top tubes -Level?
top tubes -Level?
Old 06-06-13 | 10:30 AM
15 Anniversary
top tubes -Level?
I have a Pinarello Montello about 1987 with a replacement fork-Tomassini-about the same era.I took a level today to see if the top tube is level and it's not.about 3-4 millimeter sloping upwards towards the front.Were top tubes level on these italian steel racing bikes?Should I have a fork with a longer rake?
trek330 is offline
Reply
Old 06-06-13 | 10:43 AM
photogravity's Avatar
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Out of curiosity, does it look as if the tube is sloping? I'm not sure I'd be able to visually detect a 3-4 mm slope in a top tube. I don't have answers to your questions.
photogravity is offline
Reply
Old 06-06-13 | 10:51 AM
15 Anniversary
Community Builder
I have the same era Pinarello, a 57 center to top, I can measure it for you. rake and length.
There were no standard lengths. Builders did what they felt worked in their minds and this was before "forks-R-us" buyout carbon forks encouraged some uniformity.
In general bikes were designed with a level top tube in mind, but I have a few and seen many examples with factory components that did not have a level top tube.
A 3 to 4 mm difference will probably translate to .25° change in head angle as a rough guess.
repechage is offline
Reply
Old 06-06-13 | 12:10 PM
15 Anniversary
yes it looks level.I put a level on it and if I lift the level a couple of mm on one side the bubble goes between the lines,signifying exact level.I was thinking however that since there is some play for the wheel in the back dropout,true level would be very rare.
trek330 is offline
Reply
Old 06-06-13 | 12:14 PM
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Uhmmm..IIRC, some steel bikes in their smallest sizes tend to have backward sloping tubes because there's no head tube left to shorten to get the TT level..
What size is the Pinarello you are looking at??
Chombi is offline
Reply
Old 06-06-13 | 12:17 PM
15 Anniversary
I would really like that so I would know how close to original is my fork.Also if you could measure the closest distance between the front tire and the down tube,I'd be interested.Mine is exceedingly close.About 1 centimeter.Slightly less at the back wheel!Does your toes hit the tire sometimes?
trek330 is offline
Reply
Old 06-06-13 | 12:20 PM
norskagent's Avatar
car dodger
20 Anniversary
make sure the floor is level too!
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
norskagent is offline
Reply
15 Anniversary
Mine is 54cm.That's C-C.
trek330 is offline
Reply
Old 06-06-13 | 12:32 PM
cyclotoine's Avatar
20 Anniversary
A headset that is 1mm thicker on the bottom cup than the builder designed the frame for could cause this even. And since you have a replacement fork I would say that that is likely responsible. The height on the fork is likely different by a mm or two. Different fork crowns are different thicknesses, which means different height forks and the frame was built according to that particular fork... So I am not surprised. You should be pleased that the difference is so minuscule and you have such a closely matching fork.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
cyclotoine is offline
Reply
Old 06-06-13 | 12:39 PM
If you gotta have it level, face the headset flat on the fork down a few mm.
Wulf is offline
Reply
Old 06-06-13 | 12:43 PM
Chombi's Avatar
Smallish...but not enough for a top tube to go sloping funny. I might expect such on maybe a 48CM and smaller size frame...., so small size is most likely off the list of possible causes.......I think I agree that it might have something to do with the possible replacement fork on the frame then....or the headset configuration/design.....
Chombi is offline
Reply
Old 06-06-13 | 01:22 PM
There's about 6mm of height variability in a horizontal dropout too.
F red is offline
Reply
Old 06-06-13 | 02:41 PM
gaucho777's Avatar
Titanium Club Membership
15 Anniversary
Bikes: 72 Cilo Pacer, 72 Gitane GT, 72 Peugeot PX10, 73 Speedwell Ti,l, 75 Peugeot PR-10L, 80 Colnago Super, 81 Zinn, 85 ALAN Cross, 85 De Rosa Pro, 86 Look 753, 86 Look KG86, 89 Parkpre Team, 90 Parkpre Team MTB, 90 Merlin
Fork's bent!
(Just speculation. Pictures would help.)
P.s. You may get a more accurate measurement by taking the distance from top of the top tube at the head lug to the floor and again at the top of the top tube at the seat cluster to the floor than by lifting the bike to match the level.
