Creaky bottom bracket?
So I have been riding my new bike for about a week now. I have this bottom bracket :
https://www.nashbar.com/bikes/Product...3#ReviewHeader
Today, out of nowhere, I started getting some fairly loud creaks coming from the bottom bracket area. It happens at a certain point on every rotation, and happens mostly when I am pedaling forcefully (ie. starting after stopping at a light) but it is very obvious and is driving me insane. I have removed the cranks and BB, re-installed and tightened everything. Also tightened all the stack bolts on the chainring. This fixed it for about 10 minutes, then it started again. Any ideas?
Your cog is slipping.
Bikes: EAI Bareknuckle
What cranks are you using? Some low-buck cranksets often have less than perfect square-taper interfaces and the poor fit can cause some creaking.
Wait...you have S-300s with a GXP right? Did you grease the spindle?
Sorry, its not the bike in my sig but a new bike I built up. Running these cranks
https://store.somafab.com/irdde144trcr.html
Do I still grease the spindle?
Bikes: Caad9, Fixed gear, Hardrock beater, 3 speed cruiser
I get the same creaking in my cranks every once in awhile, lube on my square taper spindle makes it go away though (even though you technically don't have to lube the spindle)
I've encountered this problem as well. Not the pedals, but in only happens when I'm out of the saddle and sprinting. More importantly, how do I take off cranks? I don't know much about maintenance.
Had the same issue, retightened everything, and it turned out to be a tiny bit of the pedal that was missing some grease. Just enough so that the added weight of at the right time in a rotation would cause the metal on metal creaking.
Ok, I got home, took of cranks and BB and regreased BB threads. Re-installed cranks, and greased pedals. Tightened everything as much as it will go, but still that damn creak when I am sprinting or out of the saddle. I can "feel" the creak in my pedals so to speak and it happens usually on the down stroke of the right foot. I have some cheap-ass pedals that came with my Windsor awhile ago that I temporarily threw on my ride until I get some nicer pedals... No way its seatpost or saddle - tightened the hell out of them. Also tightened quill.
Two questions:
1.) Could cheap-o pedals cause a creak?
2.) Also I tightened the hell out of the fixing bolts that screw into my BB spindle. As tight as I could. This seemed to help a little, but cant over-tightening these bolts be bad for the BB?
Thanks guys this creak is driving me to madness!
Two questions:
Absolutely.
It can be worse for the interface on your crank arms than your BB.
Assuming all your chainring bolts are tight, try putting a drop of light oil (or even chain lube if that's all you've got) on each one where it makes contact with your chainring.
It's also very possible that your BB isn't fitting into the frame as snugly as it should. You may want to try teflon tape (like what plumbers use) in place of grease.
Absolutely.
Art Gibs
Bicycle Mechanics
18
09-25-13 01:29 AM
