SRAM Shifting Problem - Anybody else?
Bikes: 2008 Felt F5 w/ SRAM Force, 2002 Giant OCR2, Specialized Stumpjumper M2 Comp
Just curious if anybody else experiences this and if it's exclusive to SRAM or if it's just because i'm shifting stupidly. When I'm in the big ring in the front and I'm starting to get into a cross-chain situation, I'll hit both levers at the same time so that I shift to the small ring in the front and shift to a smaller/harder gear in the back. When I do this, every once in a while, the drivetrain locks up and the rear derailleur gets sucked up and i think slams against the chain stay. I have never actually damaged anything from it happening and I just release tension on the pedals and it fixes itself. I avoid shifting in this manner as much as possible but was just curious if this is normal since the RD has so much slack to make up while it's trying to shift. So, anybody else have this?
Oh yeah, I think I've only noticed it on my Force bike and not on my Rival bike. The Rival is newer but I don't think that should matter.
Your RD is hitting your chain stay? I doubt it. I believe you that it's getting jammed up, just not because of your chain stay. It's not a specific trait to SRAM, just ease off for a half a pedal stroke.
I'm just guessing here, but I think the more 'in-tune' your FD/RD are the less likely this is to happen. I remember this happening to me in the past, but not since I started working on my own bike and getting everything really dialed in. So it might just be correlation that it doesn't happen anymore (since I probably soft pedal a bit and don't think about it) or it might be causation (because my drivetrain is better tuned now).
A suggestion that might help, increase b-tension on your RD. I might be totally wrong though, so take with a couple grains of salt.
Bikes: Cannondale EVO, CAAD9, Giant cross bike.
Bikes: 2010 Mercier Kilo WT, 2011 Specialized Tarmac Pro SL3 Red
Sucking Wheel at the back
Bikes: Lynskey Helix Sport, Lynskey M290, Cervelo S3
I believe what you are doing it creating too much slack in the chain at one time. Shift front to small then quickly shift rear where you want it. I've had what you are talking about happen with DI2 when I was playing with the Front Derailleur shifting back and forth as fast as I could trying to get it to mess up.
Bikes: Neilpryde Nazare, Storck Scenero G3, Colnago Extreme Power, CAAD 10, Bowman Palace R, Strong Custom Foco Steel, BMC SLR01, BMC ALR01
Bikes: Cannondale Supersix2 SRAM RED - Specialized Epic Comp
Stuff breaks. Nothing's forever. But I'd be pissed if it happened to me. I'm pretty picky about chains. If they get even a little stretched, off they come.
Bikes: Trek Series 6 P1 & Cronux CX Flatbar
Just happened to me the other night on the trainer. If I recall correctly I was shifting the same way when it happened. First time that it happened. Mental note not to shift at the same time.
Cool, thanks guys. I will just make sure I avoid shifting like this in the future. I was thinking and maybe the reason my Rival bike doesn't do it as much is because I cross-chain a bit more freely on that bike. It has the front trim in the big ring and maybe that makes me more comfortable cross-chaining. I don't know.
Bikes: 2010 Jamis Xenith Comp
i've dropped my chain once doing that with shimano. haven't attempted it since. as others have said, i think that method is the issue rather than the SRAM.
