FD fell off -- this ever happen to you?
Keepin it Wheel
So I'm coming to the end of a major (for me) operation where whole bikes' worth of components are getting swapped between frames. Sunday night I finish assembling bike B, bike A is still awaiting a part, so I decide to ride bike B until bike A is finished. "Just a day or two" I think, "I can chance riding light for that short time; no seatbag, no pump, no patch kit, no tools." Note to self, first ride after a frame-up rebuild, the proper attitude is "bring the whole toolkit because you never know what you might have borked up!"
Well on the way to work, I notice my FD is acting funny. It was well-aligned last night on the stand, but now it's rubbing a lot in the small cogs for both the middle and large chainrings. And hey that's weird, now it doesn't even want to drop to the small chainring. I shrug it off, figure I'll readjust when I get home. Although, something doesn't add up: middle/big ring rub on small cogs means FD is not outboard enough; but not dropping to small ring means not inboard enough. (Anybody want to guess the problem before reading on?)
Don't even look at FD all day, even though the bike lives in my cube with me. Riding home, I notice rub is even worse; and it totally doesn't want to drop to small chainring. I help it there manually, ride a while in the small ring, crest the hill, rest of the way home is downhill. I coast down to the stoplight, when it turns green, I pedal through the intersection, approaching a nice descent now, I push up to the middle ring and KAPOW (last chance to guess before I give the answer)
As I was saying, KAPOW I see a tiny flash of light rocket forwards out of the corner of my eye, I think my FD has exploded! I pull over and I see it is just hanging there by its cable; the bolt that used to be holding it onto the clamp is back there in the gutter (fortunately easy to find!); the outermost couple of threads in the FD are never to be seen again.
Obviously (now) in all my loosenings, adjustings, tightenings, testings, I had forgotten the last tightening of that braze-on bolt, and it worked its way loose over a few miles, the FD was hanging crooked (would have been obvious to fix even by hand if I had bothered to look), causing the peculiar shifting behavior, until finally the last few threads were barely holding on, and I went and tried to shift, and KAPOW...
So there I was sitting on the side of the road, with no tools. If I had at least my bike multitool I would have been able to remove the FD from its cable, open the chain with masterlink, take the FD off entirely, and easily make it home with 1x8 (actually 3x8, since it takes only a few seconds to stop, manually move the chain to the desired ring, and proceed).
Strangely I did have the foresight to pack my rarely-turned-on cellphone in my backpack (yes, I had a whole backpack with just a shirt, socks, underwear, lunch, and a cellphone in it -- I could have brought virtually all my tools if I weren't so stupid!), and I had to suck it up and call home for a ride. Or walk about 4mi. With SPD shoes and a bike with 0 flat tires.
So let this be a lesson to you (and to me!!): don't be stupid!
Keepin it Wheel
The lesson here is, when you take a first ride on a bike after working on something, you should be MORE likely to bring tools related to that something, not LESS. And in this case since I had touched EVERYTHING, it was really stupid to ride totally empty-handed.
Keepin it Wheel
Took a closer look tonight, turns out the screw hole that the braze-on bolt screwed into was helicoiled. Was that way unknown to me when I bought the bike used off CL. (Not that that's bad)
Is it possible this is not my fault? Does helicoil fail catastrophically like that sometimes? Or only when the bolt is left loose?
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
I'll admit it, it happen to me once. My Suntour Superbe Pro front derailleur's band rusted through and just fell off. Fortunately I was just starting my ride and was at the house, and fortunately I had a brand new one in storage. So I took my back up bike and rode it and when I got home worked on replacing the derailleur.
Bikes: enough bikes to qualify for Hoarders......
I had a rear snap off and go into the spokes causing a rather spectacular crash involving a front flip. I was fine the bike decidedly not.
I have forgotten to tighten the stem on my own bike a couple times too, that's exciting
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Well on the way to work, I notice my FD is acting funny...it's rubbing a lot in the small cogs...hey that's weird, now it doesn't even want to drop to the small chainring. I shrug it off, figure I'll readjust when I get home. ...
