Go Back  Bike Forums > Bike Forums > Utility Cycling
Pelican or other hard cases
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Old 09-27-12 | 12:40 PM
Burton's Avatar
Certified Bike Brat
Am thinking about attaching a couple hard cases to the rear rack. The current strategy is to use hardware sourced from Arkel (mounting rails) and bolt them to the back of the cases (approx 29" x 16" x 10".
Anyone done anything similar that can offer some input? Not overly concerned about weight issues as these will be on an ebike and case and cargo weight will be less than 50lbs.
Burton is offline
Reply
Old 09-27-12 | 05:47 PM
I have used the Arkel mounting system with a smaller pelican case (10 x 8 x 5) as a means to carry my DSLR. Added some epoxy to the bolt holes to make case water tight. Works great!
myrridin is offline
Reply
Old 09-29-12 | 03:49 PM
Burton's Avatar
Certified Bike Brat
Thanks - I'm expecting the cases in sometime next week and was considering adding a crossbar with a rubber gasket behind it to reduce any flex issues. Great to know it worked out OK for you!
Burton is offline
Reply
Old 09-29-12 | 09:13 PM
I've done it with Ortlieb spare parts--both hanging and flat on the deck of the rack. They have worked out very well.
Allen is offline
Reply
Old 09-29-12 | 09:36 PM
Burton's Avatar
Certified Bike Brat
Cool! Did you have to stabalize the hanging ones at the bottom at all?
I'm wondering how much case 'slap' to expect on rough roads with the bottoms unsecured. I was thinking just a strap over the case and attached to the bottom of the rack might be enough.
Burton is offline
Reply
Old 09-30-12 | 07:09 AM
I did add a bungee cord and hook to stabalize my case. Not because I felt it was needed for stability, but to mirror the way the arkel connections work on my other Arkel bags.
myrridin is offline
Reply
Old 10-01-12 | 03:07 PM
danielgmoore's Avatar
Bikes: Pedego City Commuter
I have a Pelican hardcase mounted as a trunk on my Pedego City Commuter. I evaluated all different kinds of trunks, cases, etc. I have a daily commute in the Seattle area so something that would provide guaranteed dry storage was important to me. I saw a write up with photos on someone who had mounted two as panniers but I just couldn't get that configuration to work for me. Either the panniers were too big or there wasn't enough space inside for my needs. I ended up going with a single storm case on the rear rack and then used further as a platform to mount extra lights and reflective tape. You can view details and photographs of my Pelican trunk mounted on my bike here.
This arrangement may be a little top heavy for some people. It works just fine for me. I added the Ursus Jumbo Double Kickstand which completely solved my tippy parking concerns.
danielgmoore is offline
Reply
Old 10-02-12 | 02:56 PM
Burton's Avatar
Certified Bike Brat
Thanks very much for the photos! Looks like a nice installation!
Looks like I'll be mounting two similar cases as panniers myself. The frame is a factory ebike mid battery design so should handle the weight no problem. Front fork has been upgraded to a RockShox Tora and the rear tite is a 26 x 2.5" so I can run lower pressure and have a less harsh ride.
I'll return the favor and post some shots when everything is installed.
Burton is offline
Reply
Old 11-20-12 | 01:18 PM
Burton's Avatar
Certified Bike Brat
Guess I'm a little late in posting pics but wanted to road test this as well. Quite a few of the contents of the Pedros MTK are redundant. Multiple allan keys and cone wrenches etc aren't needed for simple house calls. So one case is used for basic tools (including a derailleur hanger tool) and work clothes and the other has simple spares - tubes, lubes, cables etc. Total weight of both bags is less than 40lbs.
ebike has a 500W HT motor and has no problem dragging this up any hill in Montreal. Top speed is unaffected, but - you really don't wanna drive fast with that much weight on the back of a bike with no rear suspension unless the roads are perfectly smooth. Soft luggage have some built in suspension - these don't. But they ARE completely waterproof and well suited for the intended use.
The OMM rack was modified slightly - the bottom mounting pieces were tossed and the single piece left was bolted directly to the frame for increase rigidity. The Arkel mounting hardware had to was cut down to fit precisely across the back of the hard case.
File Type: jpg
Burton is offline
Reply
Old 11-20-12 | 01:43 PM
Sorry for the late reply.
https://www.ortliebusa.com/ProdList.asp?scat=21
that is where I picked up the parts. I have lower stabilization but the weight of the case keeps it from slapping about much either way.
Allen is offline
Reply
Old 11-21-12 | 07:55 PM
Burton's Avatar
Certified Bike Brat
LOL Better late than never! Thanks! Some of those look interesting!
Burton is offline
Reply
Old 11-21-12 | 10:21 PM
Sorry about that.
Ortlieb spare parts are great. I used the basket attachment for one pelican case. The L1 (or L2, I forget) system for a hanging case. And the L1 (or 2) system for converting several messenger bags, camera bags, and soft-side cooler into panniers.
Allen is offline
Reply
jefnvk
Touring
31
06-16-16 08:15 AM
azza_333
Touring
8
02-10-15 03:27 PM
motorapido
Touring
4
07-21-14 01:29 PM
empellavega
Utility Cycling
5
08-17-13 09:10 AM
no1mad
Commuting
10
05-25-12 05:09 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
