Can I see your fork alignment jigs?
Old 03-07-11 | 08:18 PM
sailorbenjamin's Avatar
From: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
What do you use for reference points when you're measuring the fork? What are the standards and tolerances?
I was just given this beautiful Falcon with a slightly bent fork. I've done a few before, just by eye. They seem to work pretty good, but it seems like this job should be treated with a little more precision.
sailorbenjamin is offline
Reply
Old 03-07-11 | 08:33 PM
Scooper's Avatar
Decrepit Member
Bikes: Waterford 953 RS-22, several Paramounts
Here's my Bringheli fork jig.
...and here's my Hammill Engineering fork blade bender.
- Stan
my bikes
Science doesn't care what you believe.
Scooper is offline
Reply
Old 03-07-11 | 09:11 PM
Bikes: one of each
Wow. That's sweet. Maybe I could make one out of oak.
Reply
Old 03-07-11 | 09:15 PM
Doohickie's Avatar
You gonna eat that?
From: Fort Worth, Texas Church of Hopeful Uncertainty
Bikes: 1966 Raleigh DL-1 Tourist, 1973 Schwinn Varsity, 1983 Raleigh Marathon, 1994 Nishiki Sport XRS
I just use a ladder. Wedge the fork blades between rungs and pull. By leaving the frame attached to the fork when I do the bending I can get plenty of leverage to do a nice, controlled bend.
I stop for people / whose right of way I honor / but not for no one.
Originally Posted by bragi "However, it's never a good idea to overgeneralize."
Doohickie is offline
Reply
Old 03-08-11 | 03:39 AM
randyjawa's Avatar
Titanium Club Membership
15 Anniversary
This is interesting. I already have some ideas for a fork gauge that I want to build to help straighten fork sets. Your jig has the creative juices flowing.
Let's see some other ideas, if there are any out there.
randyjawa is offline
Reply
Old 03-08-11 | 05:25 AM
YoKev's Avatar
hi
We had a thread like this a few months back, but I can't find it. Anyhow, someone had a really basic jig made from a 2x4 with two U bolts through it for the steerer tube. A hydraulic car jack to was unbend the blades.
YoKev is offline
Reply
Old 03-08-11 | 05:56 AM
Glennfordx4's Avatar
I don't remember who made it but I saved the image so I could make one.
Glenn
Glennfordx4 is offline
Reply
Old 03-08-11 | 05:57 AM
miamijim's Avatar
Sheldon Brown Memorial - Donating
20 Anniversary
https://www.biketoolsetc.com/index.cg..._id=SN-FCG/SET
miamijim is offline
Reply
Old 03-08-11 | 08:19 AM
20 Anniversary
Bikes: A few
I think this might be the thread mentioned. https://www.bikeforums.net/showthread...ht=fork+bender
Ciufalon is offline
Reply
Old 03-08-11 | 08:31 AM
mudboy's Avatar
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
Glenn
That would put way too much stress on the fork crown/steerer area. At the very least, clamp the top of the fork blades.
mudboy is offline
Reply
Old 03-08-11 | 10:29 AM
randyjawa's Avatar
15 Anniversary
mudboy makes a very good point, here. When straightening forks and/or frame set, I do not pass stress through a brazed or silver soldered joint. All stress is restricted to the tubing.
And that is why this thread is so good. By pooling our collective efforts and ideas, who knows what will result. I am going to keep my eye open, for do it yourself frame bicycle repairing tool material, when I go to the Dump, from now on.
Reply
Old 03-08-11 | 12:36 PM
canopus's Avatar
15 Anniversary
Bikes: Road, Touring, BMX, Cruisers...
The shop I used to work at had an excellent one. Similar to the VAR but a better refinement of it I think.
You clamped the steering tube like the var but the bars sliding jig went all the way to the crown so you aligned to the crown first, tightened the steering tube more so it would move in the jig, then checked your blades and dropouts. and aligned those as needed. Used to do a lot of them before lawsuits and when labor was cheaper than a fork.
https://www.sheldonbrown.com/var/pages/var0006.html
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
canopus is offline
Reply
Old 03-08-11 | 12:48 PM
rhm's Avatar
rhm
multimodal commuter
Older bed frames have a stout L-shaped beam at both sides. Those are excellent for this type of project.
rhm is offline
Reply
Old 03-08-11 | 05:56 PM
Bikes: one of each
Yeah. I think I read that and forgot it and then got to thinking about it again.
Post #29 from Randyjawa is particularly useful. I was having a little trouble figuring out what to reference the twist from.
Reply
jimmuller
Classic & Vintage
38
11-28-18 03:24 PM
Shp4man
Classic & Vintage
12
07-15-13 01:13 AM
gmt13
Classic & Vintage
3
10-16-11 01:01 PM
evilcryalotmore
Singlespeed & Fixed Gear
9
01-16-11 09:00 PM
chico1st
Bicycle Mechanics
0
02-07-10 01:27 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
