eai cog on formula hubs
So I'm trying to install a 1/8 17t EAI cog on a Weinmann DP18, which I believe comes with a formula hub but the damn cog would only go halfway. I know about the different sizing for phil and campy hubs but the thing just won't go in smoothly. I installed a cog from my kilo and it fits perfectly, so I compared both threads on the cogs and it seems the EAI has smaller threads. Do EAI made BSC and ISO cogs? Anybody had the same issue? Should I just force the damn thing? Also all parts are new and threads looks good. I probably need to email Ben's.
Bikes: All have flats.
Grease it up, and tighten down with a chainwhip, or use a vise, by wrapping the chain around the cog, and tightening the vise, then turning the wheel like all busdriver style.
That would be my first step. Do you have access to another hub?
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
I just got to work so picture maybe later tonight after watching My Bloody Valentine
It is a very precise fit, so make sure that the cog and hub threads are very clean. Use a tooth brush and some chain cleaner to clean both threads. Carefully inspect all around the threads to see if you have damaged them. Hopefully you haven't cross threaded your hub already. Probably not the cog, as it is steel and harder than the threads on the hub, but check anyway. If all is well, apply a thin coating of grease and carefully thread the cog on. You should be able to seat it all the way with just your hands.
Ahh, I just saw that you tried it on another hub and the same thing happened. Sounds, like you have some debris in the cog threads. I would carefully inspect them, may be a milling remnant, or maybe the thread was damaged somehow. But I certainly wouldn't be cranking it down on any soft hub threads until you know for sure.
trans female, out and proud!
Hammer Nutrition 15% Referral Discount
MassBike.org - Same Road, Same Rules
I just got an EAI from Bens this week and having the same exact problem with my hub threading. It starts off fine but is very hard to get on without using the chain whip. Bad batch? mine is a 1/8 17t. let me know what you find out. Feels like it is x threading. Mine are on Bontragger x lite hubs. posted last night about the problem https://www.bikeforums.net/singlespeed-fixed-gear/468794-help-having-hard-time-get-cog-onto-hub.html
Also how important is it to have a thin washer between the cog and lock ring? what do i get one from?
I just got an EAI from Bens this week and having the same exact problem with my hub threading. It starts off fine but is very hard to get on without using the chain whip. Bad batch? mine is a 1/8 17t. let me know what you find out. Feels like it is x threading. Mine are on Bontragger x lite hubs. posted last night about the problem https://www.bikeforums.net/showthread.php?t=468794
I also saw this from another forum. Don't know if i can cross post but see below.
https://www.orangecountyfixed.com/200...e1/#post935765
Yes, please let us know.
Plot thickens: 3 Euro-Asia Import 1/8" x 17T steel cogs all thread on half way then stop. Sounds like a bad batch. Or someone forgot to change the tap.
I would return it. DO NOT FORCE it, you may end up damaging your hub threads.
zac
zac
thread derailleur
Bikes: 82 Bianchi ECO Pista, Pake, Kilo TT, some *** bmx i found underneath an old house
Didn't have to force mine, screwed on smooth. 17 tooth, 1/8" EAI cog on a Formula hub. Got mine a couple months back though, right after Ben's re-stocked from everyone making a run on 17 tooth model.
freelance gangster
dumb question, but I have to ask: Will a fixed cog screw in on the freewheel side of a flip/flop hub? If so, my brand new 17t 1/8th EAI cog from Benscycle is having the same problem as people above. Formula hub.
edit: i'm not trying to run a fixed cog on the freewheel side, i just wanted to test if my cog would screw in smoothly.
