Magnesium alloy extruded frames
Old 04-07-04 | 11:04 AM
james57's Avatar
20 Anniversary
Yes .. I have sent another similare thread but am desperately searcing for some in depth information. I am seriously considering the purchase of a magnesium alloy frame and would appreciate additionnal information. I am not talking about Aluminum with some Mg but +95% Mg alloy with some other elements. Those tubes are extruded and welded together probably with some kind of TIG or laser method process, stress releived, etc ... Frames branded under Merida (909), Paketa rocket, Pinarello dogma are using such Mg extruded tubes.. beside the usual information such as : lightness, vibration, corrosion .. what can you tell me ..
Thks in advance ..
james57 is offline
Reply
Old 04-07-04 | 11:06 AM
p3ntuprage's Avatar
20 Anniversary
Bikes: a tvt soon to become a s/s...
will probably corrode boefore your eyes.
fsnl
sparky
p3ntuprage is offline
Reply
Lance Hater
20 Anniversary
steel
Laggard is offline
Reply
Old 04-07-04 | 11:09 AM
james57's Avatar
20 Anniversary
corrosion does not appear to be a problem if the frame is properly threated .. ie some pedals and stems use Mg alloys and have not shown signs of this problem even after many years..
james57 is offline
Reply
Old 04-07-04 | 11:10 AM
james57's Avatar
20 Anniversary
steel ??
james57 is offline
Reply
Old 04-07-04 | 11:20 AM
joeprim's Avatar
20 Anniversary
I remember when they used Mg for car wheels. Some of them cracked and failed. But then these appeared to be cast. Maybe the extruded would be tougher.
Joe
joeprim is offline
Reply
Old 04-07-04 | 11:25 AM
james57's Avatar
20 Anniversary
Similare issues appeared when they tried to produce cast frames .. and eventually stoppped I believe for the same reason .. I am talking of extruded tubes probably having a stress releive once welded ..
james57 is offline
Reply
Old 04-07-04 | 04:49 PM
p3ntuprage's Avatar
20 Anniversary
those car wheels are forged and need to be replaced after a couple of thousand miles because the go porous.
i wouldn't really hold any hopes for mg frames...
fsnl
sparky
Reply
Old 04-07-04 | 08:26 PM
20 Anniversary
Bikes: Fondriest & Serotta
How about the Pinarello Dogma? There is some info at Competitive Cyclist.
MtnMan is offline
Reply
Old 04-07-04 | 08:38 PM
20 Anniversary
Well, Pinarello says they coat it with a layer of ceramics or something, so that air can't get in. Maybe they have a warranty or something? In any case,if you can afford a Pinarello Dogma, many probably isn't too much of an issue for you. Go for it. And remember to get the Dogma Ego lol 15,000 dollars.
phat bahsturd is offline
Reply
Old 04-07-04 | 10:10 PM
Guest
Guest
Posts: n/a
I spoke to a guy who's son rode for a professional team in the Tour last year with the Pinarello Dogmas. He said they literally fell apart at the end of the season, and they had to return all the bikes. The time now rides with a new bike maker. They were definitely not satisfied with the Dogma- it doesn't sound like it has a lot of longevity.
Koffee
Reply
Old 04-07-04 | 10:22 PM
bitemail's Avatar
20 Anniversary
Th dogma is sweet , cant really go too much on hearsay....look at the good things they say about Trek
bitemail is offline
Reply
Old 04-07-04 | 11:21 PM
Feltup's Avatar
Pain Cleanseth
20 Anniversary
Bikes: On*One Imbred (commuter), Specialized Rockcombo(commuter)
Don't ya think if it was a good frame material someone would be using it? Why do you want to go with Magnesium?
Feltup is offline
Reply
Old 04-08-04 | 05:03 AM
james57's Avatar
20 Anniversary
Thks Phat & Koffee .. and just for the record, I don't have the $ to by a Dogma .. although I am quite interested about the fact that an entire team had to return frame but this could be related to multiple causes. Mg alloys are regularly used in the high end automotive industry, aviation etc .. and once properly coated should be fine. Pinarello uses a variation of such an alloy produced by dedaccai and I would not consider them specialist or inovators in this field but rather co. just sticking their label. Mg alloys are known to be super light (extremely low density approx =1,80 g/cm3 which allows to produce a frame with higher dampening properties and rigidity for the same weight .. I am not by any way defending the use of Mg but have yet to find a major problem for their use .. pls keep this thread running .. we will eventually find something .. Cheers
james57 is offline
Reply
Old 08-04-04 | 06:36 PM
Thought I'd bring this back up to the top since I am looking at a Paketa Mg frame right now. Anyone else have an opinion about this techology or manufacturer.
schwasj is offline
Reply
Old 09-08-04 | 07:09 PM
gcasillo's Avatar
Maglia Ciclamino
20 Anniversary
Bikes: Bianchi Aria, Bianchi Volpe
Well, I was just offered a terrific deal on a Dogma, but after reading this thread, I have reservations about it. At minimum, I would hope to get three good seasons in with it. Anything beyond that would be gravy.
Anybody else know more about these frames. Anecdotes, hearsay, personal experience?
gcasillo is offline
Reply
Old 09-08-04 | 08:09 PM
don d.
