Swedish/Norwegian Bottom Brackets-One piece cranks
Old 12-19-07 | 01:41 PM
cman's Avatar
I have a DBS(Norway) and a friend has Monarch(Sweden) bike both with one piece cranks. The are different than the standard American version. We can get the locknut, washer and bearing races removed from the crank. The problem lies in the bearing cups. The bearing cups must be removed to remove the cranks. I tried hammering out from the backside and unscrewing the cups (both left and right). Nothing has worked for either of us.
Does anybody have any insight.?
cman is offline
Reply
Old 12-19-07 | 03:47 PM
rmfnla's Avatar
Bikes: Gilmour road, Curtlo road; both steel (of course)
Never seen one of those but it appears from your photo that that inner ring (the rusty one) unscrews from the crank. Try tapping a punch into the notches, assuming you don't have a tool that fits (I certainly don't).
After that, who knows, but I would bet that once you get that ring off it will be more apparent what to do next.
Today, I believe my jurisdiction ends here...
rmfnla is offline
Reply
Old 12-19-07 | 03:49 PM
RockyMtnMerlin's Avatar
Bikes: Merlin Extralight Topolino Wheels Campy Record
Hey your sig is the state fish of Hawaii! Coool!
RockyMtnMerlin is offline
Reply
Old 12-19-07 | 04:20 PM
15 Anniversary
Bikes: Early Cannondale tandem, '99 S&S Frezoni Audax, '65 Moulton Stowaway, '52 Claud Butler, TSR30, Brompton
OP has already got that far.
LWaB is offline
Reply
Old 12-19-07 | 04:29 PM
cman's Avatar
Correct. Just need to remove bearing cups but cant' tell if they are threaded and which direction.
cman is offline
Reply
Old 12-19-07 | 05:12 PM
rmfnla's Avatar
Got it; a photo showing how far you have gotten would have made that clear.
I would guess that they are threaded based on the knurled outer surfaces of the cups; no reason to do that if they are just press-fit.
This is what is so frustrating about trying to troubleshoot by Internet; if I could just get my hands on 'em!
(This is also why I usually post wise@ss remarks rather than repair input; if a picture is worth a thousand words holding the part is worth a thousand pictures.)
rmfnla is offline
Reply
Old 12-20-07 | 02:36 AM
Prodigy4299's Avatar
Bikes: 1990 Trek 850, 2005 Cannondale R1000, 2019 Cannondale Topstone 105
Unfortunately I can offer no insight other than the fact that I recommend you e-mail a bike shop in Copenhagen or Oslo. They will surely be happy to help you and they all speak impeccable English.
And, by the way, my girlfriend's bike has the same cranks. Does that mean it's a DBS as well, or did other companies also make these cranks?
Prodigy4299 is offline
Reply
Old 12-20-07 | 05:44 AM
240GL's Avatar
Bikes: Bros Sonic FS XT-LX hybrid w/Brooks Swift
Oh, I've had a few DBS bikes through the years! (DBS = "Den Beste Sykkel" = "The Best Bike". Well.) Which model is yours? I have never had to remove a crank, but they should be pretty similar to your Ashtabula cranks. The bearing cups are press fit and should be hammered out. I will have a look tonight and see if there is a diagram in my DBS service booklet. If so I'll post a scan.
240GL is offline
Reply
Old 12-20-07 | 06:13 AM
Bikes: A bunch
[Bolds mine.]
Try a pin spanner first; that is what this part looks to use.
CHenry is offline
Reply
Old 12-20-07 | 09:17 AM
cman's Avatar
I would appreciate that. My friend got his bearing cups out last night. Threaded on both sides. regular threads on the right and reverse on the left.
cman is offline
Reply
Old 12-20-07 | 09:25 AM
240GL's Avatar
From my old Norwegian repair book (my poor translation, don’t blame the book!) – “fourteen easy steps”. The letters refer to the scanned picture at the bottom. Hope this helps.
“To remove the (Fauber) crank special tools are needed. One for the nut (top) and another for the cup (bottom). Start the job on the left side of the bike.
1. Using the special key unscrew the nut (a) backwards.
2. The securing washer (b) is now loose. Remove it.
3. Left dustcap (c) is also loose. On the inside there are two teeth that fit the notches in the cone (d).
4. Use the dustcap to unscrew the conus. Keep in mind that it is left-threaded, screw backwards.
5. Loosen the left cup (f) using the special tool by screwing backwards. Remove the ball bearing frame (e) and the cup.
6. The crank arm (g) will now seem loose, but before you remove it you need to loosen the right hand side using the special tool.
7. Now the crank arm can be eased out of the bicycle frame.
8. Clean the ball bearings in kerosene and re-pack them with grease. Replace worn parts.
9. If the chainwheel (j) needs replacing, unscrew the right hand side conus – which is right-threaded. Lift off the right hand side dustcap.
10. The chainwheel can now be replaced. If you place the ball bearing frame in the cup, you will observe that it rests deeper than what is the case for the left cup.
