problems w/ sugino75 cranks on steamroller
ok, so i got this steamroller(53cm seat tube) and a set of sugino 75 165mm cranks. i've matched it with the 75 sugino bottom brackets (109mm axle). Anyway, the drive side cranks looked a little too close to the chainstays (i think its the chainstay, or whatever stay it is) for comfort. Anyway, anyone else out there got this type of problem or is it just me? did i assemble the cranks too tight? here are some pictures. the second one is the one that's too close as you can see. It just grazes it a little, or just misses it sometimes.
left side.
right side(drive side).
left side.
Slow in traffic
Bikes: 2002 Bianchi Pista, Cannondale R1000
That's odd 'cause I run Sugino 75s on a 107mm (pretty sure it's 107) bottom bracket and my chainline is a little off in the other direction.
Bikes: GT Pulse Track, 93 Bridgestone XO-1 & 93 RB-1, Ritchey Swiss Cross, Ritchey Road Logic, Yoshi Konno/3Rensho Specialized Allez, Cannondale Slate, Cannondale SuperSix EVO/Disc and Cannondale Hooligan
Quoted: 39 Post(s)
Liked 144 Times
Originally Posted by dolface
have you tried turning the spindle the other way?
SuperstitiousHyperrealist
Bikes: unknown road conversion, half built Benotto track
After thinking about this a little more I think that the problem must be with the frame. Most track hubs should achiveve a 42 mm chainline and likewise a track crankset and its corresponding BB should do the same. Since the Steamroller is spaced 120mm in the rear(track spacing) the whole frame should be built to accept a setup with such a chainline, right?
hello
I'm running old Campy track cranks on my 53 Steamroller and I've got less than 10mm clearance. Since these frames are designed to accomodate fat tires, the chainstays are spaced a bit further apart near the BB.
Originally Posted by baxtefer
not all spindles are symmetrical.
(Grouchy)
are you sure you got the cups threaded into the frame all the way? the fixed cup might not be in, and the adjusting cup might be too far in. or your frame is probably misaligned. with steel, this is not such a huge issue, because you can just "cold set" it back to where it's supposed to be.
hey, its the guy whose steamroller doesnt look too well. im not so sure that its anything with the frame. if the stays are bent, wouldnt the left side be bent with it, cause they're connected with a brige, and the hubs and all. but the left side seems to have just enough space on it. anyway...at my inspection, just eyeing it, it seems to be true. im gonna, go to the lbs sometime tomorrow hopefully, but anymore comments are welcome.
Hey, here's a wild idea, you guys think that i pedal so hard, that i pull the whole chainstay with me on the right side? lol
oh..so...crusty..
Bikes: bianchi pista
alright, so i went to the lbs and right when the guy looked at it, he told me that i needed a spacer, so thats what i got. I did inquire whether it was a probmem with the alignment of the frame or not and he told me that fitting a spacer on it would be the quick and sure way of fixing the problem. It would have been too much to measure the alignment, taking out the parts, then putting it on a table and measure it and all. Frankly, i myself didnt really want to pay for all that, and putting a spacer on it did sounded like a pretty good idea. anyway, thats what i'm gonna settle with.
I also asked him if this problem ever occured (im sure that im not the only one with this setup before), and he told me that these things just happens sometimes.
thank you all for your comments though.
Cornucopia of Awesomeness
you could check the alignment yourself, using sheldon's string method.
https://www.sheldonbrown.com/frame-spacing.html
about 3/4 down the page
The fact of the matter is that your current setup should work.
hello
I remember now...
When I purchased my Steamroller off of Ebay a couple years back I did a quick 'eyeball' alignment check from all different angles, making sure everything was symetrical, and did notice my rear triangle a bit skewed to one side. I bent the area in question back into alignment. I can now see that this would cause one crankarm to be closer to one chainstay than the other.
the cranks arent old. i dont think so. the frame and cranks i got from ebay. the frame was used, but for everyone's info, i did get into a car accident with it. the sugino75 cranks werent on the bike when that happened. im pretty sure the cranks werent used. the description on it was that it was new, but installed because it came on a khs i think.
(Grouchy)
where did the LBS guy want you to put a spacer? i don't understand how a spacer on a road/track crankset would help alignment issues. i know that sort of thing definitely works on a BMX bike, but yeah, that doesn't make any sense to me.
you should've said that you got into an accident in the first place. if you got whacked, the frame is most likely not aligned, depending on where you got hit, how fast you were going, how fast the car was going, and which part of the bike took most of the force of the impact.
take it to the shop, have them use the ***-2 to check it, and proceed from there. cold-setting the frame back to where it should be will probably run about $20. if they want more than that, or you don't want to pay it, you can check back here, or sheldon brown's site for instructions on how to do it yourself.
to answer the guy's question (sorry, forgot your name), i believe you place the spacer between the cup and the frame. that seems to be the most logical place to fit it.
thanks for all your info guys
ps, if anyone else has this type of problem and want to ask me about it, email me at D_W_Guy@hotmail.com. also, those of you who have the same setup, 53cm steamroller (doesnt have to be 53cm) and sugino 75 track cranks, but dont have this problem, email me to and let me know. again, thanks all...
