Brifters on my Centurion LeMans?
I'm curious about trying to retrofit my old LeMans with some brifters. I wasn't sure if it was possible but after looking around here I'm a little more hopeful. Does anybody have some suggestions that should work? Currently all of my components are stock. Would I need to get different derailers or a new cassette?
Edit: to be a little more specific, I'm not sure what year my bike is but it looks similar to this - https://reluctantlyfit.com/wp-content...ion_LeMans.jpg
Thanks.
Thanks.
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
you might want to check out this thread for inspiration and ideas: https://www.bikeforums.net/showthread...STI-s-or-Ergos
I'm not sure if you have a freehub or a freewheel. Chances are you will need at least a 7 speed freehub in the back to use a brifter set up.. i dont think they made 6 speed brifters
I'm not much of a brifter expert but I'm sure someone will set you straight
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Starts with a budget. My favorite method to make such a conversion is to find a donor bike, and then I do a pretty complete transplant: wheels, cassette, shifters, derailleurs, crank, bb, etc. Much cheaper approach than piecemeal, and less likely to have any compatibility issues. Rear spacing of your bike may well be 120mm, to go with 8/9/10 speed rear means cold setting to 130mm.
Do you have the time/tools/aptitude/pile of parts/resourcefulness to do this conversion? If not, stop at this point. Doing a conversion goes well past the shift levers. The bike basically will be stripped down to the frame, and then built back up with the modern parts you are seeking. Parts on the bike that will work: seat post, saddle, pedals, stem, handlebars, headset, maybe brake calipers. Everything else will need to be replaced.
Unless you score a deal on the parts, and do all the work yourself, its cheaper to just buy a used STI bike, and sell your current ride. Even with scoring a deal on a donor bike, it will be easy to spend $200 on the conversion (if you do the work yourself).
Converting that old of a Lemans is somewhat questionable, as early Lemans were relatively low end frames (best to put your time and $$ into a good frame, regardless of age). You will also need to do some measuring on brake reach, as that bike looks like it has 27 inch wheels (if it has 700c, then ignore that point).
The bike you posted has a freewheel, not a cassette, so lots of changes required.
Just understand a STI conversion of a vintage bike is a labor of love, and rarely/never works out financially. Its all a matter of how far upside down you are willing to go. I have converted many bikes over the years, and am in midst of another conversion right now. This one started with finding a really good deal on a full nine speed Dura Ace equipped bike.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
Looking at your bike I'd suggest finding a Shimano 7-speed wheelset and a pair of Shimano Sora brifters.
I tried it once and it was pretty straightforward.
Before:
After:
Retro Grouch
Bikes: Yes
Assuming you have a 6 speed with 126mm dropouts, you should be able to install a 7 speed STI freewheel and use some Shimano 7 speed brifters..Check ebay there is a seller selling the rear 7sp Sora for $37.00 free shipping!
I've done a number of projects like this and they've usually gone smoothly. The problem I've had have come when I tried to use a bike without forged dropouts, like yours. It just never seemed to shift smoothly. Also, it didn't have dt shifter brazeons, similar to yours, which was annoying. Overall yes, it is possible, though the frame you are starting with will take more work than a one with a few more brazeons.
Collector of Useless Info
It's very do-able. Just expensive. I upgraded a Raleigh Supercourse to 10-speed:
$50- new compact crankset and bottom bracket (on sale)
$130- new microshift brifters with cables
$30- New rear hub
$0- Cold set the frame to 130mm
$50- new rear derailleur
$30- new chain
$40- New cassette, 12-30
$30- misc grease, brake cables, cable stops, etc.
$90- spokes and rims (CR-18's and stainless spokes)
Grand total: $450. Not cheap. But the bike is exactly what I wanted.
$30- New rear hub
$30- new chain
Quoted: 378 Post(s)
Liked 1,409 Times
I've only gone that far "back" to upgrade to Ergo/STI's, and there are just more things to consider, and overcome, most of which cost more than the original or the finished bike is worth, but if you like it, and if you'll ride it, I don't see why not. It's not like you're buying a boat.
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
Quoted: 378 Post(s)
Liked 1,409 Times
I think the Lemans RS I re-fitted with 3x7 RSX brifters and compatible wheels came out to about that.
I felt it was well worth it, and still do.
I'd hoped to get more from selling off the OEM drivetrain,
but I think I ended up giving it away, to create a smiling cyclist.
Quoted: 1872 Post(s)
Liked 692 Times
I think it's awesome. I'm all for vintage but I didn't grow up in the DT shifter era so I don't like them. But I do like vintage frames and brifters, so why not put them together on a bike you're gonna ride? Sounds like a win-win situation to me.
Wow, thanks for all of the input, this is super helpful. If I decide to actually try and go the cold setting route, what do you think of this tutorial?
https://sheldonbrown.com/frame-spacing.html
Thrifty Bill
Liked 964 Times
Shifting is fun!
Bikes: Yes, please.
Liked 4,601 Times
$30- New rear hub
$30- new chain
$30- New rear hub
$30- new chain
Quoted: 378 Post(s)
Liked 1,409 Times
