FC Cable Routing Question on Centurion Ironman
Bikes: 1997 Specialized M2Pro
FD Cable Routing Question on Centurion Ironman
I determined why the FD cable broke on my wife's bike (see this thread). The cable was rubbing against part of the FD.
This is how I had routed it last time:
I had assumed that that "knob" was to keep the cable under the bolt.
So my question is: should it be routed like this instead (tighter, of course)?
Thanks!
Thanks!
Bikes: 1983 Gureciotti/full SR 2002 Casati Record 10 speed 1995 Colnago C40 2007 Sram Rival 2006 Isaac Sram Force 2000 DEAN Ti DA 10 speed 1987 Schwinn Prologue Funny Bike 2001 Pinarello DA 9 speed 2008 Element6 Record 10speed Origin8 Lutegra10speed
You notice how the cable sits in the groove. That groove is there to help keep the cable from deforming (flat) as the bolt get tight. The earlier picture looked like you had the cable not lined up with the groove. Other than some dirt -- the cable routing looks good.
Thanks, TLC!
Yeah, I thought someone would notice the dirt. The camera adds 10 lbs of dirt.
Here it is installed and cleaned up a bit. I clipped the end of the cable a little shorter than I intended.
rebmeM roineS
IF the cable doesn't go up over the 'nub', then it doesn't pull quite enough - and can rub where it shouldn't.
Your "new" cable routing (outside of the nub) is correct. For friction shifting (downtube or barend) it doesn't really matter but for indexing it is essential the cable be routed outside and over the nub.
Looks very nice. I know your wife will be much happier with a cleaner bike that works better. She should notice that the front derailleur works better than before.
