So my bike lock is extremely broken
Old 11-13-13 | 09:40 AM
Hey guys,
My bike lock (A standard O-ring wheel lock) is extremely broken. I tried to open it like I normally would, but it didn't open, it tried forcing the key a little harder, and now the key is broken and stuck in there.
Now, with even more aggression, the cylinder in which the key goes, can spin around full circle but it still won't open. Any suggestions other than a saw? I only have a tiny hacksaw and it is going to take ages.
Jasp3r is offline
Reply
Old 11-13-13 | 09:48 AM
Myosmith's Avatar
Lover of Old Chrome Moly
I'm not sure what an O-ring wheel lock is but if you can borrow a good bolt cutter you should be able to remove most locks. Hack saws and angle grinders are other options.
Myosmith is offline
Reply
Old 11-13-13 | 09:56 AM
One like this: https://farm6.static.flickr.com/5213/...6cdbffe6_o.jpg , I probably didn't use the right term, in the Netherlands it's called a ringslot (ring lock).
And thanks for the advice
Jasp3r is offline
Reply
Old 11-13-13 | 10:00 AM
no1mad's Avatar
Thunder Whisperer
Bikes: '06 Kona Smoke
"o ring wheel lock" is probably something like the Axa Defender RL-
Click to open expanded view
Community guidelines
no1mad is offline
Reply
Old 11-13-13 | 05:24 PM
dynaryder's Avatar
DancesWithSUVs
20 Anniversary
If you can unbolt it from the frame,you should be able to spin it around to where you can get to the 'loop' and either hacksaw it or clip it with big boltcutters.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Brompton S6L/S2E-X/M6L-X/S12 T Line
dynaryder is offline
Reply
Old 11-13-13 | 07:55 PM
Bikes: 8
sure the lock cylinder where the key goes was not rusty from not oiling .
fietsbob is offline
Reply
Old 11-14-13 | 12:39 AM
thenomad's Avatar
Riding like its 1990
get a bigger hacksaw
thenomad is offline
Reply
Old 11-16-13 | 11:40 AM
elcruxio's Avatar
10 Anniversary
Bikes: 2011 Specialized crux comp, 2013 Specialized Rockhopper Pro
Sometimes those locks can be taken apart with big pliers but hacksaw would be better. Or an angle grinder.
elcruxio is offline
Reply
Old 11-16-13 | 12:04 PM
Bikes: 8
The hasp is not hardened even on the defender the AXA premium model
so a new sharp hacksaw blade should do the job .
NB hacksaws only cut one way , they are not sandpaper.
push and release the pressure on the back stroke.
fietsbob is offline
Reply
Old 11-18-13 | 06:14 AM
Ehm... I think I'm going to buy a new bike.
The lock was too tough for a hacksaw (couldn't get a start) and it BROKE MY BOLT CUTTER.
File Type: jpg
File Type: jpg
Jasp3r is offline
Reply
Old 11-18-13 | 07:12 AM
Phil_gretz's Avatar
Zip tie Karen
borrow or rent an angle grinder. it'll take you a few minutes to cut.
Phil_gretz is offline
Reply
AltheCyclist
Commuting
3
07-17-18 09:35 AM
dmanthree
Road Cycling
11
10-16-15 11:35 PM
amazinmets73
Commuting
7
12-14-14 11:13 AM
Bahnzo
Utility Cycling
73
09-09-12 06:01 AM
M. Kristensen
Advocacy & Safety
20
11-17-10 09:00 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
