. Lower end hubs made for today's Fixie crowd may offer more latitude, but you'd have to check each.
However, all is not lost, the thread is standard, and longer axles are available, so it's a simple of getting a new axle along with the spacers. If you measure carefully you can trim the axle to the exact length to end sub flush in your mounting bolts.
FB
Chain-L site
FB
Chain-L site
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
- dorinte
- dorinte
There's no such thing as 'track racing specific hubs'. A track hub is a track hub. Both of those hubs axles can be replaced with longer versions to space out to im guessing is actally 126. And not 128.
Dimension track hubs, formula track hubs. All are compatiblie with 120mm+ spacing.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
I never knew that Thanks!
Sugar "Kane" Kowalczyk
Bikes: Capo
Thanks folks. I appreciate all the help. I would assume that the Shimano axles are good quality, so is there a certain replacement axles that would be of similar quality?
Liked 2,578 Times
Wtf?
There absolutely are track racing specific hubs, namely those built specifically for competition and according to UCI rules.
Then there are Fixed Gear hubs, that are similar in most or all respects, but not necessarily in conformance to the UCI rules. At one time all track hubs were track hubs, but not today, where Fixie boom has spawned all sorts of variations of what I'd call Track Style hubs.
An analogy can be drawn to Kosher deli/restaurants. Kosher food is that prepared in strict accordance to various rules, and there are a number of kosher delis in New York. But there is a much larger number of delis with similar menus, but not, in fact, kosher, some even describing themselves as kosher style.
FB
Chain-L site
FB
Chain-L site
Liked 2,578 Times
I don't know either way whether Shimano offers a longer track axle, but others, including Wheels mfg. in Boulder CO, make quality longer replacements.
FB
Chain-L site
FB
Chain-L site
Quoted: 9 Post(s)
You could probably set the spacing and align the DO's as easily as obtaining and changing the axles. That would be my choice but maybe not yours- who knows.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
FBinNY:
Do you have the UCI Chapter and Section number that cover specific track hub dimension beyond the spacing?
Everywhere I look, the restrictions I see are in relation to mass start road wheels - most restrictions I find for track wheels are related to quick releases and disc front wheels and wheel size mismatch...
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Liked 2,578 Times
FBinNY:
=8-)
=8-)
At the time, QR hubs were likewise banned.
FB
Chain-L site
FB
Chain-L site
Quoted: 145 Post(s)
Liked 35 Times
Sounds to me then that it's not a UCI rule - but rather a local facility rule.
Long as the local controlling group publishes in advance and at registration - perfectly valid. Very common in local ASA softball tournament and leaques. Ran 'em for 13 years - mostly A, B and C class Men's fast pitch. Most common local rule changes and addendums to ASA rules were:
1. Out-of-play line. (2 of my 3 parks were very tiny and compact.)
2. Uniforms. They're expensive - folks playing locally are playing for fun and don't need the expense.
3. First base "run-by" safety rule and safety bag.
=8-)
=8-)
Disclaimer:
Disclaimer:
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
OK... we're drifting off course here (but that's normal). As FB pointed out above, longer solid axles are available from Wheels Mfg. and Shimano's older solid axles will work, too. Shimano's thread for rear axles (solid and QR) is 10 x 1mm.
Jeff Wills
Jeff Wills
Lakerat
Singlespeed & Fixed Gear
6
05-12-17 07:17 AM
mihlbach
23
05-06-17 08:59 PM
