Touring Frames
Touring Frames
Want to build my own touring bike but not sure about the frame. Heard that reynolds 531st was perfect for touring but they weren't making it anymore. What other frames are right up a touring lads alley?
I am a lonely visitor
Bikes: Michelle Pfieffer, the Carbon Fiber Wonder Bike: A Kestrel 200 SCI Repainted in glorious mango; Old Paintless, A Litespeed Obed; The Bike With No Name: A Bianchi Eros; RegularBike: A Parkpre Comp Ltd rebuilt as a singlespeed.
If I were building up a tourer, I'd look seriously at the Surly Long Haul Trucker. It's brand new and so, unproven, but worth a closer look. I'd certainly want to compare it to other frames that are out there. They're marked at about $400.00.
Religion is a good thing for good people and a bad thing for bad people. --H. Richard Niebuhr
Guest
Posts: n/a
Quoted: Post(s)
531 is still listed on their website and the microalloy 853 sounds even better!
https://www.reynolds-cycle.com/intern...teel/steel.htm
Zona tubing by Columbus is used by Marinoni for their touring frame for example.
https://www.marinoni.qc.ca/html/2004/eng_turismo.asp (this is my dream bike)
https://www.columbustubi.com/english/acciaio/index.htm
Other steel to look at is TrueTemper, they make some great tubing like the OX Platinum and the Versus HT and Versus.
Not sure on your location but Thorn at st johns cycles in the UK is very reputable and in America you should find a plethora of good frames and builders.
So what is the “best” steel for touring?
Are you planning to build the frame?
Quoted: 12197 Post(s)
Liked 1,498 Times
Hi,
there is credit card touring, camp touring, expedition touring. Which will you be doing? Companies that make steel touring bikes are Waterford, Rivendell, Heron.
Quoted: 36 Post(s)
What made 531 ST great IMO for touring was it had butted wall thicknesses as great as 1.2/.9/1.2 . It was plenty stiff enough for a heavy load and it wouldn't dent if the bike fell over or fold up from a minor crash. They still make 531 DB. But from what I'm told they are only making limited runs now in .9/.6/.9 wall. Used to be you could buy the tubes off the shelf, now you have to buy mininum quanities and Reynolds no longer has a USA based distributor so you pay shipping from GB.
It is very difficult if not impossible to find butted tubing in the standard frame sizes( 1.0, 1.125, 1.250) with butts thicker than .9/.6/.9 and even that thickness is becoming increasingly difficult to find. when I built the current frame I ride last spring I had to buy straight gauge 4130N to get more durable tubing.
Rivendell Atlantis
Beautiful...frame & fork $990 until Jan 1, then goes up to $1400...Grant Peterson is right!...lugged steel by Toyo for half $ of custom...did I mention beautiful?
Liked 1,498 Times
BillyBear,
what did I miss? Which frame is $990?
X-Large Member
Bikes: 2004 Rivendell Atlantis, 2004 Thorn eXp, 2004 Bob Brown Cycles Custom
Rivendell Atlantis.
Also, don't forget Thorn bikes for everything from light touring frames to hardcore expedition frames.
