Nitto Noodle & Soba Bars ?
JoeWolcottCT
Bikes: Cannondale
Hi All,
I've been contemplating changing to a traditional type drop bar and was intrigued by some of the pics in this recent thread:
https://www.bikeforums.net/road-cycling/371736-post-your-classic-bend-handlebars.html
I had tried traditional drop bars before but being primarily a hoods type of rider I could never get comfortable with the steep ramps on most traditional drop bars. What I like about the traditional drop bars is the actual drops where it seems like you can have multiple hand positions just in the drops. I'm running Bontrager Race flat top bars now and love the tops but not the ergo style drops.
The Nitto bars look to me to be the best of both worlds as they offer both a flat top section while still giving you a traditional style drop. The tops being flared back also seem like they might be a little more comfortable than just a straight section.
My questions are these:
Anyone offer any general feedback on the bars themselves.
Is the Soba which has the same shape as the Noodle but in one piece, worth the extra $$ ?
Are either of these bars significantly heavier enough than other all aluminum bars to be a concern ?
Any pics of your Nitto bars would be appreciated too !
Thanks,
J.
Thanks,
J.
I've got the Soba and like it a lot, especially for the flat ramps and rounded drops. Definitely the most comfortable bar I've ever ridden. I chose it over the Noodle to save weight, and because bars with center sleeves sometimes develop annoying creaks which, while not a safety concern for Nittos, annoy me. However, there are ways to eliminate the creak.
I didn't weigh my Soba, but I believe Rivendell has published the weight. It's certainly not significant to me, and I have greater confidence in any Nitto product than I do in the superlight wares from other manufacturers.
Is the Soba perfect? No--I don't care for the backward sweep much. It's neither more nor less comfortable for me than straight tops, but it does change the reach a bit, so now I wish I had a 1 cm shorter stem. I would also like a bit more downward angle to the drops. If using a quill stem, it doesn't look right to me unless the upper ramps parallel the stem, but at that angle on the Soba, the drops slope down only slightly. Finally, I'd prefer a bit (1 cm) deeper drop. But I'm being very picky here. I'm building up a new frame soon, and will be installing another Soba. I like it a lot.
Jack
Jack
JoeWolcottCT
Bikes: Cannondale
Got any pics of the bars on your bike ?
Just curious......most likely will pull the trigger on a set of Sobas once the financial carnage from the holidays settles....
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
I hate the "Noodle" name (they're 177's), but I have two in 46cm and like them quite a bit. No creaking yet.
JoeWolcottCT
Bikes: Cannondale
JoeWolcottCT
Bikes: Cannondale
Found this link from SmartBikeParts.com that lists the weight of 44cm Noodles as 340grams...
https://smartbikeparts.com/search_details.php?itm=HB1026
Still trying to figure out how much light a set of Sobas in the same size would be.....
SilentRider
Bikes: Trek Madone SLR 7, Giant TCR Advanced Pro, Trek Domane SLR, Trek Emonda SLR Project One (x2), custom Bingham Built Titanium road bike
I [now] hate weight weenies.
I just bought the Nitto Noodle bars. Haven't put them on yet as it's going on my in-prgress winter build. But I love the look. I love the curves. I love the drop. I have the 46cm, so I LOVE the width. I love the finish. I LOVE the price ..
Don't know what it weighs and I've had it for over a month. I can't wait till spring.
On the weight of the Soba handlebar, mine is a 46cm and does not feel any different than my ITM Pro260, which is purported to weigh 260g. Although I don't have a scale to verify its weight, I am sure my ITM does not weigh 260g since their supposedly lighter "215" model weighed ~250g when I weighed a few copies many years ago. Rivendell did weigh the Soba handlebar when it was first introduced, and they're officially sub-300g.
Regardless of their weight, the Nitto Soba/Noodle bars are quite fantastic in feel and simply exquisite in looks. For my non-racing bicycles, they are the choice.
The Recycled Cycler
Bikes: Real Steel. Really. Ti is cool, too !
I have the Nitto Noodle 46 size on both my bikes. When I switched to the Noodle bars I noticed a bifg difference in lower back fatigue after long rides of 50+ MILES - I felt much better. I also went with a higher Nitto stem and got bars even with seat, too.
Love the noodles... and they are on a racing bike that isn't raced
https://www.bikeforums.net/showpost.p...86&postcount=7
JoeWolcottCT
Bikes: Cannondale
What kind of bar tape are you running in that pic ?
My own personal taste only...I would tilt your bars up just a smidge...
I like my tops parallel to the ground...drops can be a little slanted...
Nice bike either way...
SilentRider
Is it about taste or comfort?
That tape is nice though .. I wonder if it comes in brown (or the leather look).
Some other pics from an old thread:
https://www.bikeforums.net/showpost.p...2&postcount=27
JoeWolcottCT
Bikes: Cannondale
That's stella azzurra eleganza something or other bar tape, which I didn't like - looks cool though. I went back to cork tape after that... and the bars are actually a little tilted up now (they work well that way with campy hoods)
JoeWolcottCT
Bikes: Cannondale
Going back to your Cervelo pics....is it just your pictures or do the Noodles flare downwards slightly from the stem to the curve by the hood ?
When racing, comfort on the hoods is irrelevant because I spend so much time in the drops. Noodle/Soba bars, in the drops, aren't terribly different than most classic bend bars. Also, when racing, an easy 100+g advantage (difference between my "light" Soba and my Easton carbon handlebar) sometimes cannot be ignored.
Note: please take that last sentence in context, which is the advantage is only part of the larger weight difference of the entire package. Of course, I understand that 100g is not going to win races but 4lbs might.
JoeWolcottCT
Bikes: Cannondale
Fair points all...
Thanks for clarifying....
Let me followup with this then...
Do you run your bars at a different height between your racing/non-racing bikes ?
My other quest in my "great handlebar search" is to be more comfortable in, and spend more time in the drops. Here are the issues involved:
Part A - Not really happy with the shape of my current ergo drops...
Solution, get different bar with more grip options in the drops.
Part B - Perhaps raise overall bar height so being in the drops for extended periods of time won't seem so uncomfortable. The tops of my current bars are 2 1/2" below my seat.....I'd like to keep this differential unless absolutely necessary......will have to force myself to spend time in the drops with the new bar before moving this. Trouble is most of the time I ride solo so I naturally gravitate towards riding the hoods.
For me, the one distinct and significant feature that the Soba/Noodle bar has over other bars is the flatness of the hoods when used with Ergopower or STI. Yes, the finish and reliability are top-notch but I really love how there is so much space on that bar offering slip-free hand positioning.
The top curve towards the hood is fairly flat, but does flare downward slightly. It's not enough to cause that typical 'valley' you see with a lot of bars though.
Yes. The handlebar for my racing bikes are set significantly lower than non-racing bikes. They're typically 3 or 4" below saddle height versus about level with the saddle.
