#3601
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 527 Post(s)
Liked 449 Times
First front wheel
Test of my first from scratch wheel.
the rear is a heliomatic. Almost done with it.
I wanted a QR front wheel for my single speed. So this front will get double duty for a while on two bikes.
First 41 miles
Mismatched wheels for a bit
First 41 miles
#3602
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 319 Post(s)
Liked 692 Times
1958 Phillips Manhattan 3-speed
Everything works, but still a little creaky and clunky. Worked on the brake calipers tonight.
#3603
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3939 Post(s)
Liked 6,631 Times
I love working on nice stuff from a garage queen... The Torpado had Nisi sewups, so I disassembled them and overhauled the 36h Nuovo Tipo hubset. All matching and original from '72. Didn't really have to polish anything ... which is nice.
#3604
Today I swapped the handle bar om my Gazelle Team ForelDorado-Golff from 1996. My initial setup with a Modolo handle bar and stem kept on twisting and I could not thighten it any more. So I put on a nice Sakea anatomic bends handle bar with a nice Gazelle stem. Pics will be posted soon.
#3605
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 392 Post(s)
Liked 813 Times
Little EGOist taped, black Mirage gruppo canceled, so it got a 10s Centaur to keep it shiny. A well deserved cleaning, cable end cutting, changing crank to Chorus ()once I get a BB), new tires (FIR Aria front wheel most likely remains a dream) and an eventual repaint (in the impossibly far future) remain open, so It won't show up here again for a while.But it came a long way already from the pile 'o junk as I got it, and it's still a budget build for daily beating.
Likes For Lattz:
#3606
Quoted: 7397 Post(s)
Liked 2,572 Times
I put a new stem on my Raleigh Super Course a week or two ago. Now I put on a new bell, and I hooked up the wiring to the dynamo-powered taillight. So now I have two headlights and two taillights for extra safety.
My BB shell doesn't have a cable guide, so I ran the cable for the front derailleur under it just as it is. That turns out not to be so stable, so I ordered a cable guide. I'll be drilling and tapping a hole. In the meantime, I attempted to prevent the cable from sliding sideways by wrapping a zip tie around the shell.
#3607
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
#3608
Veteran, Pacifist
Quoted: 3940 Post(s)
Liked 4,937 Times
Follow up on post #3628 above
Here’s the first ‘parts hang’ - just to take some measurements and see what I think - and then rethink things like housing color / saddle / bar tape. Setback? Lacking a good non-aero brake solution. But it is cleaner, shinier, and more rideable for my current needs.
I feel porkchopbmx will be getting an order for several colors of housing.
Likes For Wildwood:
#3609
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 341 Times
Clean up, tire swap, and new grips for my wife's ride after our summer trips. I think it looks kinda classy.
Likes For mechanicmatt:
#3610
Bikes: A bunch of old bikes.
Quoted: 295 Post(s)
Liked 905 Times
Here is my progress on a bike I've been working on for a few weeks. Not a wall hangar.
Should be finished soon, but snow is coming tonight.
87 Puch Mistral frame, Bottecchia fork, Mavic Module E rims, Helicomatic Hubs, some Shimano Tri-color bits...
Likes For daverup:
#3612
Liked 2,572 Times
The stem is a Nitto Technomic. I thought it might be too tall and too short an extension but I think it's good. I also inadvertently set the bars with the ramps level, and I like that so much that I did the same to my McLean.
The bell is a Greallthy. Silly name, good bell.
#3613
señor miembro
Liked 6,631 Times
Overhauled the Torpado's Dura Ace calipers and learned something new: it's a lot easier to adjust 'em without the spring engaged. I used to tweak adjustment after they were mounted, but I think they're already good now.
Unfortunately, when fiddling with a Campy top tube cable clamp, the screw went flying, and I couldn't locate it in the air nor with a broom for twenty minutes. It has apparently entered another dimension. Godspeed, screw! You are no longer part of this world, but maybe the hardware store can help...
#3614
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Really? I'm embarrassed at how ugly it is, but sure. I have an album of the bike starting in the spring of 2019. I'm still adding to the album.
Did you alter the rear of that bike? If so, how’d it go? I’m thinking my SC would be a good candidate for a 130 spread because I have lots of 9 speed stuff. Just not sure how well indexing works with the claw hanger.
Thanks!
#3615
Liked 2,572 Times
@JacobLee, yes, I spread the rear of the frame. I used the string test to get the rear end centered. I used dropout alignment gauges to make the dropouts parallel, and I used a derailleur alignment gauge to make sure the hanger was aligned. These are all very important to get indexed gears to work right. At first, I spread the frame using a threaded rod, and that worked out very badly because the right side is a lot more flexible than the left side. It's more flexible because of the dent made to give clearance for the crank. I corrected the error by bending with a 2x4 board, and I could feel the difference in flexibility very readily.
Likes For noglider:
#3616
WV is not flat..
After working on bikes for so long nothing should surprise me, but this is always a good one. I can hear the conversation now..."this tube I got at Walmart won't fit in the hole!! Don't worry my Dad has an awesome set of tools I can fix it" A big monster screwdriver and pliers and here is what we have.
Likes For brandenjs:
#3617
señor miembro
Liked 6,631 Times
^ I was thinking, bike shop Rothko, but now I'm thinking, Pop meets Hunter S Thompson gun range.
Likes For SurferRosa:
#3618
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 617 Times
I am so filled with indecision today I don't know what to finish or to start. Should I finish the Sekine ST or start my long awaited CCM project? The recently acquired Rossi would be easy, or the 73 Czech Favorit would be challenging? By days end, I must make some sort of move, .......... or not.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Likes For browngw:
#3619
Liked 2,572 Times
Today I overhauled one of the hubs on my cargo trailer. I'll do the other wheel next. The inside wasn't as bad as I feared. The grease was still wet and not very dirty, even though I've left the trailer out in the rain a few nights. Maybe I overhauled the hubs recently. I ought to log the maintenance I do.
#3620
señor miembro
Liked 6,631 Times
Overhauled everything for the '72 Torpado and now beginning to hang it on the frame.
I wanted to use that IRD 6-speed freewheel and a 126mm Record rear hub, so I also spread the rear drops a little. I intended to get it to 126, but only got it to 123 and called it good. The wheel slips in pretty easily.
Likes For J.Higgins:
#3622
Quoted: 4567 Post(s)
Liked 6,548 Times
@browngw
Now you're just showing off, that has got to be one of the best shop, layout, storage, projects on deck setup I have ever seen.
If I want to work on 2 bikes at the same time, one is in the basement and the other in the garage, which of course doesn't go well despite having plenty of tools for that.
#3623
I got these Simplex shifters for a pretty decent price and I'm working on reducing the diameter of the cable heads for a few Shimano cables. It only takes a minute or two with the cable held in a pair of pliers and working around the diameter of the head with a sanding drum on a dremel, I figure it's best to modify the consumables than bodge trying to drill out the shifters.
#3624
Bikes: '72 Fuji Newest, '79 Fuji Royale Gravel Grinder; '84 Schwinn High Sierra BMX Cruiser; '97 Huffy Tremor BMX
Quoted: 33 Post(s)
Liked 134 Times
I never know where to put this bike...
Finally splurged for some new rubber (SE Cub) for the '84 High Sierra...and bars...and a reissue Haro flex fighter as the cherry on top for the beautiful 80s SR stem I think I can call this one done now!
Likes For FujiSam:
#3625
WV is not flat..