Mechanic/Tourist
Not to be picky, but you very likely have it reversed - the rear went into the spokes and snapped off. That is why I always shift to the large rear cog at the beginning of every ride.
Keepin it Wheel
It does not matter whether one does a pre-ride check, the components are old or new, the bike is well-maintained, or even whether you are an expert mechanic or a novice. If something starts working or sounding badly, and especially if it gets worse quickly, you need to attend to it immediately. You easily could have had a problem that was far more damaging to you or the bike. Further, for anyone to commute what is apparently a bit of a distance without tools - again, new bike or old - is just asking for trouble.
Keepin it Wheel
Now that's a pre-ride (I guess actually in-ride) check that sounds easy enough to actually always do!
Keepin it Wheel
The FD was on a lower-end Shimano-equipped 2006 Trek 1000. Bikepedia says 2203, but as I bought the bike used, I don't know if it was original equipment.
Bikes: Bridgestone RB-1, 600, T700, MB-6 w/ Dirt Drops, MB-Zip, Bianchi Limited, Nashbar Hounder
And I do carry a lot of tools whenever I ride. Even on newly built bikes that don't need them.
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
I always carry the necessary tool after making a repair or installation, but now that I say it I completely rebuilt the BB on my commuter and I don't carry those tools around. Those are just too big.
Coffin Dodger
I "nut and bolt" my bike once a week when I wash it. I just run through and make sure everything is tight, it adds almost no time, and lots of peace of mind, while out riding.
Pirk
Pirk
Keepin it Wheel
Well that's my point; my problem was thinking "newly built-->don't need tools", where the correct thought should have been "newly built = haven't had time to discover potential mistakes yet --> DO need tools"
Nothing wrong with that, it's best to be prepared for the worst and have nothing happen to not be prepared and have the worse happen. I got into a habit of carrying a lot of stuff too because I use to, and still do, like to ride into remote areas and if I have failure I need to at least limp home and not walk home! I'm the kind of guy to that does not rely on my wife to act as stand in mommy when things go wrong, I will do whatever it takes to get the situation handled, in fact I'm so much that way I don't even carry a cell phone when I ride which forces me not to rely on someone else!
i had a similar problem with the brake calipers on my mtb yesterday but realized what was happening before anything exploded
i had been adjusting my calipers to get rid of a bit of rubbing on the front and forgot to tighten it back down when i went in for the night
then went for a ride with one of my sons yesterday and kept hearing this weird clunking noise fromt he front of the bike when i braked
my headset is kinda kludged together due to a too short steerer tube so i figgered i would have to adjust it when i got home
then i looked down and saw the caliper riding back and forth 1/8" on the loose bolt when i rocked the bike with the brake clamped
so i tightened the bolts down finger tight to get proper attention when i got home
sadly i forgot about it again and rode to work this morning with the caliper only finger tight
so i borrowed an allen key from the shop and went out to adjust it at lunch
anyhow
if you are not perfect like fietsbob and sometimes overlook things like that
when something starts acting funny while riding it is usually a good idea to stop for ten seconds
and check it out
a stitch in time saves twelve
(adjusted for inflation)
anyhow
and check it out
Keepin it Wheel
Keepin it Wheel
Got a replacement FD off CL today, Tiagra road triple braze-on, FD-4503. And it has a nice solid curved washer to replace the flat one I lost on the side of the road.
Took a look and this one is helicoiled for the clamp bolt as well. As far as I can tell, from all the samples I have taken, 100% of all FD are helicoiled!
you summed up your entire post very well in the last sentence.
2010 Kestrel RT900SL, 800k carbon, chorus/record, speedplay, zonda
2000 litespeed Unicoi Ti, XTR,XT, Campy crank, time atac, carbon forks
ademm
Bicycle Mechanics
4
09-04-14 07:38 AM
