Surly Troll Commuter Build
Surly Troll commuter build
The new frame is here at last! 20" Surly Troll.
I plan to build it this weekend, with more pics and ride reports to follow.
I'm Rad.
Bikes: 2008 Allez (Sold), 2009 Surly LHT (Sold), 2014 Motobecane Fantom Cross Pro
I look forward to seeing this build. Bautieri and I were having a discussion regarding this frame and he mentioned it looks a lot like the Salsa "Fargo" frame. The Surly blog https://www.surlybikes.com/blog/ has a nice looking pre-production build.
V
V
Have bike, will travel
I'm basically moving everything over from my 8-year old Giant aluminum MTB frame that has seen heavy commuting and trail use over the years. The components are a mix of fairly new XT and SLX for a 3x9 set up. I'll replace the shifter cables with Jagwire Ripcord that has full length housing.
The LBS installed a new Cane Creek S-3 headset, applied Framesaver and faced/chased the frame, so everything is ready to go.
Bikes: Windsor Wellington 3.0
It rode with the guy who bought the on in the picture I posted earlier. It is one SWEEEET ride. He has some really narrow road bars on it right now. He's getting a couple of other bars so he can switch things up for whatever rides he's doing. That is a real do-anything bike.
Here are some pictures of the build. Moving the components over from my other bike was completely straightforward. The guides for the brake and shifter housings are great. The rear dropouts made installing the rack and fender really easy.
The only minor issue I had was installing the front derailleur. The seat tube is a fairly small diameter, and I didn’t have a large enough shim, but the LBS came through with this. I left the steerer uncut for now, and will adjust after a few rides.
The rear wheel is more difficult to remove with the horizontal dropouts. It’s a little tight getting around the rear derailleur. Also, the rear fender stays need to be loosened to remove the wheel, but I plan to cut off part of the fender to eliminate that issue.
I rode around the block a couple times to make sure everything works properly. The temps were in the single digits this morning, so I didn’t ride to work. A complete build list and ride reports to follow.
Ride Report: I rode 13 miles to work today on just about every type of surface, and I must say the ride is awesome! I used the Speedcity wheelset with 700x28 Gatorskins on the rear and 700x25 4 Seasons on the front, both at max inflation. Compared to the aluminum MTB with a Surly steel fork I was riding, all the harshness is gone. The frame has exceeded my expectations.
I rode on the C&O Canal Towpath which is dirt and rocks, paved MUP with lots of root ridges, streets, wooden boardwalk-style bridges and even crossed railroad tracks, and the Troll handled it all exceptionally well. Handling was also very good, as was climbing out of the saddle.
I don't know if the improvement in ride quality is due entirely to steel, but the geometry of my old frame is nearly identical, so that's all I can think of.
Thanks for all of the nice comments from everyone.
It's true, man.
Bikes: Cannondale T1000, Inbred SS 29er, Supercaliber 29er, Crescent Mark XX, Burley Rumba Tandem
