Why are Modern Bikes So Expensive?
#451
Klaatu..Verata..Necktie?
Quoted: 10659 Post(s)
Liked 12,331 Times
I confess I'm curious where you think you're going to go with this, so let's assume for the sake of argument that I agreed.
#452
Quoted: 3663 Post(s)
Liked 3,100 Times
Likes For smd4:
#453
Quoted: 4644 Post(s)
Liked 5,178 Times
...as I got older, I used to fall less when downhill skiing. This had little or nothing to do with tech improvements in ski's (of which there were many). It had everything to do with me becoming more cautious in what I attempted to do on the mountain. I'm sure increased travel and better suspension components makes a difference, but I'm unconvinced that your crash history is a direct result of technological improvements. Forgive me.
I ski too and skis also improved massively from the 80s and 90s too.
Likes For PeteHski:
#454
Liked 5,178 Times
#455
Liked 5,178 Times
#456
Liked 12,331 Times
But you've failed to prove that point. If innovation proceeded at a constant pace, you could argue that. But you appear to agree that the pace is not constant, thus you can't reasonably argue that the degree of advancement is only what you'd expect.
#457
Liked 5,178 Times
The only thing that really makes me laugh is that as trends come and go, people in the forums end up talking out of both sides of their mouths. The same people are flipping and flopping as the winds blows. First it lightweight is the be all end all. Then some stuff gets added like disc brakes get added. Then weight wasn't really important after all. Then there stiffness in the frame and wheels. But then we have to start running our tires at low pressures for cushy rides. It goes on and on as each new or new again thing comes out. Now we have a thread about the revolutionary tech called hookless rims. It's already been around once and wasn't good then. We got people talking about how it's the bees knees. Just wait though, if the UCI bans them those same people will be talking about how unsafe they are and how they should be wiped from existence. Comedy like that is why I tune into BF.
#458
Bikes: old ones
Quoted: 26482 Post(s)
Liked 10,449 Times
...as you already know, this forum is full of Luddites. If it's new tech, and the pro's are using them, sign me up.
Likes For 3alarmer:
#459
Quoted: 1291 Post(s)
Liked 1,392 Times
It's likely that what's confusing you is that most people in the cycling community are open-minded and adjust their preferences as technology and information comes to light. They're not locked into myths and old wives' tales picked up from hanging around a dusty bike shop or riding with a grizzled old veteran back in the 70s. Nowadays, facts and real information are accessible to anyone.
I recall back in the day we used to debate what was better: DeRosa, Colnago, or heaven forbid a Raleigh. Or the classic argument: Italian or California Masi. Little did we realize at the time they were all effectively the same.
Likes For Atlas Shrugged:
#460
Liked 3,100 Times
Likes For smd4:
#461
Liked 5,178 Times
There are certainly a few very persistent Luddites who are convinced that most, if not all, modern tech is inferior. They come out of the woodwork at every opportunity to deride anything that they perceive to be a threat to their precious icons. I find it all a bit sad to be honest.
Likes For PeteHski:
#462
Bikes: old ones
Liked 10,449 Times
Bicycle drivetrain systems
In 1991, a two-wheel drive bicycle was marketed under the Legacy name. It used a flexible shaft and two bevel gears to transmit torque from the rear wheel, driven by a conventional bicycle chain with derailleurs, to the front wheel.[11] In 1994, Steve Christini and Mike Dunn introduced a two-wheel drive option.[12] Their AWD system, aimed at mountain bikers, comprises an adapted differential that sends power to the front wheel once the rear begins to slip. In the late 1990s, 2WD 'Dual Power' mountain bikes were sold in Germany under the Subaru name. They used one belt to transfer power from the rear wheel to the head tube, a small gearbox to allow rotation of the front fork, and then a second belt to transfer power to the front wheel
#463
Bikes: old ones
Liked 10,449 Times
Feel free to ignore my points about how much anyone really needs to get a good ride and some exercise on a bicycle. I'm used to it by now. Admittedly, I find Strava PR's to be oddly disconcerting.
Here's the obligatory picture of the Bowden Spacelander.
The commercial failure of the Bowden Spacelander proved that bicycle lovers are practical people who want their bikes to work well and last long not to catch the eye. Designed in 1946, the Spacelander was clearly too far ahead of its time. (Its failure also seemed to prove that beauty is in the eye of the customer, not the designer.) Designed by Benjamin George Bowden, the Spacelander’s original concept also included a shaft drive and a dynamo for steep hills so it was definitely not a crackpot concept. But, oh, those swooping front forks. If it had come out in the Swinging Sixties, when sweeping curves and bright colours were the rage, it might have caught on. But probably not.
Likes For 3alarmer:
#464
Liked 5,178 Times
...why is it considered a vermin like attribute ("coming out of the woodwork"), to question your personal preferences, which are clearly the basis for your arguments here, as definitive for what's "good" ? I think maybe you don't understand what I'm deriding, and it's not something I perceive as "a threat to my precious icons". What I'm deriding here is your pseudo religious fervor for things new in the world of bicycles, because you like them, and they get used by the pro peleton. I don't personally think all modern tech is inferior, with regard to bicycles. I just think it's sometimes considerable overkill for most of us.
