sled as a trailer?
Bikes: 2015 gravity bullseye monster fatbike,2013 salsa vaya. 90's diamondback MTB,84 univega.
sled as a trailer?
It is possible I have lost my mind,but wouldnt some sled ski's come in handy on hard pack snow?
totally louche
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
long, rigid sled traces, (think 12 foot lengths of 3/4" pvc or bamboo. crisscrossed for control, strapped to the top tube would probably do the trick.Maybe rig them at the dropouts. Run sled reins thru the pvc pipe between sled and bike.
If you've ever been ski hauling, and looked over to see your sled racing ahead, loose on the reins, seconds before it skitters sideways and pulls you off your feet, you'd understand you're going to want rigid traces between you and the sled.
go for it, and post pictures!!!
Thread Killer
I've done it, to pull the kids for kicks, and it works fine provided there's enough snow, of course!
I have dropout hitches from my mono-wheel trailer, so it was easy for me to attach: I used a pair of old hammock spreader bars that I had sitting around the garage, the holes in which were perfectly sized for the ball-lock pins that are part of the trailer hitch. At the sled end, I just threaded the reins through, knotting them to allow a little slack between the sled and spreader bars.
It was basically pretty straightforward, and aside from the slightly uncomfortable feeling of the sled overriding the bars during a stop, worked fine for a trip through fresh powder to the park for some sledding. Unfortunately, it didn't snow like that again that winter, and I've never used it again since, so my insights are pretty limited.
Chariot has a pretty dope ski conversion kit for it's trailers that might be fun to play, although the simplicity of lashing a plastic toboggan to the back of the bike is pretty irresistible. Tracking on a flat-bottom sled in anything but powder is probably nightmarish, though, so I'd be more inclined to look at something with runners were I to take the notion seriously.
That's where my mind is running-maybe some square cut runners attached to the trailer wheels,after they are blocked and can't roll.sounds like a fun project,I have three trailers,might have to try it and see what happens
col
Commuting
12
07-10-14 09:11 AM
KristyG5
Utility Cycling
3
04-22-10 12:04 AM
