No Mounting Tabs for Rear Fenders?.... No Problem!
Old 11-12-11 | 12:42 PM
Twonutz's Avatar
Bikes: Norco CCX1, Kona Unit
I recently bought a Kona Unit, primarily for winter commuting. After getting it home, I realized that though there were mounting points on the front fork for fenders, they were conspicuously absent on the rear.
After experimenting for a bit and making little progress, I went back to my LBS for some help. They came up with a solid and aesthetic solution. (Mad props to Phil at Full Cycle!!!)
I've attached some pictures in case anyone else is in the same boat trying to figure out a way to fix a similar problem.
I'm not sure where they got the clamps from, as the closest I was able to find online after the fact were "earthing pipe clamps" (for grounding) or "three bolt pipe clamps". Neither seem to be as thick as the ones my LBS used, though I suppose round clamp might have some advantages. The rubber liner they added should prevent any slipping or rubbing.
Not only were they able to create an attachment point for the rear stays, but through a clever use of spare parts and some dremel work on the rear clip, they kept the lines clean and maximized the amount of clearance to allow me to run larger tires. (2.1" studded should fit with the sliding dropout all the way forward.) By moving the mounting point, it also solved the common issue of clearing the disc brake caliper, without the need for any spacers.
They also made an "extension" for the front fender mount, to compensate for the fork adjusted 29er front end. This allows the fender to sit lower than it would with the stock hardware.
The last thing I need to do is put on my studded tires, then sit patiently and wait for snow!
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Twonutz is offline
Reply
Old 11-12-11 | 04:49 PM
Sounds like you have a very good LBS and mechanic. Enjoy!
Easy Peasy is offline
Reply
Old 11-12-11 | 08:06 PM
streetstomper's Avatar
10 Anniversary
You can get steel loom clamps with rubber cushions in various sizes for about a buck at Home Depot.
https://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Jandd claims to have stainless clamps, but if you order, you get the same loom clamps as above instead of the ones pictured, at a much steeper $4 plus hefty shipping. I suspect they're not stainless, either.
https://www.jandd.com/detail.asp?PRODUCT_ID=FCLAMP
streetstomper is offline
Reply
Old 11-12-11 | 08:24 PM
They look like 3/8" pipe hangers, you can also use heat some flat stock and a hammer to create the same effect. Definitely cool I have the SKS for road bikes
v0_boulder is offline
Reply
Old 11-12-11 | 08:46 PM
david58's Avatar
Bikes: Fuji Cross Comp, BMC SR02, Surly Krampas
I bought four packages of p-clamps in the electrical section at Home Depot, so I could try and mount the rack that didn't quite fit my CX bike for commuting. Wasn't sure of the size, so got a variety. So much better than the seatpost rack!! And thanks to the BF poster that pointed out the p-clamps for me.
david58 is offline
Reply
Old 11-12-11 | 08:48 PM
ussprinceton's Avatar
15 Anniversary
Bikes: '18 S-Works Tarmac (white letters), '18 S-Works Tarmac (black letters), '22 Allez Elite, '16 Emonda SL, '12 SS Evo HiMod team, '12 SS Evo HiMod 2, '03 fuel100, '14 adventure3, '19 BMC TeamMachine SLR01
my seatpost rack acts as a rear fender, but I've been riding my CAAD 10 road bike more
ussprinceton is offline
Reply
Old 11-14-11 | 08:08 AM
Glynis27's Avatar
Spinning @ 33 RPM
Bikes: '89 Fuji Saratoga, '97 Schwinn Mesa SS, '07 Felt F1X, '10 Transition TransAM, '11 Soma Analog SS
The way they used the rear-reflector mount on the front of the rear fender is a new one to me. I'll need to remember that.
Fitting fenders at the shop always takes a bit of time. I actually quite enjoy trying to figure out the best ways to get them fitted and line up.
Glynis27 is offline
Reply
Old 11-14-11 | 11:09 AM
CliftonGK1's Avatar
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
P-clips are the more common way to go than the hanger fittings shown by the OP, but whatever works, right? Looks solid, and I like the front fender drop-hanger solution. It's similar to what I've done on my Cross Check turned commuter, to get a clean fender line with 32mm tires (since it can clear a big-ol pair of 45s). I used a piece of strip steel from the hardware store, chopped it down to size with a Dremel and drilled mounting holes to attach it at the fender bracket and the fork crown. Gotta do what ya gotta do, sometimes.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
CliftonGK1 is offline
Reply
Bianchigirll
Classic & Vintage
51
09-27-16 06:24 PM
jhill44
Winter Cycling
2
11-26-14 08:22 AM
Turtle Speed
Commuting
7
09-20-12 09:26 PM
hobkirk
General Cycling Discussion
14
04-20-11 02:22 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
