rattling noisy chain. arrrrghh
Old 12-29-06 | 09:45 PM
BizzaroBike's Avatar
Fear of Napalm
Bikes: 70's Schwinn Suburban. Univega Conversion. Early 90's GT. KHS Flite 100 (in the making).
The chain tension is fine, and the chain line is straight. But the chain is still somewhat noisy and it's driving me crazy! Should I lube it up some more, or is it just my crappy cog? Help me out everybody.
BizzaroBike is offline
Reply
Old 12-29-06 | 09:46 PM
deathhare's Avatar
:jarckass:
Maybe you need a new chain?
deathhare is offline
Reply
Old 12-29-06 | 09:49 PM
Fear of Napalm
argh sorry I forgot to mention the chain isn't even a day old!
Reply
Old 12-29-06 | 09:52 PM
Retem's Avatar
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
clean it check you cog and cr teeth and loube it
Retem is offline
Reply
Old 12-29-06 | 10:15 PM
sniks's Avatar
JuNKie! bike junkie!
I found that 1/8 is a bit louder than 3/32 and that eai cogs are bit more quiet that say a Surly cog or the dreaded cyclepro cog.
I just got a super toughness chain and it is a lot more quiet than the Kool chain (bmx) I had on before.
that my 2 cents.
www.cranks505.com
sniks is offline
Reply
Old 12-29-06 | 10:29 PM
paule's Avatar
What size cog and chain? Also, how tight is your chain? I know you said it was fine, but if it's over tight it will be loud. Lube it up and ride for a few daze. Sometimes these things have a way of working themselves out.
paule is offline
Reply
Old 12-29-06 | 10:32 PM
1. Loosen the chain- 1/2" up/down play is ideal.
2. Clean and lube it.
This will solve 99% of chain noise.
-1/8" chains are a little noisier than 3/32".
- A new chain on old cog/ring may make a bit of noise for a little while as everything hasn't worn exactly together yet.
BostonFixed is offline
Reply
Old 12-29-06 | 10:59 PM
I think any new drivetrain esp 1/8" will be a little noisy to begin with, and then quiet down as everything wears in with everything else. My 1/8" KMC chain/ Surly cog/ TA ring drivetrain was very loud at first and pretty chill now, ~900 kms in.
mander is offline
Reply
Old 12-30-06 | 01:05 PM
mihlbach's Avatar
20 Anniversary
that my 2 cents.
Man my experience is totally opposite. My (new) EAI cog is loud..I've tried serveral chains, all with the same loud results. My surly cog is quieter, or rather, it was quiter before it got really worn. But if I compare them when they were bot unworn...the Surly was much quieter.
My Izumi track chain (EHS) was loud and clanky on all of my cogs, and it was stretched after 400 miles and I was a real Nazi about keeping it clean and lubed, and properly tensioned. What a waste of $50. My cheapo $6 KMC BMX chain is much smoother and quieter.
mihlbach is offline
Reply
Old 12-30-06 | 01:11 PM
Fear of Napalm
16t 1/8 cog, 1/8 KMC chain. I cleaned up everything, and when riding it's almost like I have no chain at all. But it's a lot more noisey when the bike is turned upside down, which, well doesn't really matter, but is it normal? Thanks for all the help!
Reply
Old 12-30-06 | 02:05 PM
mihlbach's Avatar
20 Anniversary
Its noiser when its upside down because you are probably in your garage (or somewhere quiet) and you probably have your face right up to the drive train. Out on the noisy street, with the wind, and your head way up there, any minor noises from your drive train will be unheard, or at least seem quieter.
mihlbach is offline
Reply
Old 12-30-06 | 03:54 PM
jet sanchEz's Avatar
20 Anniversary
Maybe the chainring bolts could use some tightening? Or maybe a little grease on them?
jet sanchEz is offline
Reply
Old 12-31-06 | 03:03 AM
Fear of Napalm
Problem solved, new 18t cog (euro-asia) purchased, no noise. I needed a new bigger cog anyway.
Reply
Old 12-31-06 | 09:58 AM
Retem's Avatar
Paste Taster
I run an old school suntour superbe pro cog an fsa ring and a kmc z chain and when it is clean dead silent like the ninja it is
Retem is offline
Reply
Old 12-31-06 | 10:27 AM
mihlbach's Avatar
20 Anniversary
I like the ninja reference. Its way better than having to read those ******** "butter smooth", "like butta" etc. comments about chains and bearings. I'm really really sick of the butter analogy.
mihlbach is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
