Anyone have Panaracer Fire XC Pro 2.1" tires?
Could you do me a favor and measure the actual width of your tires? At the widest point, does it actually seem ot be 2.1", or is it narrower (or wider) than that? Thanks.
I couldn't car less.
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
Don't have that tire....or calipers.
2.10>on 26 rims fit most any mtb.
Why?
Te mortuo heres tibi sim?
Bikes: hardtail, squishy, fixed roadie, fixed crosser
Originally Posted by jeff williams
2.10 is measured tire hight. Not width, that depends on the design.
Why?
Why?
that is the width.
they sit about 45mm tall, and measure right about 2" at the widest part of the tread.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Time for a change.
From: 6 miles inland from the coast of Sussex, in the South East of England
Originally Posted by Cornish_Rdr_UK
I have panaracers, they're ok, nothing special though imo, pretty light, thats all they've got going for the them i reckon
On the tyre width, 2 sets on two different widths of rims. Funnily enough the two different widths of rim give two different widths of tyre. Differing by 3/16".
Originally Posted by scrublover
huh? what are you talking about with 2.10 being the height?
that is the width.
that is the width.
"Bicycle tire size is expressed as the wheel diameter by the tires widest width. Therefore 26x2.0 means that the tire is 26" in diameter and 2.0" wide. Maxxis also offers 16,” 20,” 24,” and 700c size tires in various disciplines."
https://www.maxxis.com/products/bicycle/faq.asp
How did I get mixed up? But the 2.25, 2.3, 2.5 nominal width are taller than 26 inches?
They sure lOOk taller. Maybe I can fit a 2.3 front.
The XC tires I like stop @ 2.1, currently my front (1.95 rear) I want to put 2.1 rear and 2.25-2.3 front but i've not bought the tire 'cause I thought it would be too tall, not wide. I have more width clearnce than hight.
Would a bike store return a tire that had been mounted and inflated,(not run) but didn't fit?
Yorkshire, UK
Bikes: 04 Marin Mount Vision, 04 Rock Lobster Tig Team SL
The fire xc's are sposed to be 2.1" but they look alot narrower in my eyes, more like a 1.95 maybe. They give ok traction but the width is really not what i was expecting im afraid.
XC Rider
Bikes: Santa Cruz Heckler
At the end of the day, if you have a bike to which you're only go and XC ride, then any Tyre over 2.1 is an overkill. It'll slow you down and drag. Most of the top XC Pro's run 1.8 & 1.95
It's just MY problem as I want a 2.25 dry dirt tire tread for my solid fork.
I have 1.95 rear, 2.1 front. Need to run 2.10 rear 2.25 front but IRC goes thick mud monster knob @ 2.25.
Any body seen xc (type\close) tread 2.25's ?
the 2.1 Fire Xc's seem to be as rare as rocking horse crap here in aus. I have run the 1.8's and was pretty happy with them. They are quite pressure sensitive and the soft compound makes them ware a lil fast, but over all they suited me fine.
At the moment im about to try GEAX , will see how they go. if they dont work out then ill be heading back down the Panaracer path i think.
Bikes: '05 Yeti 575, , 01 Cannondale SI1000, 03 Felt F65, 07 Tarmac Pro
Well I want xc tread on 2.25's. Period.
I'm currently running a Kenda Blue Groove 2.35 in front and a 2.1 Fire XC Pro in back. The Kenda is made out of a sticky rubber and is kind of a slow roller, but it grips roots and rocks like crazy. I like the Fire in back, but have never been too impressed with it in front. I've also run a WTB Weirwolf 2.5 on front before, it's kind of skinny for a 2.5 tire, but it rolls better than the Kenda.
Take a look at the specs page on this site: https://mtbtires.com
He has a ton of good info in there.
Dean
IRC Trailbear comes in a 2.25" size. using one on the rear of my singlespeed; very good tire in that size.
IRC also has a tire called the Backcountry in a 2.25" size, though i've not used it.
Mine is 26" XC Pro 2.1 folding tire and the actual diameter is a bit less than 1.9" both ways, width and heigth (height including thread), when brand new and inflated to 50 psi.
By the way, I checked many tires of different kinds from road to mountain and in all cases width was the same as height.
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
^^ You DO realize that you are responding to a 7-year-old thread, right?
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
stockae92
Mountain Biking
3
07-21-16 09:26 AM
Mr. Fly
4
06-18-12 01:02 PM
jonathanb715
3
05-17-11 09:50 AM
I dunno, they look like they've super tread on them though