#465
Liked 12,331 Times
I did. I didn't agree to that. Wait, wasn't it you that intimated my point would only be valid of the pace of change wasn't linear? And now you're saying that my point would be valid if the pace WAS linear?? YES, yes, it was you!
So which goal post do you want to use? The pace of change is linear, or it isn't?
#466
Liked 3,100 Times
Likes For smd4:
#467
Bikes: old ones
Liked 10,449 Times
...out of curiosity, is there anyone who disagrees with you on this topic who is not a troll ? It's a credit to your own (self)importance here, that there are so many people interested only in pushing your buttons. A vast "hoard of Luddites, coming out of the woodwork", is how you put it.
How do you manage to talk to people in real life, who do not share your views on a topic ? Do they eventually run and hide, when they see you approaching ?
Likes For 3alarmer:
#468
Liked 12,331 Times
I did! I was going to comment on how nicely the 6207s fit the levers, and how good they look, but I decided to take the Circuit for its 3rd shakedown ride. The Avocet saddle is a big improvement, but I think I need to move it back about 5mm.
#469
Liked 5,178 Times
#470
Liked 5,178 Times
It’s rarely a problem in real life because most of my views are not very controversial. For example I tend not to argue that the earth is flat.
#471
Liked 5,178 Times
...the professionals of the past were, presumably, taking the most advantage of the product available. Pete is, presumably, taking the most advantage he can of the current product. I'm asking if he can take so much advantage, that he exceeds the guys back then, who were better than both of us. That's a legit question, and you are either trolling today, or desperately in need of another cup of coffee. I'm out.
But even if I was riding pro level race bikes I don’t see what relevance my performance would have to pros riding bikes from the past. I have no doubt Eddy Merckx would have left me for dead on his 70s racer, but that doesn’t mean I would want to swap a modern race bike for his old steed.
Likes For PeteHski:
#472
Bikes: old ones
Liked 10,449 Times
This is such a silly question on every level. Firstly I ride an endurance road bike and a trail mountain bike. Neither are optimised for elite competition or races by pros. They are both high performance second-tier recreational bikes aimed at guys who prioritise comfort over all-out speed. They must be pretty effective because I regularly ride all day without any issues. I take full advantage of their comfort and wide gear range. They are quiet, reliable bikes and perform considerably better than bikes I owned previously.
Now, I discover to my surprise, that speed is not one of your goals at all. The only reason this came up is because you've spent so much time here (and in other places) touting the nature of the tech improvements that make these bikes superior because of stuff like aero profiles. And every time I've seen a discussion of wheels, you're there with "heavier deep profile rims are faster, thus better."
I feel a great sense of betrayal. Like I've been trolled by a master troll, who strings you along for a while, then doubles back to discard all that was said before.
Mostly, if all you're interested in is riding your bike all day, (endurance) what difference does it make what you do it on ? Gearing that will do the job has been available for many years now, and people have been doing endurance rides since Hector was a pup. Masterful trolling on your part. I salute you. Apparently you're just here to defend technology for its own sake, regardless of whether you use it yourself.
Likes For 3alarmer:
#473
Liked 1,392 Times
...and it is this modern high performance that allows you to ride all day ? I'm genuinely interested in this statement, because I have done the same thing on 80's bikes. Obviously I'm missing something in your argument. What am I missing ? I thought your whole point has been that modern high tech goes faster, and does it better ? Am I mistaken in that ?
...once more, and for the last time, I think. I was asking about this in the context of almost all your prior statements, (in this thread and others), about the huge leaps in technology that make these modern wonder machines things of great functional performance, that go faster than the old stuff, and do it better. My own conviction is that you need to be at an upper level of athletic ability and training to take advantage of these performance gains.
To tie that back to the original premise of this thread those developments were expensive to develop and produce. If you like old stuff or bikes from the 80’s they are readily available on the used market for very reasonable prices which are dropping precipitously, enjoy.
#474
Bikes: old ones
Liked 10,449 Times
Originally Posted by 3alarmer
Oh, you think technology development is linear right?
I don’t actually know the history of bicycle development between 1940 and 1980 but I doubt it involved very much in terms of new technology and production processes. As an engineer, most of the major development appears to have occurred over the last 2 decades. Isn’t that why retro-grouches complain about all the non-standard proprietary parts we see today?
I had a guy next door for years like that. You quickly learn to nod, smile, say, "Good morning," and then make for your front door.
Technological progress...real progress...is not defined by the number of engineers employed designing proprietary parts that work on the same principles, and about as well, as the old ones. And it would be swell if you could back up your statements about this new army of bicycle engineers working for the various manufacturers. I have no idea whether it's true or not, it might very well be. But if all they're doing is continuing to redesign the carbon fiber plastic framed bicycle with a chain drive shifted by derailleurs, I don't see the leap. Maybe a short hop.
#475
Quoted: 4081 Post(s)
Liked 7,667 Times
Likes For tomato coupe:
