Should I worry about high heart rate?
Hey Guys:
oops I for to add heart to the thread title.
I wanted to ask you a question. Sorry if its a stupid question but I thought I should ask it anyway just in case. I am wondering if I should be worried about my high heart rate. When I look at the Garmin stats of other guys I do not see anyone with a rate as high as mine is. I am in not bad shape and I am fat or obese at 205 and 6'4". I am also 36 years old.
I went out for a 80K ride today and noticed that my HR was around 160 the entire time. This certainly makes difficult to go any faster than I currently am. I feel fine when I am not biking and biking. I have no SOB or any chest pain. Usually when I am spinning I am around 95 to 100 as you will see in the stats. I a rode around 2500km this year so its no like I am just starting out either.
Take look and let me know what you think. Should I go to a doc? He already thinks I am hypochondriac so I am don't want go unless I absolutely have to
PS Don't make fun of my lame numbers
https://connect.garmin.com/activity/116684248
Claude
Claude
hello there. I am also 6'4'' and 190lbs. I also experience higher heart rates (average about 160) and tend to max around 175-180 on my rides. My guess is that it has to do with height and size. Our hearts need to work harder to move that blood and oxygen. It could also be that your simply not in good shape. Wouldn't worry about it (your HR is not extremely high).
Bikes: S-Works Roubaix SL2^H4, Secteur Sport, TriCross, Kaffenback, Lurcher 29er
Yup. 47 years old, 6'3" and 190 here. I hit 190 bpm on today's ride. Don't worry about the number, worry about how you feel. If you feel fine don't sweat it.
Underwhelming
Bikes: Lynskey R330 Ti, Dean El Vado Ti, Trek 4300
I wouldn't see a doctor. I've asked three...at physical exams and once while on a ride with a doc.
Basically, it's very difficult to hurt your heart (or kill yourself) as long as it's in good shape. You have to ignore obvious signs to cause damage. That said, you should know what your maximum heart rate is, and use that in training. Do work hard on the hard days, and do recovery rides to help your body recover (i.e., Zone 1-2).
I'm 41, with a max of 192 (so far), and resting rate around 50. Today's solo century was mostly in Zone 3 at an average of 155 bpm.
Fast club rides I'll get really close to my max, and have a higher average. For instance, a couple weeks ago at a club ride my average was 167, and my max for that ride was 191. You work hard, but then you recover the next day by taking it easy.
Middle-Aged Member
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
The only concern I have heard about having a higher heart rate is maintaining zone 4 (for me) means you are on the threshold of creating lactic acid... for me that is around 167bpm (if I remember correctly)
Now, if you are getting dizzy and light headed, then tone it down
Bikes: Argon18 Gallium 2016, Trek Emonda SL6 Pro 2018, Salsa Beargrease
I just use the maximum heartrate rule of thumb (220 - age) . He is 36 year old, it does 184 so I rounded it down and said "over 180" it could be dangerous. Of course, it depend of people condition... If you start to feel dizzy at 160bpm stop pushing it!
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Trek Marlin 6, Scott Sub 35, Kona Rove, Trek Verve+2
I hit 190 on a good day.
Portland Fred
Bikes: Custom Winter, Challenge Seiran SL, Fuji Team Pro, Cattrike Road/Velokit, РOS hybrid
I were in your shoes, I would not see a doc since there's a lack of evidence that anything is wrong. The first thing I thought when I saw your numbers are that you are simply out of shape. Be aware that what constitutes "out of shape" here is different than in the regular world -- I'd apply that description to 90% of riders on any recreational century even though they can obviously ride 100 miles.
How long have you been riding? 2500km is decent, but it's really not that much. Unless you do a lot of other activity that you haven't described here, it sounds like you're normal.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
You need to do a test to see what your personal max is
That "rule" is supposed to predict maximum heartrate, but is completely useless. You should read up on that.
OP: unless you have some particular medical reason for concern, it's not dangerous or even particularly unusual. (FWIW, according to the "rule" and today's CX race data, I should be 14. https://www.trainingpeaks.com/sw/UK2N...4G3N37J5D36PTQ)
The real danger is being in that 95%+ range for too long of if your heart rate does not come down after you chill out. If you're going hard and then back off, your heart rate should fall accordingly fairly quickly. I'm not talking down to resting but mine settles around 130 pretty a couple minutes after hard intervals.
Staying too high too long will result in dizziness, fatigue, and a sick feeling as you start starving of oxygen. This is fine if it's temporary (like toward the end of intervals) but prolonged periods are dangerous
Bikes: 2008 Cervelo RS, 2004Trek 2100,1985 Nishike Prestige
I check my hrm against my bp machine which also gives hr. If I were you Id have yours checked just to make sure that your getting accurate readings.. In addition , from what I have read about hr its not the actual heart rate thats all that important but at which point as your hr is climbing that your breathing becomes labored . That point is your threshhold hr and the rate that you should concern yourself about while training.
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
I try not to let my HR get below 160, and I'm WAY smaller than you guys. And 160 is low if I am running (best reason to run I have found, gets your cardio thru the roof!). I wouldn't worry about it.
Portland Fred
My doctor has told me that your max heart rate is literally the maximum your heart can pump. Mine is 203 at 27 and I average around 170 on most rides at good effort. The formula is just a ballpark.
Absent any underlying cardiac disease, over-exertion by itself is not dangerous. Now falling off your bike onto your head, or riding into a wall is another story...
Or, just stick around here for a while. Same thing...
I also experience quite high heart rates, like on all out efforts I average in the 190's max at 213.
This is a good read https://www.joefrielsblog.com/2011/03/high-heart-rate-questions.html
I am 28 and had an average hr of 192 for a 25 minute time trial recently. Some people just have higher heart rates. I usually average around 155-160 on my moderate 3 hour saturday club rides. My max is 207. I usually only see over 200 during sprints in races.
Any free medical advice you get over the internet will be worth every penny.....
you're big, carrying freight
160 bpm is really not that high
if you have other signs of some 'condition' then go see a doc, otherwise
the whole Garmin thing is great fun, and some interesting info but a huge number of really great riders rode without that info.
leave the garmin on, cover it up, go ride... then compare how you felt in sections against the info. most will find the info looks a lot worse than they actually felt...