-Randy
'72 Cilo Pacer (x2) • '72 Peugeot PX10 • ‘72 Gitane Gran Tourisme • '73 Speedwell Ti • '74 Motobecane Grand Jubile • '74 Peugeot UE-8 • ‘80 Colnago Super • ‘81 Univega Super Special • ‘82 Zinn • ‘84ish Mystery Custom • '85 A.L.A.N Cyclocross • '85 De Rosa Pro • '86 Look Equipe 753 • '86 Look KG86 • '89 Parkpre Team Road • '90 Parkpre Team MTB • '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
gaucho777 is offline
Reply
Old 06-06-13 | 02:46 PM
cyclotoine's Avatar
20 Anniversary
Excellent point also.
Reply
Old 06-06-13 | 05:53 PM
15 Anniversary
Originally Posted by gaucho777
Fork's bent!
trek330 is offline
Reply
Old 06-06-13 | 09:48 PM
gaucho777's Avatar
15 Anniversary
I'm glad for your sake it appears I was wrong. Looks straight enough, though it's not easy to tell from the slight angle of the photo. Shorter bikes do tend to have more issues with toe overlap. Hopefully someone who owns or is more familiar with this model can show an example of an original fork for rake comparison.
-Randy
Reply
Old 06-07-13 | 03:13 AM
Old Yeller's Avatar
Bikes: 1987 Trek 1500, 1989 Pinarello Montello, 1998 Trek 7000 MTB
1989ish 54cm Montello. This may help.... And no, the fork's not bent.
Old Yeller is offline
Reply
Old 06-07-13 | 04:34 AM
I doubt "level" meant 0.00 degrees of variance from true level.
If it rides fine, I wouldn't worry about it.
It's not like it means you have a climbing angle of attack or anything.
If it sloped down, you wouldn't be going any faster, either.
Run a 700x20 at the front and a 700x23 rear, and you should be fine.
RobbieTunes is offline
Reply
Old 06-07-13 | 05:07 AM
Road Fan's Avatar
20 Anniversary
But if you do this, be aware the top of the steer tube will sit up higher above the top of the head tube - could need more spacer for the top half of the headset.
Road Fan is offline
Reply
Old 06-07-13 | 09:42 AM
15 Anniversary
Community Builder
My Pinarello front dimensions:
585 mm direct measure BB center to front axle center.
46 mm rake.
360 mm front axle to crown race seat as measured parallel to the steering axis.
43 mm tubular rim to down tube at the tangent (closest distance) I chose the rim vs the tire as tire size varies much more than rim diameters.
Reply
Old 06-07-13 | 09:57 AM
cyclotoine's Avatar
20 Anniversary
hehe.. Devil's advocate. I am sure Wulf suggested this tongue in cheek, because this would be insane.
Let me ask you forum member... when was the last time you checked to see if your top tube was perfectly level on a perfectly level surface plate? I would be very surprised if any of my top tube are perfectly level given all the variables that go into it.. tire variation, pressure, headset type. position of rear wheel in drop outs... small variations in the construction that are inconsequential... etc.
Reply
Old 06-07-13 | 10:11 AM
15 Anniversary
Community Builder
I use the axle centers. Most are. A number are not. Some rise as much as 8 mm between the seat lug and the head tube. These are for the most part middle size range frames.
Note that if the frame was designed with a "Nuovo Record" steel headset and one exchanges it for a Super Record, you will be off.
I set in almost all cases the rear wheel at the forward most adjustment of the rear dropouts.
Reply
Old 06-07-13 | 10:52 AM
15 Anniversary
46 mm rake.
Thank you for your efforts!!My measurements are less all around but the bike is also smaller so probably that's the reason.Thanks to all who contributed to the subject.
trek330 is offline
Reply
shapiros
Fitting Your Bike
6
06-18-13 07:16 AM
Chief Brody
Road Cycling
6
06-15-13 08:59 PM
shapiros
Singlespeed & Fixed Gear
1
06-13-13 09:03 AM
metalheart44
Fifty Plus (50+)
64
02-11-11 01:34 PM
hhliao
Framebuilders
10
09-10-10 01:00 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
