Gear ratio issue, what do?
I have a problem:
I'm running 48/15 right now (velodrome), and don't have a car.
I have to bike home after training, and have a few hills.
I'm running a flip flop hub (worst invention ever), so I can't run a cog on the freewheel side, as I'm brakeless, and backpedaling would be death.
Can you, intelligent members of BFSSFG, think of a solution other than switching out my cog/chainring every time for a lower ratio, or the miche cog/carrier system?
**Front fork isn't drilled for a brake
pic very related
pic very related
i smell bacon
Bikes: Geekhouse Deerfield, GT Edge Ti, Spooky Skeletor, TET Track, Ritchey P-650b, Bridgestone MB-3
Get a wheelset with fixed/fixed threads (can mount fixed cog + lockring on both sides).
Bikes: Pegueot UO8, Tommaso Augusta
Change to the Miche cog system, allowing you to easily swap out a cog for a lower gearing on the ride home.
I know this isn't exactly the setup you wanted, but will probably be the cheapest.
i smell bacon
IRO hubs are available in fixed/fixed for $20 + shipping. You might need new spokes, too?
Other than that, the Miche carrier + cog system seems like the easiest option, but even that sounds like it'll run $40+ for two cogs and a carrier.
The cheapest option is to just switch cogs every time.
Xavier: I considered it, but I've heard about some difficulties with the system. How does one remove/tighten the carrier itself?
Yummygooey: Switching cogs every time sounds ok, but I am running a formula cog, and am wary about stripping the threads, especially with rotafix (no chainwhip at the moment)
i smell bacon
You should invest in decent cogs (and lockring) anyways, and a chainwhip is a good tool to have around for a fixed gear rider.
Get a 46t chainring and pin spanner and swap that out when you're done? Changing chainrings seems much easier than changing cogs.
Does anyone else ride to and from the velodrome?
I'm trying to wrap my head around emergency skidding on the streets with this ratio
GONE~
If you're serious about track, you should invest in a set of velodrome wheels that you use them exclusively on the track. Mostly because the Everwear? Rando? you have is going to feel like you're pedalling through mud if you want to break out for a lead.
What velodrome will you be riding in?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
I have the Miche system on two wheels, and it works very well. You just install the carrier once, and after that you just remove the lockring to change cogs. You install the carrier the same way you install a normal threaded cog. Screw the carrier on by hand, then slide on a cog and tighten the lockring. Use a chainwhip on the cog to fully tighten the carrier, after which you retighten the lockring. If you want to be really sure it is tight, install the wheel in the dropouts and stand on a pedal with the front wheel jammed against a wall or other fixed object. Then, remove the wheel and recheck the lockring for tightness. Use a good quality lockring such as Dura Ace.
Couldn't you just install/tighten your cog and then put on the lockring at the end?
King of the Hipsters
Bikes: Realm Cycles Custom
Just gear down to 45 X 19 (63 gear inches) and learn to spin.
You can change back to your "velodrome" chainring and cog in a half an hour when you go to the "velodrome."
Bikes: Caad9, Fixed gear, Hardrock beater, 3 speed cruiser
I may be missing something, but if you change the cog too much your chain will probably be the wrong size with a bigger cog on there.
Well a few teeth in the cog shouldn't change too much, chainring definitely would make a bigger difference
That is a problem though
I still don't understand Ken Cox's reply
Fueled by Tigers Blood
you are wrong. If he doesn't need to have this wheel slammed against the seat post you can probably run 2 cogs 2-4 teeth apart. My jamis could run a 15 or a 19. Same chain.
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
Well, Sturmey Archer has reissued it's old Fixed 3 speed IGH. (S3X)
https://www.sheldonbrown.com/harris/s...cher-hubs.html
Now, it's definitely not the cheapest at $240.00, but it's the coolest.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
You should have horizontal dropouts that let you adjust your chain tension; and, for large changes in gears, put on a new chain.
A chain costs less than a cog or a chainring.
So, you have one ring, cog and chain combination for the street and another ring, cog and chain for the velodrome.
A half hour work after you get to the velodrome.
In the meantime, on the street, you can ride with a more useful gear ratio and learn to spin...which will pay off on the velodrome as well as on the street.
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
IMO it is best to have a set of street wheels and a set of track wheels get something cheap like the wabis and be done with it keep you track wheels straight and you good tires clean and put some crap tires on your street wheels and get at it
