80mm Tubes for my ZIPP Wheels -- what to consider?
Thinking of going with 80mm Tubes for my ZIPP Wheels. Right I have the valve extenders which i have gotten used to. But it is still bit of a pain to put extra air in the the tubes at times using the valve extenders.
Thinking of going with the 80mm tubes Contennential makes
Would I have any problems with using them? eg. stem banging around? etc etc?
thanks for input before i make this transition?
So it is
Quoted: 11402 Post(s)
Liked 4,759 Times
I use them with no issue at all. BDop Valvinators will keep the rattling of the stem down.
Quoted: 6556 Post(s)
Liked 58 Times
+1 on the Valvinators from BDop Cycling. I have also used the 80 mm stems with no problem. You can also wrap the stem in electrical tape where it goes through the hole in the rim. If you don't want the Valvinators electrical tape works almost as good to cushion the valve hole also. Better than extenders for sure.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
Which zipps? 80mm stems are fine for 404's. Too short for 808
You could get lost and die.
You could hit a tree and die.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
and 60mm stems are fine for the 303s.
I noticed someone mentioned about using the Lite Tubes. Any problems with the Lite tubes from the air coming out during a ride?
would the lite tubes be just as durable as regular tubes?
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
I suggest looking for tubes with remove able cores in any length and getting an adaptor that allows the core to be screwed in the top so it operates like a regular tube. That way you can find a replacement tube no matter where you are and stem length won't matter.
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
Well if you're talking about my Bontrager Race XL it's just the name of their model (they also have an xXl Light which I used with my older wheels but they don't make them in 80mm stems). No problems at all, they're just standard tubes but lighter than many.
Quoted: 429 Post(s)
Liked 248 Times
No, they're not as durable.
Mr. Dopolina
Quoted: 149 Post(s)
Liked 117 Times
Be sure to get an alloy tool so you can use it more than on e. The plastic tools are useless and utterly disposable.
MDI
Bicycle Mechanics
11
02-27-12 08:58 PM
