I slammed my wheel
I slammed my wheel
I removed a link in my chain last night and slammed the wheel up against the seat post. I've read that this can improve handling and make it more nimble. Did I do a good thing? Are there draw backs other then changing a tire? ...and how does my chain slack look?
Bikes: Fiori Fixie powder blue w/ granny bars
Chain is too slack. Makes no difference in changing a tire, as that the wheel is removed either way.
You will experience MASSIVE reductions in air resistance. Palpable improvements to performace!
You probably will gain like 5mph easy.
Your chain is too tight. Add a couple links.
I'd definitely switch a more aero tire.
You know, your bike has these things called "track ends" and they're there to give you a means of tensioning your chain (aside from removing links of course).
Use them. Stop being silly and worrying about some meaningless street cred factor. An inch between your tire and seat tube means nothing.
THE STUFFED
Bikes: R. Sachs Simplicity; EAI Bareknuckle; Madone SLR9 Gen 8
If for some reason you really have to be more aerodynamic, and the only way to do it is to reduce the drag from your low end high spoke count rear wheel: get a regular old water bottle and cage on your downtube. In one well shared test you save almost 1 minute over 40km.
Veteran Racer
Bikes: 34 frames + 80 wheels
Half-link ftw.
Veteran Racer
Bikes: Guru Evolo R, Colnago Pista, Look AL 464P SS, various frankenbikes
I'm always glad when I can provide some entertainment. the reason I got inspired to do that was to try to get rid of the creaking sound when I pedal. tightened the crank arms so I'm guessing it's the bottom bracket.
How on earth did you think the creak was coming from the space between your tire and seat tube...?
What the **** did I just read.
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Thing is, although you need to do all this, the creak is probably somewhere else. Saddles are notorious - with Brooks it's compulsory (but of chain oil under the adjusting nut fixes that one). Seat posts can creak, as can head sets if not adjusted properly or tight. Just about anything on a bike can creak, including some things that aren't supposed to like frame tubes ... when a crack is developing or other such imminent disaster. More often than not though, the source of the creak will be the last thing you think of and it will be either simple to fix or ridiculously difficult. What it is NOT going to be, is your bottom bracket, despite that being a popular place to point fingers (cue a dozen people all telling us how their bottom bracket was making all the noise).
Basically, your bike as shown in the photo is not set up properly. Why? Because the chain is too slack. Adjust it. Oil it. Then ride it and work out what's happening. Does it creak when you pedal hard and stop when you're merely rolling the pedals over (assuming it's fixed gear, coast if it's freewheel). Does it still do it when you're standing (if not, it's the seat or seat post). Does it do it when you pull on the handlebars. Geddit? Look for the circumstance and then look for the cause.
Now we can all go back to having fun ... can't we?
Or a pedal.
Your cog is slipping.
Bikes: EAI Bareknuckle
Grumpy Old Bugga
tsappenfield
Classic & Vintage
6
07-19-11 02:23 PM
