flip-flop mismatch
flip-flop mismatch
if i have a 16t cog on one side, can i put a 14t freewheel on the other without messing up the chainline or having to make any adjustments?
Quoted: 1217 Post(s)
Liked 187 Times
I can't find the source right now but IIRC every tooth difference in the cog/freewheel is a 1/4" difference in the placement of the axle in the dropout.
1 bigger tooth moves the axle up 1/4"
Right?
Right?
It won't mess up your chainline at all, but you may not have enough room. Spoonrobot is right, each tooth move 1/4 inch. So if you are making a two tooth differenece your wheel will move 1/2". As long as you have track ends, or horizontal drop outs you will most likely have enough room, but you may need to play around with your chain length.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
Well, you have to get the chain tension right and the wheel straight whenever you flip the wheel whether you have a 16/16 or 14/16, assuming no chain tugs or similar device is in use, it'll be the same amount of "adjusting things".
If it's close to the backend of the dropouts with the 16T you might have to pull a chain link, but that probably only has to be done once.
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
you wont be adjusting anything more than you would be by taking your wheel off and putting it back on, its just a matter of chain tension
Bikes: everywhere
Liked 7,695 Times
I might add, if you have these in your dropouts then you'll want to remove them:
Bikes: Schwinn Madison, Windsor Dover
pro in someone's theory
Bikes: FTP
Quoted: 72 Post(s)
It isn't much, whatever it is and it certainly shouldn't require a change in the chain unless the wheel is seated right all the way at the back or all the way at the front of the dropout anyway.
Liked 187 Times
You gonna eat that?
EDIT: ACK... half that? I gotta read Sheldon's writeup on that.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Adding or subtracting a link in the chain will move the axle 1/2". Changing either sprocket size by one tooth is the equivalent of moving the axle 1/8" (4 mm).
RUSA #7498
Originally Posted by noglider
You gonna eat that?
ON EDIT: Think I figured it out -- one extra tooth increases the circumference of the cog by one half-link. Half of that is on the inside of the chain loop and doesn't contribute to the chain length. The other half contributes equally to the top and bottom of the chain.
While you are pondering it, and imaging things, don't think of circumference at all. Picture the link coming out of the horizontal portion of the chain.
Liked 2,568 Times
One full link is two half-links -- the half-links are 1/2" each.
It's not really a bad idea to have two different chainrings. If you prefer riding fixed and 16t is the best for your normal riding area keep that, and if you need less or more for certain hills or routes, go ahead and put that ring on your freewheel side. This is the beauty of a flip flop. It's almost like predestined gearing but still a lot less cumbersome.