Guest
Posts: n/a
Thks in advance ..
I know I'd like to try one. I personally would not be worried about corrosion. People also say the epoxy in carbon fiber frames degrades in sunlight, but I still see 10 yr old CF frames ridden and working just fine. If they lack real knowledge, people rely on rumors and hearsay, but rumors and hearsay are just that.
The pro team Fassa has been racing on Pinarello Dogma magnesium frames for the last three years, so they must work for them.
Magnesium is supposed to provide exceptional vibration dampening, so the story is they should be comfy.
If I was going to get one, the Merida might be the direction I'd go in if a dealer was available.
Reply
Old 09-08-04 | 11:56 PM
chef_jmr's Avatar
showing progress
20 Anniversary
Bikes: Serotta CSI
Just because a pro-team is paid to ride on a certain manufacturer's frames, does not make the frames faultless, nor are the riders all happy about riding them. You may call me a cynic, but there are reasons why some frames have been re-badged to keep the riders happy.
As for another true Dogma incident, my old cycling partner, <170 lbs., just sent back his dogma after the welds cracked!!! Is that worth the $7000? This is not the first time I've heard of this happening to the Dogma; I've scratched it off my short list. He's now on a six13 Cannondale.
chef_jmr is offline
Reply
Old 09-09-04 | 01:12 AM
khuon's Avatar
DEADBEEF
20 Anniversary
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
I'm always amused when people say things like, "well, this material must suck because nobody uses it" or "brand X made a bike out of this material and it broke so it sucks". There are a lot of ways of utilising materials and it's the way that it's done that's more important than the material itself. As was previously mentioned, Mg has been used for high quality parts that seem to be holding up strong in both the bicycle and other industries. Likewise, there have been cases of the opposite. I will not speak to the quality of the Dogma but I would like to just point out that it is extremely narrowminded to discount a material without taking into consideration the manufacturing processes. I keep seeing people do this to everything from carbon fibre to titanium to aluminum and more.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
khuon is offline
Reply
Old 09-09-04 | 10:27 AM
chef_jmr's Avatar
showing progress
20 Anniversary
Bikes: Serotta CSI
I don't think anyone said Magnesium sucks; maybe it is not ready for PRIME-TIME. I am not discounting the magnesium usage but the quality of the frame from Pinarello when it comes to its craftsmanship. When I spend $7000 on a bike, I expect a flawless ride, and welds! I could care less about the manufacturing process and how they got the tubes to that point (I happen to care, but the point is: that is not the consumer's responsibility). I'm the end-user, not the manufacturer.
Yes, many discount newer materials when they have not been utilized correctly and to their fullest potential, but "extremely narrowminded"? I think your pushing it. I am very interested in the future of Mg, but not throwing my $7g's at it. The Serotta Ottrott ST is on top now.
chef_jmr is offline
Reply
Old 09-09-04 | 11:07 AM
don d.
Guest
Posts: n/a
Rebadged Pinarellos?
There is nothing original about an Ottrott. It is an Exxon Graftek redux. And way overpriced at that. At least the Mg manufacturers are working in new territory.
Reply
Old 09-09-04 | 11:20 AM
chef_jmr's Avatar
showing progress
20 Anniversary
Bikes: Serotta CSI
Does no one actually read or comprehend on this forum?
My earlier statement was that some frames are re-badged for the pro-peloton, not unusual, and not referring to Pinarellos.
Second, I was not arguing about the originality of a frame, so whether I want and can purchase a Ottrott who cares about its originality??? It is one of the greatest frames on the market today, if you can or want to afford it. I am not familiar with the Exxon Graftek, but Ben Serotta makes some of the smoothest frames around, with customer spec'd customized carbon tubing, which I would pay for any day over being a guinea pig for an Mg frame.
Mg manufacturers working in new territory? It's just another alloy, I don't see how groundbreaking that is, advanced but not groundbreaking.
chef_jmr is offline
Reply
Old 09-09-04 | 01:30 PM
DocRay
Guest
Posts: n/a
Magnesium in theory is great, and probably great for single season use for a pro, but the long term problems are tricky. It corrodes, it also undergoes electrolysis if another metal touches it. It's difficult to machine or cut or weld. I don't care what they plate it with, if it chips the finish, it will corrode fast, especially in coastal air. New alloys are not flammable at least.
My guess is for the minor increment in performance, it's not worth it.
Here's a bike with bamboo tubing. whatever...
Reply
Old 09-14-04 | 09:34 AM
james57's Avatar
20 Anniversary
Here is the summer update :
I got it straight from the Litech plant in Russia, race version of Mg frame, race 2 du's and a TT, put about 2000 km on it, no cracks, no apparent corrosion, feels great, good dampening, BB very stiff .. and if itall disappears in a yr who cares, it cost 450 USD (frame only)..
weight (2.6 lbs for the frame) ..
james57 is offline
Reply
Old 09-14-04 | 10:00 AM
galen_52657's Avatar
Bikes: 2001 Look KG 241, 1989 Specialized Stump Jumper Comp, 1986 Gatane Performanc
He has got to be different........ can't be seen on just ANY over-priced bike....
galen_52657 is offline
Reply
