Dahon Kinetix freehub body replacement (Mu P8)?
Old 03-02-13, 11:06 AM
Bikes: Brompton, Dahon Vitesse D5
Quoted: 55 Post(s)
I'm not well versed in derailleur setups since all my bikes have hub gears. I'm doing some maintenance on a friends Mu P8 (2007) and I think the freehub body is shot since there's a lot of play there and the bearings feel rough. I've just discovered I need a 12mm allen key (it looks like 12 to me but could be 11) to take the freehub off. . . I don't have one just yet. Anyone know what might serve as a replacement or will I have to order a whole new Kinetix hub?
chagzuki is offline
Old 03-06-13, 06:12 AM
Quoted: 55 Post(s)
The fixing bolt appears not to be an allen fitting but rather something like this:
I'm not sure what sort of tool I need.
File Type: jpg
chagzuki is offline
Old 03-06-13, 10:18 AM
Bikes: 8
Quoted: 7607 Post(s)
Shimano uses a 10mm allen wrench, to split the driver from the hub, by removing a similar tubular bolt.
perhaps that is just a 12 point rather than a 6 point
Kinetex a cheaper Caprio version?, IDK, check w the Dealer..
fietsbob is offline
Old 03-09-13, 10:11 AM
badmother's Avatar
Quoted: 317 Post(s)
Did you find a solution to this? Decided a few days ago to take a closer look at my sons Kinetix hub to try to give you an answer, and I`ll try to finish it today, he wants his bike back.
I have done this before on some MTB hub, and I can not remember having any problems finding a tool. I am sure I used the biggest (10mm) allen key.
Trying to do so on this hub is not working. The 10mm slides trough with no resistance.
I agree with fietsbob it could be a 12 point rather than 6, but it is not a 10mm.
Only 12mm I have is not long enough to reach where it should. It is quite short, a socket type of allen key bought to use with a tourche wrench.
My guess is that what you need is a long enough 12mm allen key.
Did you try the Bicycle Mechanics thread? Didi you find a solution?
badmother is offline
mitchmellow62
Bicycle Mechanics
10
08-17-18 09:34 PM
mrandradej
Bicycle Mechanics
5
05-20-14 07:34 PM
need2ride
Bicycle Mechanics
6
02-04-14 03:52 PM
Aquakitty
Bicycle Mechanics
9
05-11-12 07:42 PM
Replica
Bicycle Mechanics
9
03-21-12 07:22 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
