First Impressions on my Trek CrossRip Comp
Quoted: 767 Post(s)
Liked 1,742 Times
I been looking to re-start my bike commuting in earnest this go round as gas prices seem to be heading north to stay and I figured why not just make it official, but I decided, I was going to put together a comfortable ride with solid components.
I did a lot of researching and decided to go with the 2014 Trek CrossRip Comp as I decided to remove the drive train from my steel frame road bike, which I no longer rode, and move it over to the CrossRip. All Trek CrossRip versions have the same frame and fork combo's, only differences are the components and brakes.
My bike is now configured with the following:
Items pull from old frame:
Crank: Shimano 105 - 5600 10 speed
Cassette: Shimano 105 - 12-25 10 speed
Deraileurs: Shimano Ultegra 6600 Front and Rear
Chain: DuraAce 10 speed
Seatpost: Specialized Carbon Fiber setback
The following came with the bike I have not changed them out.
Brakes: Avid BB5 160 front, 140 Rear
Rims: Bontrager Nebula 32 spoke Front\Rear
Hubs: Formula DC20 front\ DC22 Rear - Disc 6 bolt
Tires: Bontrager H5 Hard-Case Ultimate, 700x32c
Handlebar: Bontrager Race Lite IsoZone, VR-CF, 31.8mm
Stem: Bontrager Race Lite, 31.8mm, 7 degree 70mm
Headset: Cartridge bearings, sealed
I added:
Bottom Bracket: Shimano Ultegra 6800 external. The old one was tired and worn out
Bontrager rear rack and fenders
Lizard Skin 2.5 Black bar tape. Love this stuff...worth every penny...and there are a lot of pennies in the price.
Time Roc ATAC S pedals
Garmin Out From computer mount
Weight as described above: 25.9 lbs. While not light, still lighter than the bike I used to commute on now, a 2003 Trek 7300, weight 28.6 lbs.
I took my first ride today, sort of a recovery ride, as I did 65 miles on Saturday for the Jacksonville Tour de Cure. 20 miles, and man I could feel the weight difference from my Cannondale SuperSix, but other than that, it rode great. The wheels and tires are slightly heavy, but spin nice. The bike was very smooth, did not have a lot of road buzz from the frame, being aluminum this was a surprise, but I thoroughly enjoyed the ride. I plan to replace the tire and more than likely the wheels to reduce some weight, probably go to 700x28's , removing 3-4 lbs overall with the combination of tires and Wheels. I believe this is a setup that I will have for a long time that will make my commute much less of a slog and something I look forward to each day.
If you are looking for a road bike fit for your commuter...I would highly recommend looking at this Bike.
Brian
I added:
Brian
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Quoted: 5888 Post(s)
Liked 3,471 Times
Good looking build; the silver shimano parts look sharp on this bike. I'm a big fan of cross bikes.
Quoted: 767 Post(s)
Liked 1,742 Times
Yea, the lettering is more of a silver to me versus a white, so it fit pretty nicely with the flat black.
I bought a Crossrip Comp a couple of months ago to use as a touring bike. I see the the lettering as white so I added white fenders. The guys at the LBS were aghast until they saw the bike.
Quoted: 767 Post(s)
Liked 1,742 Times
I can see the white fenders being cool. My fenders have yet to come in...got lost somewhere along the way, should be here Tuesday. How is your bike holding up? Have you had any issues with the wheels or brakes? I considered upgrading the brakes, but since I live in a flat area...figured the BB5 was enough to do the job.
Quoted: 767 Post(s)
Liked 1,742 Times
The bike is doing great. Did my first 100 mile trip day before yesterday with no problems at all. Be careful with the paint because it mars fairly easily. The brakes, especially the front, grinded, howled, screeched, and moaned for the first few weeks but the LBS assured me it was normal and would soon quiet down. And they did. I live in a hilly to mountainous area and the brakes do just fine.
By the way, did you get the kick stand with yours? I notice these 2 small points near the rear brake and they told me it was for the kick stand. I had planned to just use the one I had, but it would not work with the disc setup.
excellent...I did have to adjust mine a little, when I came out of the seat and put a little torque on the front wheel, they were rubbing slight and I thought the caliper was hitting the spokes. LBS told me to just adjust the pads a little and I was finally able to get them all quiet. Start my commuting adventures in the morning... but man the heat is going to come on with a vengence this week. By Friday, it is suppose to be 96, but clear weather, so I should be good until my fenders come in.
Bikes: Seven Evergreen, Co-Motion Americano
Excellent review. My wife and I picked up 2014 CrossRip LTDs for commuting on in the Pacific Northwest. We both really like those bikes. The only problems we've had so far have been spoke/wheel related and the LBS, today, started the process to have Trek replace my rear wheel under warranty.
I'm going to have to check into adding a kickstand as an option - could be useful for our commute.
Quoted: 767 Post(s)
Liked 1,742 Times
Yep, I have already been in touch with Boyd at Boyd Cycling, and they are planning to offer disc based Altamont wheels for those with disc brakes, I think they just 6 bolt, but I asked him if there will be a center lock option. Pricing will be the same as the rim brake models and will only be offered in the 24/28 spoke options which is great as I have the Altamont's on my road bike and I really like them.
Quoted: 767 Post(s)
Liked 1,742 Times
What was the issue on the wheel?? Also, did you have any issues with the rotors rubbing when you put a little torque on the front end like when I come out of the saddle primarily. Don't really hear anything while I am riding. I've adjusted the pads a bit to try to eliminate this, but it bugs me. Coming from a total rim brake background...never had this issue and not real sure where to go from here. I talked to my LBS and they said that Disc brakes can be a little finicky and did some adjustments, but I can still hear it. Sounds like something hitting the spokes.
Just a little Follow up. Finally got my fenders, kickstand and I bought a Light and Motion Urban 550. That is a pretty bright light compared to what I am used to. I need to get a better picture...but this will have to do.
I also order me some of these for the bike. I just happened to email Boyd Cycling about some disc hubbed wheels and he said that he is in the process of getting some disc hub wheels without the sidewall machined and said he had a pair he be willing to sell me. As I already have the Altamont's on my SuperSix and love them, so I knew what I was getting and I ordered them on Thursday. Can't wait for them to come in. He does not have it on his order site just yet, but did post about it on his facebook site. This must have been fate as the picture of the wheels, which I got from his facebook site; shows the wheels with the Hutchinson Sector 28's which I have been mulling over putting on the Trek since I ordered it as I want to move the bike to tubeless eventually. He told me they were a breeze to go on and really liked them. I think I am just going to run the tire that came with the bike and once they wear down a bit, I will pick up the Sector's.
My rear wheel has been breaking spokes.
The latest break occurred when we were out on our first overnight bike touring trip. Trek, and our LBS, have both been excellent to work with. My new wheel should arrive this week from Trek. If a new wheel doesn't stop the spokes breaking I'll move to handmade wheels.
I haven't had any unusual sounds. The CrossRip LTD has the TRP Hyrd breaks, and those have been a little easier - for me at least! - to get dialed in than pure mechanical discs like the BB7s for example.
Quoted: 767 Post(s)
Liked 1,742 Times
Quoted: 767 Post(s)
Liked 1,742 Times
Here is an updated picture with my new Boyd Altamont's with Disc Hubs and no rim brake option. They are a sweet ride.
Hi,
I'm looking to add some accessories to my totally stock 2014 Crossrip Comp with disc brakes. Brian, your bike looks great - can you please tell me which kickstand and fenders you installed (links or model #s if possible)?
Also, I'm looking to add Topeak racks - are these a compatible selection?
[h=1]Topeak Super Tourist Tubular Bicycle Trunk Rack DX with Side Bar for Disc Brake Bikes[/h]
https://www.amazon.com/Topeak-Super-T.../dp/B000ZKHN6Y
Some Guy on the Road
Bikes: Foundry Chilkoot, Trek Domane
Quoted: 43 Post(s)
This thread is from last May, so you might not get a response from the OP.
The kickstand is a rear-mount, something similar to the Greenfield Stabilizer (bottom of the page)
Welcome to Greenfield Industries, Inc. - Freeport, New York - Quality U.S.A. Die Caster
OP states in their first post that fenders are Bontrager
Bontrager: NCS Fender (Model #09150)
Quoted: 767 Post(s)
Liked 1,742 Times
Hi,
Thanks...The kickstand is the Bontrager or what ever re-badge kickstand they sell for the bike, it was like $14. I also just got the Bontrager Fenders ~$45?? since the LBS gave me $250 of freebee cash for buying the bike to apply toward stuff. The rack should work fine...I just got the Bontrager rack the LBS had and it works find for me. I added the Bontrager trunk bag and recently moved to Ortlieb Front Panniers, highly recommend these.
Kickstand: Bontrager Dual Sport Rear Mount Kickstand - Replacement Parts - Accessories -Trek Store
Fenders: Bontrager NCS Fenders (700c) - Bird Legs Bicycles | Freedom on Wheels | Tallahassee Jacksonville Florida
Trunk bag: https://store.trekbikes.com/product/b...+trunk+bags.do
Ortlieb: https://www.ortliebusa.com/prodInfo.asp?pid=30&cid=2
And a pic showing a better view of the kickstand.
Bike
Oh an update....the weight of the bike is now sitting close to 21 lbs when I moved to the Boyd wheels with Michelin Pro4 Endurance tires I am running now.
Quoted: 767 Post(s)
Liked 1,742 Times
Just a slight update...Bike still rides wonderfully. I highly recommend one if you are looking.
I recently happened upon a bike I was not looking to buy yet, but got such a deal and dug the color so much, I pulled the trigger and picked it up. I bought a Trek ALR. It came with 11 speed 105 setup and I decided to move the Ultegra from my Synapse to the ALR and moved the 11 speed 105 over to my CrossRip which had a mix of Ultegra\105 10 speed. The 11 speed 105 group shift superbly and will make a great upgrade to my commuter and the black on the group matches nicely. I also just ordered some Salsa skewers in green for just a splash of color.
mustardthang
Road Cycling
3
05-06-12 03:12 PM