11. Installation is reverse of removal. Keep in mind the different thread direction left and right.
12. Finally, check that the crank rotates easily. If it is too tight or loose, loosen the nut. The tightening is adjusted by rotating the dustcap.
13. Retighten the nut properly.
14. Make a last check to ensure that everything works as it should.
240GL is offline
Reply
Old 12-20-07 | 09:29 AM
Juha's Avatar
Formerly Known as Newbie
Titanium Club Membership
20 Anniversary
Why Copenhagen? I thought Monark was Swedish? Though I'm sure bike shops in Copenhagen would be able to help too.
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Juha is offline
Reply
Old 12-20-07 | 10:03 AM
cman's Avatar
240GL- Thanks for the description and pic. Seeing the tool should help me figure the bearing cup removal. The hammer and punch has not worked to turn the bearing cups.
cman is offline
Reply
Old 12-20-07 | 11:06 AM
rmfnla's Avatar
Looks identical to an Ashtabula set-up.
rmfnla is offline
Reply
Old 12-20-07 | 11:24 AM
cman's Avatar
except the ashtabula crank can be taken apart with a pipe wrench...an ashtabula crank can be removed from the frame without removing the bearing cups and the bearing cups on a ashtabula crank are pressed in and not threaded.
cman is offline
Reply
Old 12-20-07 | 11:46 AM
wroomwroomoops's Avatar
Sir Fallalot
15 Anniversary
It's interesting to note that the instructions translated from the Nrwegian by 240GL mention the removal of the bearing cups by "screwing backwards" - which I guess means counter-clockwise, which makes sense (most of the time in life). The special tool, if I am reading this correctly, is some pin spanner. I have the variable ParkTools pin spanner that would probably work for this purpose.
wroomwroomoops is offline
Reply
Old 12-20-07 | 12:03 PM
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
You don't really need a pin spanner. Just use a screwdriver and a mallet, and punch tangentially. Works for both loosening and tightening.
CdCf is offline
Reply
Old 12-20-07 | 12:16 PM
Sir Fallalot
15 Anniversary
*walks away and whistles some Beethoven tune*
Reply
Old 12-20-07 | 12:29 PM
Videre non videri
Fair enough, but then a pin spanner won't work either... I've used both methods, and screwdriver+mallet is by far the most effective, if a bit more destructive to the metal...
CdCf is offline
Reply
Old 12-20-07 | 12:39 PM
rmfnla's Avatar
I'm not convinced that both are not the case here.
When you do get it apart please tell us how it played out.
rmfnla is offline
Reply
Old 06-29-08 | 04:56 AM
I know this thread was last active Dec -07 but i have some picture that might help cman or anyone else with this kind of bottombracket.
https://happymtb.org/forum/file.php/1/file=65399
Mount the tool (if you've got one, a screwdriver, nail or screw with the right size works too) and start to unscrew (reverse threaded):
https://happymtb.org/forum/file.php/1/file=65400
Remove these (just pull them out):
https://happymtb.org/forum/file.php/1/file=65401
Now it should look something like this:
https://happymtb.org/forum/file.php/1/file=65402
Mount your tool and start unscrewing like in step 1:
https://happymtb.org/forum/file.php/1/file=65403
indianmannen is offline
Reply
Old 05-12-11 | 03:24 PM
Just an update - with the help of jebejava i found this link https://fixedgearbikes.blogspot.com/2...er-bottom.html
to modernise or replace the ashtabula. you can buy them here, under KASETTIKESKIÖT - https://www.pyoratohtori.fi/
rialaado is offline
Reply
Old 05-23-12 | 02:54 PM
I bought the Park Tool SPA-6 pin spanner and was almost shocked when my Fauber came apart with no problem at all. The Park Tool pins were much too small, still it worked fine after I had soaked the cup with CRC & waited for a few hours. Some parts, including the right hand bearing cup, actually unscrewed by hand. A few taps with hammer + punch were needed for the left hand bearing cup, but nothing was really that hard. The crank was full of oily sand, so taking the 30 year old Fauber apart was definitely a good idea. Recommended, but soften up with CRC or something first and get a pin spanner.
pertti_jarla is offline
Reply
Old 10-21-16 | 01:35 PM
3alarmer's Avatar
Bikes: old ones
Fauber Crank photos
...on the off chance it might make this easier for someone down the line, here are some photos of a Fauber I just took off a DBS Golden Star that badly needs painting. Were it not for that, I'd probably not have bothered.
Used a pin punch (which will now require some redressing), a hammer of only moderate size, and a lot of CRC Freeze Off. It did not give up easily. For reference, I was confused about the threading directions at first. The drive side is regular RH threaded and the non drive side is LH thread.
Which for some probably very good reason is the reverse of most stuff these days.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
3alarmer is offline
Reply
Old 10-21-16 | 01:57 PM
Bikes: 8
"Thun" Bike Bottom bracket The company of that name does not make them any More as I try to look them up
fietsbob is offline
Reply
