Average Male Inseam to Height Ratio?
big ring
Originally Posted by biker7
Don't know if you have a background in statistics or not. Bottom line is inseam length (independent of height) still dominates for the vast bell curve of cyclists out there. There is a correlation however. Dave Moulton's chart is derived by thousands of fittings and he is a pre-eminent expert on the subject. So is Sheldon Brown. Both subscribe to the 2/3 X's cycling inseam for frame size. I do too. Statistically most (not all) derive their height in their legs. Tall people many times have pedestrian length torsos. This applies to Sheldon Brown and myself and countless others. As a result, bicycles are designed to grow vertically almost 2:1 versus horizontally in frame size. This is not happenstance but based statistically on a normal distribution of height to inseam ratio. The reason that seat tube length or now virtual seat tube length with the advent of sloped top tube geometry bikes predominates is because virtual or actual seat post length dictates head tube length. In the grand scheme it is the ratio of seat post to head tube length that matter for saddle to handlebar drop. The other prevailing factor is top tube length and again, top tube does not increase nearly as must as seat post and head tube length between frame sizes which agrees with the statistical norm that torso size does not change nearly as much as inseam for different size people.
HTH,
George
HTH,
George
Double Secret Probation
Bikes: Madone 6 series SSL, Cannondale CX9, Trek TTX, Trek 970, Trek T2000
Height 184.3 cm
Inseam 89.2 cm
Ratios 2.07 or 0.48
I ride a 60 Trek, with about 81 cm seat height and a 120 mm stem
Inseam 89.2 cm
Ratios 2.07 or 0.48
Time to Ride...
Time to Ride...
Might I pose another question.. Are short legs(relative to overall height) a disadvantage. It would seem a relatively long torso would be more weight for the shorter legs to push around.
Quoted: 1811 Post(s)
Liked 1,335 Times
Someone here has to know something about Fibronacci's Golden Number, no? I just know it exists. 1.68 ratio or something like that. Anybody?
big ring
The golden ratio in the human body
It may be surprising to know that the golden ratio can be found in the human body. Your hands contain three bones in each finger (you may notice this more by bending them). The ratio of the longest bone compared to the middle bone and the ratio of the middle bone compared to the smaller bone are both close to 1.618. (The Fibonnacci ratio.)
Another place you will find the golden ratio is your height. Measure how tall you are and compare this to the distance between your feet and navel. Their ratio is close to 1.618. Your face may also contain the golden ratio. What is the ratio of the width of your mouth compared to the width of the bottom of your nose?
Some people think that the closer certain ratios in your body are to the golden ratio, the more attractive you appear.
However, the golder ratio addresses the "aesthetic" imperative - it would be a stretch to say a person with a golden ratio proportion is stronger than another without said proportion.
big ring
This is the essence of my original question. However, no one knows what the average male inseam-to-height ratio is, so relative comparisons are meaningless at this point.
Originally Posted by MIN
I have no idea what that is supposed to mean. Clarify? Also, I am somewhat of a stats guru, by trade.
George
I am 5'10" and where a 30 inch length jean size. I have also wondered if there was a frame designed for short leg cyclist like ourselves. Looks like the answer isn't going to come in this thread though.
George
Liked 1,335 Times
FWIW, jean inseam and your inseam are two different things.
big ring
I just wanted to confirm you are clueless as many statisticians are...lol. You can crunch indices and distribution skewness all you want, but it always comes down to the application of the relationships that matter which most statisticians can't fathom. And hence your question. Your statement above without addressing the substance of my response confirms it.
George
George
I'm trying to address you response but I have no idea what you were tying to say. Don't take it as slander, you just were not clear to me.
You state: "inseam length (independent of height) still dominates for the vast bell curve of cyclists out there." Bell curve of what and how does inseam length dominate?
I resemble that remark!
Bikes: Cervelo Soloist Team, Flyte SRS-2, Raleigh R-600, Gary Fisher Utopia
I've spent way too much time thinking about how useless and annoying this mental ************ exercise is. Worse than carbon v. steel, spoke counts and saddle preferences combined. I compute a 99.9997% probability that the only way you'll know it fits is if you ride it!
Time to bring in the clowns, dial it up to 400 watts and get the hell outta here :
I really can't help you if you don't understand my initial response. Don't feel alone, many don't understand bicycle fit as it takes quite a bit of study. Your question is simply esoteric or not particularly relevant to bicycle fit, that's all. Studying the relationship of any two traits of human anatomy to surmise a correlation to fit is simplistic. Not unlike the belief that top tube length is most important or virtual seat post dominates when it comes to fit. These are conventions of convenience. They all matter as fit is a puzzle with many relationships between anatomy and bicycle geometry…some competing. A better study for example would be the ratio of thorax height to cycling inseam as neck and head height are pretty irrelevant. Or study foot length to saddle height as they clearly relate...or femur length to KOPS relative to inseam and CG on the bicycle for optimal 55/45 weight distribution for the best fit. If you take a deep enough dive, you will find that studies that include two variables are meaningless.
I will leave you with a simple example.
Cigarette smoking has been deemed to be beneficial. Under times of high stress, studies have proved that ingesting the amount of Nicotine in a single cigarette has a calming affect on a vast majority of the population. The study concludes therefore that everybody should light up when having a difficult day.
As a sidebar, which wasn't part of the study...
It was determined later in a separate study that long term cigarette smoking will promote premature death.
George
big ring
With all due respect, inseam-to-height ratio is not that far-fetched of a metric to consider in determining the overall shape of a rider's body. I will concede however that inseam-to-thorax height might be a better metric (as it discounts the length of the neck and head). Ultimately, both are proxy variables in determining the overall "leginess" of a rider.
Per the Cannondale website:
Your inseam to height ratio, the length of your arms, the size of hands, the size of your torso etc. all factor into determining the correct fit of a bike. As a result, Cannondale highly suggests that you not rely on fit charts, but instead seek professional guidance and recommendations from an experienced bicycle shop.
George
I like beans
Bikes: Tarmac Pro, Bianchi Zurigo, Raleigh Gran Sport, Fuji Del Rey, Ironman Centurion
Wow, never realized how long my torso is.
Overall: 73"
Inseam: 31"
42%
No wonder why I like compact geometry.
Overall: 73"
Inseam: 31"
42%
Does anyone know what the average male inseam-to-height ratio is?
Do manufactures set geometry with this proportion in mind?
My measurements:
70" (177.8cm) Height
32.25" (82cm) Inseam
46.1% Inseam to Heigh Ratio
I want to know - relative to the male norm for my height - is this short legged or long legged?
Based on the answer to above, which company's geometry would suit me? (Example: I know Lemond is good for relative short legged riders, but I'm not sure what that is, quantifiably.)
My measurements:
96.5cm inseam
55%
Quoted: 1067 Post(s)
Liked 259 Times
I am guessing a bit here but am fairly sure I am correct in saying that taller people have longer legs than shorter people.
i.e the average inseam/height ratio of people that are 5'8" would be less than it is for people that are 6'4".
So a meaningful "average" would need to account for height.
Should Be More Popular
Quoted: 22750 Post(s)
Liked 9,133 Times
Cheerfully low end
Quoted: 649 Post(s)
Liked 1,067 Times
Indeed! Anyway, if you approximate body height at 7.5 heads and leg length at 3.5 heads, you would expect the distribution to center around 46% which I think is a reasonable estimate. If it were a couple percent lower, I wouldn’t be surprised.
I’m at about 49% and toward the long leg end of the distribution.
Otto
Otto
